IERender and IE9 dont work toge
After I installed  IE9 Pegasus 4.61 stopped working when I try to view the contents of a message. After I chose not to use IERenderer I can read the contents of messages. I have installed the latest version of IERenderer. It seems as if IERenderer and IE9 and dont work together.
<span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">After</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I installed</span> <span title="Klikk for å vise alternative oversettelser" class="hps"></span><span title="Klikk for å vise alternative oversettelser" class="hps"></span> <span title="Klikk for å vise alternative oversettelser" class="hps">IE9</span> <span title="Klikk for å vise alternative oversettelser" class="hps"></span></span><span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">Pegasus</span> <span title="Klikk for å vise alternative oversettelser" class="hps">4.61 </span></span><span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">stopped</span> <span title="Klikk for å vise alternative oversettelser" class="hps">working</span> <span title="Klikk for å vise alternative oversettelser" class="hps">when</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I</span> try to <span title="Klikk for å vise alternative oversettelser" class="hps">view</span> <span title="Klikk for å vise alternative oversettelser" class="hps">the contents</span> <span title="Klikk for å vise alternative oversettelser" class="hps">of</span> <span title="Klikk for å vise alternative oversettelser" class="hps">a</span> <span title="Klikk for å vise alternative oversettelser" class="hps">message</span><span class="" title="Klikk for å vise alternative oversettelser">.</span> <span title="Klikk for å vise alternative oversettelser" class="hps">After</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I</span> <span title="Klikk for å vise alternative oversettelser" class="hps">chose</span> <span title="Klikk for å vise alternative oversettelser" class="hps">not</span> <span title="Klikk for å vise alternative oversettelser" class="hps">to use</span> <span title="Klikk for å vise alternative oversettelser" class="hps">IERenderer</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I can</span> <span title="Klikk for å vise alternative oversettelser" class="hps">read the</span> <span title="Klikk for å vise alternative oversettelser" class="hps">contents of</span> <span title="Klikk for å vise alternative oversettelser" class="hps">messages</span><span title="Klikk for å vise alternative oversettelser">.</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I have</span> <span title="Klikk for å vise alternative oversettelser" class="hps">installed the</span> <span title="Klikk for å vise alternative oversettelser" class="hps">latest</span> <span title="Klikk for å vise alternative oversettelser" class="hps">version</span> <span title="Klikk for å vise alternative oversettelser" class="hps">of</span> <span title="Klikk for å vise alternative oversettelser" class="hps">IERenderer</span><span title="Klikk for å vise alternative oversettelser">. </span></span><span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">It</span> <span title="Klikk for å vise alternative oversettelser" class="hps">seems</span> <span title="Klikk for å vise alternative oversettelser" class="hps">as</span> <span title="Klikk for å vise alternative oversettelser" class="hps">if</span> <span title="Klikk for å vise alternative oversettelser" class="hps">IERenderer</span> and <span title="Klikk for å vise alternative oversettelser" class="hps">IE9</span> <span title="Klikk for å vise alternative oversettelser" class="hps">and</span> <span title="Klikk for å vise alternative oversettelser" class="hps">dont work</span> <span title="Klikk for å vise alternative oversettelser" class="hps">together. </span></span>
[quote user="kjmork"]It seems as if IERenderer and IE9 and dont work together.[/quote]
I'll look into it when I can afford the time.
<p>[quote user="kjmork"]<span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">It</span> <span title="Klikk for å vise alternative oversettelser" class="hps">seems</span> <span title="Klikk for å vise alternative oversettelser" class="hps">as</span> <span title="Klikk for å vise alternative oversettelser" class="hps">if</span> <span title="Klikk for å vise alternative oversettelser" class="hps">IERenderer</span> and <span title="Klikk for å vise alternative oversettelser" class="hps">IE9</span> <span title="Klikk for å vise alternative oversettelser" class="hps">and</span> <span title="Klikk for å vise alternative oversettelser" class="hps">dont work</span> <span title="Klikk for å vise alternative oversettelser" class="hps">together.</span></span>[/quote]</p><p>I'll look into it when I can afford the time.</p>
I have the same problem - can you give me a hint how to turn off "IRenderer"?
 To turn off IERenderer:
Close all reader windows and the folder manager then click on the IERenderer icon and uncheck "Use IERenderer". BearHTML will take over...
To turn it back on do the same but check "Use IERenderer"
<p> To turn off IERenderer: </p><p>Close all reader windows and the folder manager then click on the IERenderer icon and uncheck "Use IERenderer". BearHTML will take over...</p><p>To turn it back on do the same but check "Use IERenderer" </p>
Please let me know if Bearhtml works ok in this environment too
<p>Please let me know if Bearhtml works ok in this environment too</p><p>Martin </p>
BearHTML seems to work ok here. I use Win7-64bit-SP1, pegasus 4.61 and installed IE9 for testing. After that i was not longer able to see the content in mail messages as long as IERenderer was active.
BearHTML seems to work ok here. I use Win7-64bit-SP1, pegasus 4.61 and installed IE9 for testing. After that i was not longer able to see the <span id="result_box" class="short_text" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">content</span> <span title="Klikk for å vise alternative oversettelser" class="hps">in</span> <span title="Klikk for å vise alternative oversettelser" class="hps">mail</span> <span title="Klikk for å vise alternative oversettelser" class="hps">messages</span> <span title="Klikk for å vise alternative oversettelser" class="hps">as long as IERenderer was active. </span></span>
Same here. Win7, 64bit, SP1, IE9.
Html messages crash pmail in preview mode, after installing final version of the IE9, when IERenderer active. It worked fine with previous versions of IE9 (beta).
BearHTML works fine.
<p>Same here. Win7, 64bit, SP1, IE9. </p><p> </p><p>Html messages crash pmail in preview mode, after installing final version of the IE9, when IERenderer active. It worked fine with previous versions of IE9 (beta).</p><p> </p><p>BearHTML works fine. </p>
Same here, upgraded IERenderer from 2.4.0.3 to 2.4.1.0 but still crashes, also new version has removed vital bits from the toolbar (see JPG)
<p>Same here, upgraded IERenderer from 2.4.0.3 to 2.4.1.0 but still crashes, also new version has removed vital bits from the toolbar (see JPG)</p><p> </p>
[quote user="keithjones"]Same here, upgraded IERenderer from 2.4.0.3 to 2.4.1.0 but still crashes, also new version has removed vital bits from the toolbar (see JPG)[/quote]
Go to Tools => Options => Toolbars and select the POP3 user toolbar style.
<p>[quote user="keithjones"]Same here, upgraded IERenderer from 2.4.0.3 to 2.4.1.0 but still crashes, also new version has removed vital bits from the toolbar (see JPG)[/quote]</p><p>Go to <em>Tools => Options => Toolbars</em> and select the <em>POP3 user</em> toolbar style.</p>
[quote user="philherz"]Anyone know if uninstalling IE9 solves this problem??
Yes, at least in my system.
<p>[quote user="philherz"]Anyone know if uninstalling IE9 solves this problem?? [/quote]</p><p> </p><p>Yes, at least in my system. </p>
[quote user="kjmork"]After I installed  IE9 Pegasus 4.61 stopped working when I try to view the contents of a message.[/quote]
A fix is now available for public testing, it provides some more fixes and enhancements as well, see the development history on the download page.
<p>[quote user="kjmork"]<span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">After</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I installed</span>  <span title="Klikk for å vise alternative oversettelser" class="hps">IE9</span> </span><span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">Pegasus</span> <span title="Klikk for å vise alternative oversettelser" class="hps">4.61 </span></span><span id="result_box" class="" lang="en"><span title="Klikk for å vise alternative oversettelser" class="hps">stopped</span> <span title="Klikk for å vise alternative oversettelser" class="hps">working</span> <span title="Klikk for å vise alternative oversettelser" class="hps">when</span> <span title="Klikk for å vise alternative oversettelser" class="hps">I</span> try to <span title="Klikk for å vise alternative oversettelser" class="hps">view</span> <span title="Klikk for å vise alternative oversettelser" class="hps">the contents</span> <span title="Klikk for å vise alternative oversettelser" class="hps">of</span> <span title="Klikk for å vise alternative oversettelser" class="hps">a</span> <span title="Klikk for å vise alternative oversettelser" class="hps">message</span><span class="" title="Klikk for å vise alternative oversettelser">.</span></span>[/quote]</p><p>A fix is now <a href="/files/folders/community_add-ons_for_pegasus_mail/entry24145.aspx" mce_href="/files/folders/community_add-ons_for_pegasus_mail/entry24145.aspx" target="_blank">available</a> for public testing, it provides some more fixes and enhancements as well, see the development history on the <a href="/files/folders/community_add-ons_for_pegasus_mail/entry24145.aspx" mce_href="/files/folders/community_add-ons_for_pegasus_mail/entry24145.aspx" target="_blank">download page</a>.</p>
