In addition to Thomas' comments it should be noted that paths without drive letter may not work if running Mercury as a service. This is how it Mercury creates a path by default:
mailqueue: C:\PROGRAM\MERCURY\QUEUE
Paths are not needed for protocol modules (the dll:s should be in the Mercury directory).
Unless your computer actually is named "localhost" you shouldn't specify that name in the Domains section.
As you apparently had the scheduling module MercuryX loaded it should be noted that this module is broken in the 4.72 release and may have caused problems for you. There is a patch in the downloads section, but in your case just turn it off as Thomas suggested.
<p>In addition to Thomas' comments it should be noted that paths without drive letter may not work if running Mercury as a service. This is how it Mercury creates a path by default:</p><blockquote><p><i>mailqueue: &nbsp; &nbsp; &nbsp; C:\PROGRAM\MERCURY\QUEUE</i></p></blockquote><p>Paths are not needed for protocol modules (the dll:s should be in the Mercury directory).</p><p>Unless your computer actually is named "localhost" you shouldn't specify that name in the Domains section.</p><p>As you apparently had the scheduling module MercuryX loaded it should be noted that this module is broken in the 4.72 release and may have caused problems for you. There is a patch in the downloads section, but in your case just turn it off as Thomas suggested.</p><p>/Rolf&nbsp;</p>
