First well done the the beta team for all the work on the upgrade [:)]
Maybe I didn't post this in the correct place
But I have come across a small problem I have not been able to work around.
OK well as I described yesterday the 4.61 worked well when installed last night on 32 and 64 bit win 7
This was as stanadlone machines where files were on the local drive.
Today I upgraded a small office network.Here the files, both programme and mail folders are on a file server.
All 32 bit systems work as expected.
However our 64bit machines ( We have 3 ) both win 7 (2) and visa (1) have an identical problem.
After upgrade on the file server each local machine ran the wssetup file to set the parametes
However
when you try to start the progamme over the network, ( put in your
username and wait etc.) it gets to a point where it is above to load (
we have pubic folders so this take a min or two). the programe then
crashes with the single windows error message .
( Pegasus mail
for windows has stopped working....A problem caused the progamme to stop
working correctly....windows will close the programme ....and notify
you if a solution is available )
Next on the same 64bit win7 machines I installed a separate new local copy of Pegasus, this worked fine
from the new local copy I was going to try to reconfigure the setting
so it could assess the network files but of course you cant do this
because the pconig and mbxmain won't run on a 64 bit machine so that
option is out
so I guess I am asking any ideas on how to get Pegasus 4.61 to work over a network on 64bit
Note 4.52 was working fine with our system
The setup is
Remote drive\Pmail\Programme( for the programme files )
Remote drive\Pmail\Mail ( for all our mailboxes and public folders )
Ideas would be most welcome
<p>&nbsp;First well done the the beta team for all the work on the upgrade&nbsp; [:)]</p><p>&nbsp;
</p><p>Maybe I didn't post this in the correct place</p><p>&nbsp;</p><p>But I have come across a small problem I have not&nbsp; been able to work around.
</p><p>OK well as I described yesterday the 4.61 worked well when installed last night on 32 and 64 bit win 7 </p><p>This was as stanadlone machines&nbsp; where files were on the local drive.</p><p>Today I upgraded a small office network.Here the files, both programme and mail folders are on a file server.</p><p>All 32 bit systems work as expected.</p><p>However our 64bit machines ( We have 3 ) both win 7 (2) and visa (1) have an identical&nbsp; problem.</p><p>After upgrade on the file server each local machine ran the wssetup file to set the parametes</p><p>&nbsp;However
crashes with the single windows error message .</p><p>&nbsp;( Pegasus mail
</p><p>&nbsp;Next on the same 64bit win7 machines I installed a separate new&nbsp; local copy of Pegasus,&nbsp; this worked fine </p><p>Next
option is out </p><p>&nbsp;</p><p>so I guess I am asking any ideas on how to get Pegasus 4.61 to work over a network on 64bit&nbsp;</p><p>Note 4.52 was working fine with our system</p><p>The setup is</p><p>Remote drive\Pmail\Programme( for the programme files )
</p><p>Remote drive\Pmail\Mail&nbsp; ( for all our mailboxes and public folders )</p><p>&nbsp;</p><p>Ideas would be most welcome
</p><p>&nbsp;</p><p>&nbsp;</p>
