Just a thought, is it possible that MS objects to the same ip address for two host names? No one else does so far as I can tell.
Here is the smtp log and the mercury.ini file
SMTP Log:
1 mail sent from hotmail to james.parker@bishopsstortford.org (received)
1 mail sent from hotmail to james.parker@bishopsstortfordtc.gov.uk (not received)
1 mail sent from hotmail to both (received on bishopsstortford.org only
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
0420 4cc30ec2 Connection from 65.55.90.96
T 20101023 180420 4cc30ec2 EHLO snt0-omc2-s21.snt0.hotmail.com
T 20101023 180421 4cc30ec2 MAIL FROM:<james.parker.bstc@hotmail.com>
T 20101023 180421 4cc30ec2 RCPT TO:<james.parker@bishopsstortford.org>
T 20101023 180421 4cc30ec2 DATA
T 20101023 180421 4cc30ec2 DATA - 46 lines, 1188 bytes.
T 20101023 180422 4cc30ec2 QUIT
T 20101023 180422 4cc30ec2 Connection closed with 65.55.90.96, 2 sec. elapsed.
T 20101023 180522 4cc30ec3 Connection from 109.86.89.143
T 20101023 180522 4cc30ec3 HELO arscomp
T 20101023 180522 4cc30ec3 MAIL FROM: <tic@bishopsstortford.org>
T 20101023 180523 4cc30ec3 RCPT TO: <tic@bishopsstortford.org>
T 20101023 180523 4cc30ec3 DATA
X 20101023 180523 4cc30ec3 'Viagra' encountered in subject line - connection dropped.
T 20101023 180523 4cc30ec3 Connection closed with 109.86.89.143, 1 sec. elapsed.
T 20101023 180654 4cc30ec4 Connection from 65.54.61.95
T 20101023 180654 4cc30ec4 EHLO snt0-omc2-s44.snt0.hotmail.com
T 20101023 180655 4cc30ec4 MAIL FROM:<james.parker.bstc@hotmail.com>
T 20101023 180655 4cc30ec4 RCPT TO:<james.parker@bishopsstortford.org>
T 20101023 180655 4cc30ec4 DATA
T 20101023 180655 4cc30ec4 DATA - 47 lines, 1243 bytes.
T 20101023 180655 4cc30ec4 QUIT
T 20101023 180655 4cc30ec4 Connection closed with 65.54.61.95, 1 sec. elapsed.
# MERCURY.INI generated by Mercury Setup
# Sample Bindery Mode / Standalone Mode MERCURY.INI file.
# This sample file implements most of the possible switches for each
# module, but you can edit it to do less if you wish.
# Anything after a '#' to the end of the line is a comment and
# is stripped out before parsing. Trailing and leading whitespace
# is also stripped before parsing. Many sample commands have been
# left in this file commented out for reference purposes.
# Note that in general, manual modification of this file is NOT
# RECOMMENDED - use the Mercury "Configuration" menu to change the
# program's settings wherever possible.
[General]
myname: mail.bishopsstortfordtc.gov.uk # Canonical name for this server
timezone: +0000 # Time Zone to add to date fields
mailqueue: D:\MERCURY\QUEUE # Where mail should be put for delivery
smtpqueue: D:\MERCURY\QUEUE # Where the SMTP client should look for mail
newmail_path: D:\MERCURY\MAIL\~N # Where to find the users' WinPMail mailboxes.
[Protocols]
C:\Program Files\MERCURY\mercurys.dll
C:\Program Files\MERCURY\mercurye.dll
C:\Program Files\MERCURY\mercuryp.dll
C:\Program Files\MERCURY\mercuryd.dll
C:\Program Files\MERCURY\mercuryi.dll
C:\Program Files\MERCURY\mercuryb.dll
[Mercury]
failfile: C:\Program Files\MERCURY\Mercury\FAILURE.MER # Delivery failure notification template
confirmfile: C:\Program Files\MERCURY\Mercury\CONFIRM.MER # Delivery confirmation template
aliasfile: C:\Program Files\MERCURY\Mercury\ALIAS.MER # System-wide alias file
synfile: C:\Program Files\MERCURY\Mercury\SYNONYM.MER # User synonym database
listfile: C:\Program Files\MERCURY\Mercury\LISTS.MER # List of lists
logfile: C:\Program Files\MERCURY\Logs\Core\~y-~m-~d.log # Traffic logging file
retpath: 1 # Do/Don't use 'return-path' for errors
poll: 60 # Seconds between queue polling cycles
scratch: C:\Program Files\MERCURY\Scratch # Where we can write temp files
postmaster: Admin # NetWare UIC of postmaster
broadcast: 1 # Yes, we want broadcast notifications, but
PM_notify: 1 # Do/Don't send errors to the postmaster
change_owner: 1 # Change message ownership to recipient
hard_quit: 49 # If NZ, quit only on Ctrl+File|Exit
RetryPeriod: 10 # Period between job retries (minutes)
MaxRetries: 16 # Maximum number of times a job can fail
TwoPasses: 1 # If NZ, process submission queue in 2 passes
Autoaddress: 1 # If NZ, auto-generate user addresses based on name
Daily_exit: 0 # If NZ, auto-restart each day after maintenance
Alt_Forward: 1 # If NZ, allow alternate forwarding specification
Maint_hour: 23 # Hour for daily maintenance (24-hour clock)
Retry_Mode: 0 # If NZ, use progressive backoff for queue retries
Local_DSNs: 1 # If NZ generate Delivery Status for local users only
DSN_time1: 10800 # Seconds deferred before first DSN is sent
DSN_time2: 86400 # Seconds deferred before second DSN is sent
DSN_time3: 259200 # Seconds deferred before third DSN is sent
Host_in_title: 0 # If NZ, show hostname in system tray and taskbar
Lingering: 0 # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60 # Seconds before a lingering mailbox is shut down
Alert_Host: notify.pmail.com # Host to check for licensee advisories
Alert_Interval: 720 # Frequency in minutes (min 240) for checks
Alert_Flags: 3 # Flags controlling advisory checks
[MercuryC]
logfile : C:\Program Files\MERCURY\Logs\MercuryC\~y-~m-~d.log # Traffic logging file
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryC\ # Directory for session log files
Session_logmode : 0
host: # mail mail host which relays for us
scratch: C:\Program Files\MERCURY\scratch # Where we can write temp files
poll: 30 # Seconds between queue polling cycles
failfile: C:\Program Files\MERCURY\Mercury\FAILURE.MER # Delivery failure template
esmtp: 1 # Yes, we want to use ESMTP extensions
[MercuryE]
HELO : mail.bishopsstortfordtc.gov.uk
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryE
Session_logmode : 1
Poll : 15
Timeout : 60
Nameservers : 192.168.1.254
Logfile : C:\Program Files\MERCURY\Logs\MercuryE\~y-~m-~d.log
Log_Verbose : 0
DNS_Timeout : 60
DNS_Retries : 4
Transcripts : 1
MaxThreads : 10
[MercuryD]
Scratch : C:\Program Files\MERCURY\Scratch\MercuryD
Timeout : 30
Poll : 30
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryD
Session_logmode : 0
[MercuryS]
Debug : 1
HELO : mail.bishopsstortfordtc.gov.uk on oak
Logfile : C:\Program Files\MERCURY\Logs\MercuryS\~y-~m-~d.log
Timeout : 30
Relay : 0
Strict_Relay : 1
8BitMime : 1
Allow_Illegals : 0
SMTP_Authentication : 0
Killfile : c:\program files\mercury\sender.kfl
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryS
Session_logmode : 0
Compliance_Settings : 292
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 2
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 1
SMTP_ConnFlags : 0
[MercuryP]
Scratch : C:\Program Files\MERCURY\Scratch\MercuryP
Logfile : C:\Program Files\MERCURY\Logs\MercuryP\~y-~m-~d.log
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryP
Session_logmode : 0
Timeout : 60
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup : TESTGRP
[Domains]
bishopsstortfordtc: bishopsstortfordtc.gov.uk
bishopsstortfordtc: [192.168.1.19]
bishopsstortfordtc: bishopsstortford.org
[Maiser]
Helpfile: C:\Program Files\MERCURY\Mercury\MAISER.HLP # Help sent on failed maiser requests
Lookupfile: C:\Program Files\MERCURY\Mercury\MAISER.LKP # Format file for the 'lookup' command
Send_dir: C:\Program Files\MERCURY\Mercury\SENDABLE # Directory for the 'send' command
Logfile: C:\Program Files\MERCURY\Logs\Maiser\~y-~m-~d.LOG # Mail server log file
Notify: C:\Program Files\MERCURY\Mercury\TMP # Dir. for pending 'notify' commands
[MercuryH]
logfile : C:\Program Files\MERCURY\Logs\MercuryH\~y-~m-~d.log # Traffic logging file
Timeout : 30
[MercuryI]
Scratch : C:\Program Files\MERCURY\Scratch\MercuryI
Logfile : C:\Program Files\MERCURY\Logs\MercuryI\~y-~m-~d.log
Timeout : 120
Server_Port : 143
SSL_Port: 993
Charset : ISO-8859-1
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryI
Session_logmode : 0
Idle_Timeout : 1800
SSL_Mode : 0
Login_Disabled : 0
[MercuryB]
Scratch : C:\Program Files\MERCURY\Scratch\MercuryB
Logfile : C:\Program Files\MERCURY\Logs\MercuryB\~y-~m-~d.log
Timeout : 120
Server_Port : 80
Session_logging : C:\Program Files\MERCURY\Sessions\MercuryB
Session_logmode : 0
Idle_Timeout : 1800
SSL_Mode : 0
Alt_Server_Port : 443
[Groups]
[Rewrite]
[Statistics]
StatFlags: 0 # Statistical reporting settings
STM_Hours: 24 # How often to e-mail stat log files
<P>Thanks</P>
<P mce_keep="true">Just a thought, is it possible that MS objects to the same ip address for two host names?&nbsp; No one else does so far as I can tell.</P>
<P mce_keep="true">Here is the smtp log and the mercury.ini file</P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>SMTP Log:</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>1 mail sent from hotmail to </FONT><A href="mailto:james.parker@bishopsstortford.org" mce_href="mailto:james.parker@bishopsstortford.org"><FONT color=#0000ff face=Verdana>james.parker@bishopsstortford.org</FONT></A><FONT face=Verdana> (received)</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>1 mail sent from hotmail to </FONT><A href="mailto:james.parker@bishopsstortfordtc.gov.uk" mce_href="mailto:james.parker@bishopsstortfordtc.gov.uk"><FONT color=#0000ff face=Verdana>james.parker@bishopsstortfordtc.gov.uk</FONT></A><FONT face=Verdana> (not received)</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>1 mail sent from hotmail to both (received on bishopsstortford.org only</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p><FONT face=Verdana>&nbsp;</FONT></o:p></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><B style="mso-bidi-font-weight: normal"><o:p><FONT face=Verdana>&nbsp;</FONT></o:p></B></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>0420 4cc30ec2 Connection from 65.55.90.96</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180420 4cc30ec2 EHLO snt0-omc2-s21.snt0.hotmail.com</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180421 4cc30ec2 MAIL FROM:&lt;james.parker.bstc@hotmail.com&gt;</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180421 4cc30ec2 RCPT TO:&lt;james.parker@bishopsstortford.org&gt;</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180421 4cc30ec2 DATA</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180421 4cc30ec2 DATA - 46 lines, 1188 bytes.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180422 4cc30ec2 QUIT</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180422 4cc30ec2 Connection closed with 65.55.90.96, 2 sec. elapsed.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180522 4cc30ec3 Connection from 109.86.89.143</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180522 4cc30ec3 HELO arscomp</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180522 4cc30ec3 MAIL FROM: &lt;tic@bishopsstortford.org&gt;</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180523 4cc30ec3 RCPT TO: &lt;tic@bishopsstortford.org&gt;</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180523 4cc30ec3 DATA</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>X 20101023 180523 4cc30ec3 'Viagra' encountered in subject line - connection dropped.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180523 4cc30ec3 Connection closed with 109.86.89.143, 1 sec. elapsed.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180654 4cc30ec4 Connection from 65.54.61.95</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180654 4cc30ec4 EHLO snt0-omc2-s44.snt0.hotmail.com</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180655 4cc30ec4 MAIL FROM:&lt;james.parker.bstc@hotmail.com&gt;</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180655 4cc30ec4 RCPT TO:&lt;james.parker@bishopsstortford.org&gt;</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180655 4cc30ec4 DATA</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180655 4cc30ec4 DATA - 47 lines, 1243 bytes.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180655 4cc30ec4 QUIT</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>T 20101023 180655 4cc30ec4 Connection closed with 65.54.61.95, 1 sec. elapsed.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><o:p><FONT face=Verdana>&nbsp;</FONT></o:p></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>MERCURY.INI generated by Mercury Setup</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Sample Bindery Mode / Standalone Mode MERCURY.INI file.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>This sample file implements most of the possible switches for each</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>module, but you can edit it to do less if you wish.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Anything after a '#' to the end of the line is a comment and</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>is stripped out before parsing. Trailing and leading whitespace</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>is also stripped before parsing. Many sample commands have been</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>left in this file commented out for reference purposes.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Note that in general, manual modification of this file is NOT</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>RECOMMENDED - use the Mercury "Configuration" menu to change the</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>#<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>program's settings wherever possible.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[General]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>myname:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>mail.bishopsstortfordtc.gov.uk<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Canonical name for this server</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>timezone:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>+0000<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Time Zone to add to date fields</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>file_api:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Use the file api instead of queues</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>mailqueue:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>D:\MERCURY\QUEUE<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Where mail should be put for delivery</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>smtpqueue:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>D:\MERCURY\QUEUE<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Where the SMTP client should look for mail</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>newmail_path:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>D:\MERCURY\MAIL\~N<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Where to find the users' WinPMail mailboxes.</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Protocols]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>C:\Program Files\MERCURY\mercurys.dll</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>C:\Program Files\MERCURY\mercurye.dll</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>C:\Program Files\MERCURY\mercuryp.dll</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>C:\Program Files\MERCURY\mercuryd.dll</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>C:\Program Files\MERCURY\mercuryi.dll</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>C:\Program Files\MERCURY\mercuryb.dll</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Mercury]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>failfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\FAILURE.MER<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Delivery failure notification template</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>confirmfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\CONFIRM.MER<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Delivery confirmation template</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>aliasfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\ALIAS.MER<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># System-wide alias file</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>synfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\SYNONYM.MER<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># User synonym database</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>listfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\LISTS.MER<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># List of lists</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>logfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Logs\Core\~y-~m-~d.log<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Traffic logging file</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>logwidth:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>30<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Width of address fields in logfile</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>retpath:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Do/Don't use 'return-path' for errors</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>maxhops:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>30<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Used to detect mailing loops</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>gullible:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, don't validate 'From' fields</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>poll:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>60<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Seconds between queue polling cycles</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>scratch:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Scratch<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Where we can write temp files</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>returnlines:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>15<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># How many lines of failed messages to return</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>postmaster:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>Admin<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># NetWare UIC of postmaster</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>broadcast:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Yes, we want broadcast notifications, but</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>receipts:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># ... no broadcasts for receipt confirmations</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>PM_notify:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Do/Don't send errors to the postmaster</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>change_owner:<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Change message ownership to recipient</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>hard_quit:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>49<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, quit only on Ctrl+File|Exit</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>auto_tzone:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, obtain timezone information from OS</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>LogLevel:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>15<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># System message reporting level</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>LogMax:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>100<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Maximum number of system messages to store</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>RetryPeriod:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>10<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Period between job retries (minutes)</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>MaxRetries:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>16<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Maximum number of times a job can fail</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>TwoPasses:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, process submission queue in 2 passes</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Autoaddress:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, auto-generate user addresses based on name</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Daily_exit:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, auto-restart each day after maintenance</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>No_Areply:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, disable automatic replies system-wide</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Alt_Forward:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, allow alternate forwarding specification</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Maint_hour:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>23<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Hour for daily maintenance (24-hour clock)</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Maint_min:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Minute for daily maintenance</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Retry_Mode:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, use progressive backoff for queue retries</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Local_DSNs:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ generate Delivery Status for local users only</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>DSN_time1:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>10800<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Seconds deferred before first DSN is sent</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>DSN_time2:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>86400<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Seconds deferred before second DSN is sent</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>DSN_time3:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>259200<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Seconds deferred before third DSN is sent</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Host_in_title: 0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># If NZ, show hostname in system tray and taskbar</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Lingering:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Enable or disable 'lingering mailboxes'</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Linger_Timeout: 60<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Seconds before a lingering mailbox is shut down</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Alert_Host:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>notify.pmail.com<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Host to check for licensee advisories</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Alert_Interval: 720<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Frequency in minutes (min 240) for checks</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Alert_Flags:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>3<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Flags controlling advisory checks</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryC]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>logfile : C:\Program Files\MERCURY\Logs\MercuryC\~y-~m-~d.log<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Traffic logging file</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryC\<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN># Directory for session log files</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logmode : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>host:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN># mail mail host which relays for us</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>scratch:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\scratch<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;</SPAN># Where we can write temp files</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>poll:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>30<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN># Seconds between queue polling cycles</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>returnlines: 15<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN># How many lines of failed messages to return</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>failfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\FAILURE.MER<SPAN style="mso-spacerun: yes">&nbsp; </SPAN># Delivery failure template</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>esmtp:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN># Yes, we want to use ESMTP extensions</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryE]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>HELO : mail.bishopsstortfordtc.gov.uk</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryE</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logmode : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Poll : 15</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Timeout : 60</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Nameservers : 192.168.1.254</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Logfile : C:\Program Files\MERCURY\Logs\MercuryE\~y-~m-~d.log</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Log_Verbose : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>DNS_Timeout : 60</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>DNS_Retries : 4</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Transcripts : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>MaxThreads : 10</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryD]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Scratch : C:\Program Files\MERCURY\Scratch\MercuryD</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Timeout : 30</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Poll : 30</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryD</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryS]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Debug : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>HELO : mail.bishopsstortfordtc.gov.uk on oak</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Logfile : C:\Program Files\MERCURY\Logs\MercuryS\~y-~m-~d.log</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Relay : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Strict_Relay : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>8BitMime : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Allow_Illegals : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>SMTP_Authentication : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Killfile : c:\program files\mercury\sender.kfl</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryS</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Compliance_Settings : 292</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Maximum_Failed_Rcpts : 4</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Max_Relay_Attempts : 2</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>SSL_Mode : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>ST_Blacklisting : 288</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>No_VRFY : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>SMTP_ConnFlags : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryP]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Scratch : C:\Program Files\MERCURY\Scratch\MercuryP</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Logfile : C:\Program Files\MERCURY\Logs\MercuryP\~y-~m-~d.log</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Stack : 32768</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Mark_Read : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Login_Disabled : 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>UIDL_nul_list : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>New_UIDs : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>No_NUL_passwords : 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryP</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryX]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Drain_queues: 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Cmd_Delay: 10</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Cmd_Wait: 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># IE4_Dialling: 0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Use_ETRN: 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Clients_only: 1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Sunday: 0800,1800,3,15,30,60</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Monday: 0830,2100,5,15,60,60</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Tuesday: 0830,2100,5,15,60,60</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Wednesday: 1500,1900,2,30,5,30</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Thursday: 0900,1900,2,30,0,0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Friday: 0830,2100,5,15,60,60</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Saturday: 1031,1035,2,45,-1,0</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># [Groups]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># testgroup<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>TESTGRP</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Domains]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>bishopsstortfordtc: bishopsstortfordtc.gov.uk</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>bishopsstortfordtc: [192.168.1.19]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>bishopsstortfordtc: bishopsstortford.org</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Maiser]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Maiser:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Maiser<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># 'Username' of mail server account</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Helpfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\MAISER.HLP<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Help sent on failed maiser requests</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Lookupfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\MAISER.LKP<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Format file for the 'lookup' command</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Send_dir:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\SENDABLE<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Directory for the 'send' command</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Logfile:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</SPAN>C:\Program Files\MERCURY\Logs\Maiser\~y-~m-~d.LOG<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Mail server log file</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Notify:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>C:\Program Files\MERCURY\Mercury\TMP<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Dir. for pending 'notify' commands</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>NoList:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>N<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># If 'Y', disable the 'list' command</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Local_only:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Y<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># If 'Y', local 'notify' commands only</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryH]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>logfile : C:\Program Files\MERCURY\Logs\MercuryH\~y-~m-~d.log<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN># Traffic logging file</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Addressbook : \\CLIO\SYS\SYSTEM\MERCURY\PH.PMR</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># MOTD : \\CLIO\SYS\SYSTEM\MERCURY\PH-MOTD.TXT</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana># Administrator : postmaster@clio.pmail.gen.nz</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryI]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Scratch : C:\Program Files\MERCURY\Scratch\MercuryI</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Logfile : C:\Program Files\MERCURY\Logs\MercuryI\~y-~m-~d.log</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Timeout : 120</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Server_Port : 143</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>SSL_Port: 993</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Charset : ISO-8859-1</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryI</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Idle_Timeout : 1800</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[MercuryB]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Scratch : C:\Program Files\MERCURY\Scratch\MercuryB</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Logfile : C:\Program Files\MERCURY\Logs\MercuryB\~y-~m-~d.log</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Server_Port : 80</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Session_logging : C:\Program Files\MERCURY\Sessions\MercuryB</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>Alt_Server_Port : 443</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Groups]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Rewrite]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>[Statistics]</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>StatFlags:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>0<SPAN style="mso-spacerun: yes">&nbsp; </SPAN># Statistical reporting settings</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>STF_Hours:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>24<SPAN style="mso-spacerun: yes">&nbsp; </SPAN># How often to write stat log files</FONT></P>
<P style="MARGIN: 0cm 0cm 0pt; tab-stops: 54.0pt" class=MsoNormal><FONT face=Verdana>STM_Hours:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>24<SPAN style="mso-spacerun: yes">&nbsp; </SPAN># How often to e-mail stat log files</FONT></P>
<P mce_keep="true">&nbsp;</P>
