shortcut help
Thomas thank you so much for the help.
That took care of my problem.
Ken
<p>Thomas thank you so much for the help.</p><p>That took care of my problem.</p><p>Ken </p>
I have Pegasus 452 running on one computer1. On computer2 I would like to have a short cut that works with the mail box on computer 1.
I have installed Pegasus on computer 2 then tried to change the short cut properties Target to \\computer\PMAIL\Programs\winpm-32.exe
I have also changed the Start in to \\computer\PMAIL\programs
I always end up in the new mailbox on computer 2 not the one on computer 1
This should be simple but I don't know what I am doing wrong.
<p>I have Pegasus 452 running on one computer1. On computer2 I would like to have a short cut that works with the mail box on computer 1. I have installed Pegasus on computer 2 then tried to change the short cut properties Target to \\computer\PMAIL\Programs\winpm-32.exe I have also changed the Start in to \\computer\PMAIL\programs I always end up in the new mailbox on computer 2 not the one on computer 1</p><p>This should be simple but I don't know what I am doing wrong.</p><p>Thanks </p><p> </p>
> I always end up in the new mailbox on computer 2 not the one on computer 1 This should be simple but I don't know what I am doing
> wrong.
Use pconfig.exe from the \\computer\PMAIL\programs and change the home an new mail directory drive letter to \\computer\PMAIL  so that the program goes to the correct system to find the computer mailboxes.  For example, if the HOME and NEW mail directory currently shows c:\pmail\mail\~8 then change it to \\computer\PMAIL\mail\~8.
Now when \\computer\PMAIL\programs\winpm-32.exe is called it will go to \\computer\PMAIL\mail to read the pmail.usr file and then go to \\computer\PMAIL\mail\username to read the pmail.ini file.
> I have Pegasus 452 running on one computer1. On computer2 I would like to have a short cut that works with the mail box on computer 1. > > I have installed Pegasus on computer 2 then tried to change the short cut properties Target to \\computer\PMAIL\Programs\winpm-32.exe > > I have also changed the Start in to \\computer\PMAIL\programs > > I always end up in the new mailbox on computer 2 not the one on computer 1 This should be simple but I don't know what I am doing > wrong. Use pconfig.exe from the \\computer\PMAIL\programs and change the home an new mail directory drive letter to \\computer\PMAIL  so that the program goes to the correct system to find the computer mailboxes.  For example, if the HOME and NEW mail directory currently shows c:\pmail\mail\~8 then change it to \\computer\PMAIL\mail\~8. Now when \\computer\PMAIL\programs\winpm-32.exe is called it will go to \\computer\PMAIL\mail to read the pmail.usr file and then go to \\computer\PMAIL\mail\username to read the pmail.ini file.
