Mercury Modules Offline
Disable MercuryX unless you actually use it. If you use it you will need to download this patch:
http://community.pmail.com/files/folders/patches/entry24194.aspx
<p>Disable MercuryX unless you actually use it. If you use it you will need to download this patch:</p><p>http://community.pmail.com/files/folders/patches/entry24194.aspx</p><p>/Rolf </p>
My problem is the following:
I start Mercury, and i have to go into Offline mode and exit again in order to get the modules S and C online, how can i avoid having to do this everytime i start up mercury?
I saw a post about this, but it wasn't answered and its from 2 years ago, so i post a new one.
Thank you very much ;)
<p>My problem is the following:</p><p>I start Mercury, and i have to go into Offline mode and exit again in order to get the modules S and C online, how can i avoid having to do this everytime i start up mercury?</p><p>I saw a post about this, but it wasn't answered and its from 2 years ago, so i post a new one. </p><p> </p><p>Thank you very much ;) </p>
