After using pegasus for many years with no problems, I've upgraded to 4.52. We are receiving messages that are total garbage, primarily from one customer - but not all the time. Going thru the source, it seems that the problem messages use UTF-8 encoding. Messages that use other character sets are no problem so far. So, I changed my prog to use UTF-8, at least outgoing (couldn't find any other settings to change) and messages from one of my contacts started coming through properly. I just got another one, from someone else using UTF-8, total garbage again. They are readable if I log into my mail server (ISP webmail access) so the problem seems to be at this end. I've run out of ideas. I even got one message that was half readable, half garbage.
help???
<p>After using pegasus for many years with no problems, I've upgraded to 4.52. We are receiving messages that are total garbage, primarily from one customer - but not all the time. Going thru the source, it seems that the problem messages use UTF-8 encoding. Messages that use other character sets are no problem so far. So, I changed my prog to use UTF-8, at least outgoing (couldn't find any other settings to change) and messages from one of my contacts started coming through properly. I just got another one, from someone else using UTF-8, total garbage again. They are readable if I log into my mail server (ISP webmail access) so the problem seems to be at this end. I've run out of ideas. I even got one message that was half readable, half garbage.</p><p>help???</p><p>&nbsp;</p>
