A set view of Folders does not stay
Thank you for your reply.
I just checked it > it is set correctly, however it does not solve the problem. I found out even if you adjust a folder after closing and opening the colloums are small again. No need to close Pegasus
<P>Thank you for your reply.</P> <P>I just checked it > it is set correctly, however it does not solve the problem. I found out even if you adjust a folder after closing and opening the colloums are small again. No need to close Pegasus </P>
If I optomized the with of the positions From, Subject, Date/Time and Size of a folder and close afterwards Pmail > when I open Pmail again the coloums are back small again.
How could I possibly set it in a way that it will stay ?
<P>If I optomized the with of the positions From, Subject, Date/Time and Size of a folder and close afterwards Pmail > when I open Pmail again the coloums are back small again.</P> <P>How could I possibly set it in a way that it will stay ?</P> <P mce_keep="true"> </P>
[quote user="HBruder"]
Do you have Save the Pegasus mail desktop state between sessions checked in Tools | Options | Basic settings? Hope this helps.
Steffan
[quote user="HBruder"]<p>If I optomized the with of the positions From, Subject, Date/Time and Size of a folder and close afterwards Pmail > when I open Pmail again the coloums are back small again.</p> <p>How could I possibly set it in a way that it will stay ?</p> <p mce_keep="true"> [/quote]</p><p mce_keep="true">Do you have <i>Save the Pegasus mail desktop state between sessions</i> checked in Tools | Options | Basic settings? Hope this helps.</p><p mce_keep="true">Cheers! Steffan </p>
