Thank you for your reply.
I just checked it > it is set correctly, however it does not solve the problem. I found out even if you adjust a folder after closing and opening the colloums are small again. No need to close Pegasus
<P>Thank you for your reply.</P>
<P>I just checked it &gt; it is set correctly, however it does not solve the problem. I found out even if you&nbsp;adjust a folder&nbsp;after closing and opening&nbsp;the colloums are small again. No need to close Pegasus&nbsp;</P>
