Hi Thomas,
Thank you for your help.
First I would like to say that now I can send emails with Mercury.
T - This also means you cannot use MercuryE to send the mail since you do not have a fixed IP address, domain name and PTR record for the system running Mercury.
D - I can use from my PC two options of communication. One through celluar modem to ISP. Second (but not in parallel) is my connection to the local network.
When I used option one I utilized MercuryE and it worked nicely. The Name servers input was left empty.
When I wanted to work inside my network, in MercuryE there was an error which said (in general): can not resolve the "domain" (myname@domain), so I cuntinued with your recommendation and I transfered to MercuryC.
In the definition for the Smart host name i entered the mail server IP, and I had to enter my user name and password for authontication. Now MercuryC worked as well.
When I operated MercuryC and left Smart host name empty the program crashed. The site does not permit me to upload the printscreen of the crush, and I did not find any dump file to upload.
I think mercury should be notified about the bug (should be easy to correct).
Thank you agin
David
<P>Hi Thomas,</P>
<P>Thank you for your help.</P>
<P>First I would like to say that now I can send emails with Mercury.</P>
<P>T - This also means you cannot use MercuryE to send the mail since you do not have a fixed IP address, domain name and PTR record for the system running Mercury.</P>
<P>D - I can use from my PC&nbsp;two options of communication. One through celluar modem to ISP. Second (but not in parallel) is my connection to the local network.</P>
<P>When I used&nbsp;option one I utilized&nbsp;MercuryE and it&nbsp;worked nicely. The Name servers&nbsp;input was left empty.&nbsp;</P>
<P>When I wanted to work inside my network, in MercuryE there was an error which said (in general): can not resolve the "domain" (<A href="mailto:myname@domain">myname@domain</A>), so I cuntinued with your recommendation and I transfered to MercuryC.</P>
<P>In the definition for the Smart host name&nbsp;i entered&nbsp;the mail server IP, and I had to enter my user name and password for authontication. Now MercuryC worked as well.</P>
<P>When I operated MercuryC&nbsp;and left&nbsp;Smart host name&nbsp;empty the program crashed. The site does not permit me to upload the printscreen of the crush, and I did not find any dump file to upload.</P>
<P>I think mercury should be notified about the bug (should be easy to correct).</P>
<P>&nbsp;Thank you agin</P>
<P>David</P>
