I checked old list messages and Mercury has been adding a Sender header since at least 2004. So if the on behalf text has started to appear recently it's probably because of some change in the mail client software.
There is no setting for including or not including the Sender header, but you could perhaps rename Maiser to ListServer or something similar if that would make more sense. Other than that it would probably be possible to create a daemon to remove Sender headers from list messages.
<p>I checked old list messages and Mercury has been adding a Sender header since at least 2004. So if&nbsp;<span class="Apple-style-span" style="font-family: Tahoma, Arial, Helvetica; ">the on behalf text has started to appear recently it's probably because of some change in the mail client software.</span></p><p>There is no setting for including or not including the Sender header, but you could perhaps rename Maiser to ListServer or something similar if that would make more sense. Other than that it would probably be possible to create a daemon to remove Sender headers from list messages.</p><p>/Rolf&nbsp;</p>
