Problem when quoting an UTF-8 message that contains apostrophes
[quote user="idw"]
You should have mentioned before that this only happens when replying to a selected portion of text: Now I can duplicate it, but only in this case ...
You're right, sorry, I didn't realize that. I always select a part of the message before replying, in order to remove extra signatures.
Sorry again,
<p>[quote user="idw"]</p><p>You should have mentioned before that this only happens when replying to a selected portion of text: Now I can duplicate it, but only in this case ...</p><p>[/quote]</p><p>You're right, sorry, I didn't realize that. I always select a part of the message before replying, in order to remove extra signatures. </p><p>Sorry again, </p>
I noticed a problem when I receive an UTF-8 encoded message that contains apostrophes, sent by Microsoft Windows Live Mail.
For instance, I receive a message that contains the word:
J'ai
In raw view, it's encoded as:
 Content-Type: text/plain;
    charset="utf-8"
Content-Transfer-Encoding: quoted-printable
J=E2=80=99ai
PM displays it properly.
But when I answer the message, and quote the original text, I get:
 > J™ai
whetever the charset I select for my messages.
PM seems to convert it to > J=E2=84=A2ai instead of keeping > J=E2=80=99ai
Does anyone know where it can come from, and how to prevent this?
Thank you,
Olivier
<p>Hello,</p><p>I noticed a problem when I receive an UTF-8 encoded message that contains apostrophes, sent by Microsoft Windows Live Mail. For instance, I receive a message that contains the word:</p><p><b>J'ai</b></p><p>In raw view, it's encoded as:</p><p><b> Content-Type: text/plain;     charset="utf-8" Content-Transfer-Encoding: quoted-printable J=E2=80=99ai</b> </p><p>PM displays it properly. But when I answer the message, and quote the original text, I get:</p><p><b> > J™ai </b></p><p>whetever the charset I select for my messages. PM seems to convert it to <b>> J=E2=84=A2ai</b> instead of keeping <b>> J=E2=80=99ai</b></p><p>Does anyone know where it can come from, and how to prevent this?</p><p>Thank you,</p><p>Olivier </p><p><b></b>   </p>
[quote user="OlivierG"]I noticed a problem when I receive an UTF-8 encoded message that contains apostrophes, sent by Microsoft Windows Live Mail.[/quote]
I can't duplicate this with plain text, are you sure you're not quoting the HTML part that it most certainly contains? Can you please forward this message to beta-reports[at]pmail.gen.nz: Copy it to your new mail folder, then open Help => About Pegasus Mail => Info to check for the New mailbox location, right-click the message in Pegasus Mail's new mail folder and select Message properties which will display the filename (with a CNM extension) at its top, open the respective location in a Windows explorer window and then attach the located CNM file to a message to the above address, preferably zipped.
<p>[quote user="OlivierG"]I noticed a problem when I receive an UTF-8 encoded message that contains apostrophes, sent by Microsoft Windows Live Mail.[/quote]</p><p>I can't duplicate this with plain text, are you sure you're not quoting the HTML part that it most certainly contains? Can you please forward this message to <em>beta-reports[at]pmail.gen.nz</em>: Copy it to your new mail folder, then open <em>Help => About Pegasus Mail => Info</em> to check for the <em>New mailbox location</em>, right-click the message in Pegasus Mail's new mail folder and select <em>Message properties</em> which will display the filename (with a CNM extension) at its top, open the respective location in a Windows explorer window and then attach the located CNM file to a message to the above address, preferably zipped.</p>
I just sent a file that highlights the problem.
Thank you,
Olivier
<p>I just sent a file that highlights the problem.</p><p> </p><p>Thank you,</p><p>Olivier </p>
[quote user="OlivierG"]I just sent a file that highlights the problem.[/quote]
<p>[quote user="OlivierG"]I just sent a file that highlights the problem.[/quote]</p><p>You should have mentioned before that this only happens when replying to a selected portion of text: Now I can duplicate it, but only in this case ...</p>
