Is it failing to send messages when it isn't set to use the password/username from a POP3 definition? You are not totally clear on whether this issue is simply strange and confusing or actually preventing you from sending messages.
Also, because the option above it is to use a specific username/password, I wonder whether Pegasus is grabbing those details from the previously-set definition and using them (or trying to) under that setting. Just a thought - I'd be surprised if it was.
<P>Is it failing to send messages when it isn't set to use the password/username from a POP3 definition? You are not totally clear on whether this issue is simply strange and confusing or actually preventing you from sending messages.</P><P>Also, because the option above it is to use a specific username/password, I wonder whether Pegasus is grabbing those details from the previously-set definition and using them (or trying to) under that setting. Just a thought - I'd be surprised if it was.</P>
