Date problems and recurring folder index issues
> I have been using pmail for years, but recently have encountered two problems.  The first is that in the date time column for sorting
> messages, every e-mail received since the beginning of the month is listed as January 11.  The second is that most of the time after
> moving messages to a folder, I can no longer access that folder without having to first reindex or in many cases, reindex, close the
> program and reopen it.  Any suggestions would be greatly appreciated.
> Thanks.
1.  Move all the messages you want to save to a temp folder and delete all the messages in the original folder.
2.  Use the right click "recover deleted space" to remove all messages from the folder.
3.  If step 2 works then simply move all of the messages from the temp folder back to the original folder and delete the temp folder.
4.  If step 2 fails then delete the original folder and rename the temp folder to match the original name.  Reset any filter pointing to this folder.
> I have been using pmail for years, but recently have encountered two problems.  The first is that in the date time column for sorting > messages, every e-mail received since the beginning of the month is listed as January 11.  The second is that most of the time after > moving messages to a folder, I can no longer access that folder without having to first reindex or in many cases, reindex, close the > program and reopen it.  Any suggestions would be greatly appreciated. > Thanks. 1.  Move all the messages you want to save to a temp folder and delete all the messages in the original folder. 2.  Use the right click "recover deleted space" to remove all messages from the folder. 3.  If step 2 works then simply move all of the messages from the temp folder back to the original folder and delete the temp folder. 4.  If step 2 fails then delete the original folder and rename the temp folder to match the original name.  Reset any filter pointing to this folder.
I have been using pmail for years, but recently have encountered two problems.  The first is that in the date time column for sorting messages, every e-mail received since the beginning of the month is listed as January 11.  The second is that most of the time after moving messages to a folder, I can no longer access that folder without having to first reindex or in many cases, reindex, close the program and reopen it.  Any suggestions would be greatly appreciated.  Thanks.
Never mind the date problem.  I fixed that.  However, folder indexing issue is real pain.  Thanks.
