Hi
Can anyone help explain this, please?
One of our staff uses a distribution list to email newsletters to a small group of people. The newsletter will usually contain a c. 2MB PDF attachment.
Sometimes, recipients will receive more than one copy of the message. One person received 5 copies of the same message. I contacted this person and sent a test message with a 2.2MB attachment (a BMP) and the receipient recieved 2 copies:
Mercury Log
O 20101111 1549 MG00041E greenman@lincsheritage.org recipient@aol.co.uk 3131366
Connection Log
15:50:10.402: --- Thu Nov 11 15:50:10 2010 ---
15:50:10.417: Connect to 'cluster8out.eu.messagelabs.com', timeout 30.
15:50:11.416: >> 220 server-15.tower-169.messagelabs.com ESMTP<cr><lf>
15:50:11.416: << EHLO apsarchaeology.co.uk<cr><lf>
15:50:11.463: >> 250-server-15.tower-169.messagelabs.com<cr><lf>
15:50:11.463: >> 250-STARTTLS<cr><lf>
15:50:11.463: >> 250-PIPELINING<cr><lf>
15:50:11.463: >> 250 8BITMIME<cr><lf>
15:50:11.463: << MAIL FROM:<greenman@lincsheritage.org><cr><lf>
15:50:11.541: >> 250 OK<cr><lf>
15:50:11.541: << RCPT TO:<recipient@aol.co.uk><cr><lf>
15:50:11.587: >> 250 OK<cr><lf>
15:50:11.587: << DATA<cr><lf>
15:50:11.619: >> 354 go ahead<cr><lf>
15:50:11.619: << Received: from Spooler by apsarchaeology.co.uk (Mercury/32 v4.62) ID MO00041F;<cr><lf> 11 Nov 2010 15:50:11 -0000<cr><lf>
15:50:11.619: << Received: from spooler by apsarchaeology.co.uk (Mercury/32 v4.62); 11 Nov 2010 15:49:40 -0000<cr><lf>
15:50:11.619: << From: "Greenman" <greenman@lincsheritage.org><cr><lf>
15:50:11.634: << To: recipient@aol.co.uk<cr><lf>
15:50:11.634: << Date: Thu, 11 Nov 2010 15:49:12 -0000<cr><lf>
15:50:11.634: << MIME-Version: 1.0<cr><lf>
15:50:11.634: << Content-type: Multipart/Mixed; boundary=Message-Boundary-14850<cr><lf>
15:50:11.634: << Subject: [HTL-Test] #1 Attachment 2MB<cr><lf>
15:50:11.634: << Message-ID: <4CDC1078.15783.34B47219@greenman.lincsheritage.org><cr><lf>
15:50:11.634: << Priority: normal<cr><lf>
15:50:11.634: << X-mailer: Pegasus Mail for Windows (4.52)<cr><lf>
15:50:11.634: << <cr><lf>
15:50:11.634: << --Message-Boundary-14850<cr><lf>
15:50:11.634: << Content-type: Multipart/Alternative; boundary="Alt-Boundary-24411.884240921"<cr><lf>
15:50:11.634: << --Alt-Boundary-24411.884240921<cr><lf>
15:50:11.634: << Content-type: text/plain; charset=US-ASCII<cr><lf>
15:50:11.634: << Content-transfer-encoding: 7BIT<cr><lf>
15:50:11.634: << Content-description: Mail message body<cr><lf>
15:50:11.634: << Many thanks. I appreciate your help with this.<cr><lf>
15:50:11.634: << Test message with a 2.2MB attachment.<cr><lf>
15:50:11.634: << Please let me know how many copies you have received.<cr><lf>
15:50:11.634: << Thanks<cr><lf>
15:50:11.634: << Greenman<cr><lf>
15:50:11.634: << --<cr><lf>
~~~~~~~~~~~~~~~~~My Signature~~~~~~~~~~~~~~~~~
15:50:11.650: << <cr><lf>
15:50:11.650: << --Alt-Boundary-24411.884240921<cr><lf>
15:50:11.650: << Content-type: text/html; charset=US-ASCII<cr><lf>
15:50:11.650: << Content-transfer-encoding: 7BIT<cr><lf>
15:50:11.650: << Content-description: Mail message body<cr><lf>
15:50:11.650: << <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"<cr><lf>
15:50:11.650: << "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><cr><lf>
15:50:11.650: << <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head><cr><lf>
15:50:11.650: << <title></title><cr><lf>
~~~~~~~~~~~~~~~~~HTML Version of message~~~~~~~~~~~~~~~~~
15:50:11.681: << </html><cr><lf>
15:50:11.681: << <cr><lf>
15:50:11.681: << --Alt-Boundary-24411.884240921--<cr><lf>
15:50:11.681: << --Message-Boundary-14850<cr><lf>
15:50:11.681: << Content-type: text/plain; charset=US-ASCII<cr><lf>
15:50:11.681: << Content-disposition: inline<cr><lf>
15:50:11.681: << Content-description: Attachment information.<cr><lf>
15:50:11.681: << The following section of this message contains a file attachment<cr><lf>
15:50:11.681: << prepared for transmission using the Internet MIME message format.<cr><lf>
15:50:11.681: << If you are using Pegasus Mail, or any other MIME-compliant system,<cr><lf>
15:50:11.681: << you should be able to save it or view it from within your mailer.<cr><lf>
15:50:11.681: << If you cannot, please ask your system administrator for assistance.<cr><lf>
15:50:11.681: << ---- File information -----------<cr><lf>
15:50:11.681: << File: dcadarrow.bmp<cr><lf>
15:50:11.681: << Date: 17 Oct 2005, 10:55<cr><lf>
15:50:11.681: << Size: 2279478 bytes.<cr><lf>
15:50:11.681: << Type: BMP-image<cr><lf>
15:50:11.681: << Content-type: Application/Octet-stream; name="dcadarrow.bmp"; type=BMP-image<cr><lf>
15:50:11.697: << Content-disposition: attachment; filename="dcadarrow.bmp"<cr><lf>
15:50:11.697: << Content-transfer-encoding: BASE64<cr><lf>
15:50:11.697: << <cr><lf>
15:50:11.697: << Qk02yCIAAAAAADYAAAAoAAAAAAQAAOYCAAABABgAAAAAAADIIgAAAAAAAAAAAAAAAAAAAAAA<cr><lf>
15:50:11.697: << rOfMj+myj+myj+myj+qwj+myj+myj+myj+myj+myj+myj+myj+mtj+mtj+myj+myj+mtj+my<cr><lf>
15:50:11.697: << j+myj+mtj+myj+mtj+myj+mtj+myj+mtj+myj+myj+mtj+qwj+mtj+myj+qwj+mtj+myj+my<cr><lf>
~~~~~~~~~~~~~~~~~Attachment Data~~~~~~~~~~~~~~~~~
15:51:52.364: << fmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZm<cr><lf>
15:51:52.364: << fmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZm<cr><lf>
15:51:52.364: << <cr><lf>
15:51:52.364: << --Message-Boundary-14850--<cr><lf>
15:51:52.364: << .<cr><lf>
15:51:52.598: >> 250 ok 1289490712 qp 15806 server-15.tower-169.messagelabs.com!1289490610!46497168!1<cr><lf>
15:51:52.614: << QUIT<cr><lf>
15:51:52.645: >> 221 server-15.tower-169.messagelabs.com<cr><lf>
15:51:52.645: --- Connection closed normally at Thu Nov 11 15:51:52 2010. ---
Now, I can see that the message was successfully delivered to MessageLabs and will contact them to see if they might be able to explain what is causing this. However, I would appreciate a 'second opinion' so if anyone has encountered this before and is aware of any conditions that can cause this I would appreciate it if you could reply. I have asked the recipient for an alternative address (non AOL), to email further test messages but have yet to receive a reply.
Many thanks.
<P>Hi</P>
<P>Can anyone help explain this, please?</P>
<P>One of our staff uses a distribution list to email newsletters to a small group of people. The newsletter will usually contain a <EM>c.</EM> 2MB PDF attachment.</P>
<P>Sometimes, recipients will receive more than one copy of the message. One person received 5 copies of the same message. I contacted this person and sent a test message with a 2.2MB attachment (a BMP) and the receipient recieved 2 copies:</P>
<P mce_keep="true">&nbsp;</P>
<P>Mercury Log</P>
<P>O 20101111 1549 MG00041E greenman@lincsheritage.org&nbsp; recipient@aol.co.uk&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 3131366</P>
<P>Connection Log
15:50:11.416: &gt;&gt; 220 server-15.tower-169.messagelabs.com ESMTP&lt;cr&gt;&lt;lf&gt;
15:50:11.416: &lt;&lt; EHLO apsarchaeology.co.uk&lt;cr&gt;&lt;lf&gt;
15:50:11.463: &gt;&gt; 250-server-15.tower-169.messagelabs.com&lt;cr&gt;&lt;lf&gt;
15:50:11.463: &gt;&gt; 250-STARTTLS&lt;cr&gt;&lt;lf&gt;
15:50:11.463: &gt;&gt; 250-PIPELINING&lt;cr&gt;&lt;lf&gt;
15:50:11.463: &gt;&gt; 250 8BITMIME&lt;cr&gt;&lt;lf&gt;
15:50:11.463: &lt;&lt; MAIL FROM:&lt;greenman@lincsheritage.org&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.541: &gt;&gt; 250 OK&lt;cr&gt;&lt;lf&gt;
15:50:11.541: &lt;&lt; RCPT TO:&lt;recipient@aol.co.uk&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.587: &gt;&gt; 250 OK&lt;cr&gt;&lt;lf&gt;
15:50:11.587: &lt;&lt; DATA&lt;cr&gt;&lt;lf&gt;
15:50:11.619: &gt;&gt; 354 go ahead&lt;cr&gt;&lt;lf&gt;
15:50:11.619: &lt;&lt; Received: from Spooler by apsarchaeology.co.uk (Mercury/32 v4.62) ID MO00041F;&lt;cr&gt;&lt;lf&gt;&nbsp; 11 Nov 2010 15:50:11 -0000&lt;cr&gt;&lt;lf&gt;
15:50:11.619: &lt;&lt; Received: from spooler by apsarchaeology.co.uk (Mercury/32 v4.62); 11 Nov 2010 15:49:40 -0000&lt;cr&gt;&lt;lf&gt;
15:50:11.619: &lt;&lt; From: "Greenman" &lt;greenman@lincsheritage.org&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; To: recipient@aol.co.uk&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Date: Thu, 11 Nov 2010 15:49:12 -0000&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; MIME-Version: 1.0&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Content-type: Multipart/Mixed; boundary=Message-Boundary-14850&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Subject: [HTL-Test] #1 Attachment 2MB&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Message-ID: &lt;4CDC1078.15783.34B47219@greenman.lincsheritage.org&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Priority: normal&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; X-mailer: Pegasus Mail for Windows (4.52)&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; --Message-Boundary-14850&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Content-type: Multipart/Alternative; boundary="Alt-Boundary-24411.884240921"&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; --Alt-Boundary-24411.884240921&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Content-type: text/plain; charset=US-ASCII&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Content-transfer-encoding: 7BIT&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Content-description: Mail message body&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Many thanks. I appreciate your help with this.&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Test message with a 2.2MB attachment.&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Please let me know how many copies you have received.&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Thanks&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; Greenman&lt;cr&gt;&lt;lf&gt;
15:50:11.634: &lt;&lt; --&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; --Alt-Boundary-24411.884240921&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; Content-type: text/html; charset=US-ASCII&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; Content-transfer-encoding: 7BIT&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; Content-description: Mail message body&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; &lt;!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; &lt;html&nbsp; xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"&gt;&lt;head&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.650: &lt;&lt; &lt;title&gt;&lt;/title&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; &lt;/html&gt;&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; --Alt-Boundary-24411.884240921--&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; --Message-Boundary-14850&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; Content-type: text/plain; charset=US-ASCII&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; Content-disposition: inline&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; Content-description: Attachment information.&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; The following section of this message contains a file attachment&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; prepared for transmission using the Internet MIME message format.&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; If you are using Pegasus Mail, or any other MIME-compliant system,&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; you should be able to save it or view it from within your mailer.&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; If you cannot, please ask your system administrator for assistance.&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt;&nbsp;&nbsp;&nbsp; ---- File information -----------&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; File:&nbsp; dcadarrow.bmp&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Date:&nbsp; 17 Oct 2005, 10:55&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Size:&nbsp; 2279478 bytes.&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Type:&nbsp; BMP-image&lt;cr&gt;&lt;lf&gt;
15:50:11.681: &lt;&lt; Content-type: Application/Octet-stream; name="dcadarrow.bmp"; type=BMP-image&lt;cr&gt;&lt;lf&gt;
15:50:11.697: &lt;&lt; Content-disposition: attachment; filename="dcadarrow.bmp"&lt;cr&gt;&lt;lf&gt;
15:50:11.697: &lt;&lt; Content-transfer-encoding: BASE64&lt;cr&gt;&lt;lf&gt;
15:50:11.697: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
15:50:11.697: &lt;&lt; Qk02yCIAAAAAADYAAAAoAAAAAAQAAOYCAAABABgAAAAAAADIIgAAAAAAAAAAAAAAAAAAAAAA&lt;cr&gt;&lt;lf&gt;
15:50:11.697: &lt;&lt; rOfMj+myj+myj+myj+qwj+myj+myj+myj+myj+myj+myj+myj+mtj+mtj+myj+myj+mtj+my&lt;cr&gt;&lt;lf&gt;
15:50:11.697: &lt;&lt; j+myj+mtj+myj+mtj+myj+mtj+myj+mtj+myj+myj+mtj+qwj+mtj+myj+qwj+mtj+myj+my&lt;cr&gt;&lt;lf&gt;</P>
<P>~~~~~~~~~~~~~~~~~Attachment Data~~~~~~~~~~~~~~~~~</P>
<P>15:51:52.364: &lt;&lt; fmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZm&lt;cr&gt;&lt;lf&gt;
15:51:52.364: &lt;&lt; fmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZmfmZm&lt;cr&gt;&lt;lf&gt;
15:51:52.364: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
15:51:52.364: &lt;&lt; --Message-Boundary-14850--&lt;cr&gt;&lt;lf&gt;
15:51:52.364: &lt;&lt; .&lt;cr&gt;&lt;lf&gt;
15:51:52.598: &gt;&gt; 250 ok 1289490712 qp 15806 server-15.tower-169.messagelabs.com!1289490610!46497168!1&lt;cr&gt;&lt;lf&gt;
15:51:52.614: &lt;&lt; QUIT&lt;cr&gt;&lt;lf&gt;
15:51:52.645: &gt;&gt; 221 server-15.tower-169.messagelabs.com&lt;cr&gt;&lt;lf&gt;
15:51:52.645: --- Connection closed normally at Thu Nov 11 15:51:52 2010. ---</P>
<P>Now, I can see that the message was successfully delivered to MessageLabs and will contact them to see if they might be able to explain what is causing this. However, I would appreciate a 'second opinion' so if anyone has encountered this before and is aware of any conditions that can cause this I would appreciate it if you could reply. I have asked the recipient for an alternative address (non AOL),&nbsp;to email further test messages but have yet to receive a reply.</P>
<P>Many thanks.</P>
