Does Microsoft Outlook work with Mercury IMAP using SSL?
Thanks for your help Thomas.
It turned out that the problem was with the firewall protecting the Mercury server.
I'd not allowed traffic to port 993 and of the various mail clients I was testing IMAP SSL connections with, only Outlook used that port.
Regards
Richard
<p>Thanks for your help Thomas.</p><p> </p><p>It turned out that the problem was with the firewall protecting the Mercury server.</p><p>I'd not allowed traffic to port 993 and of the various mail clients I was testing IMAP SSL connections with, only Outlook used that port.</p><p> </p><p>Regards</p><p>Richard </p>
I'm using Mercury 4.73 and Microsoft Office Outlook 2003.
From looking at other posts here, it seems others have Outlook talking to Mercury, but  maybe not via IMAP.
In Mercury's IMAP configuration, I have
Enable support for SSL/TLS checked
Disable plaintest logins for non-SSL connections checked.
Support for deprecated direct-connect SSL Port=993, Interface left blank.
In the Outlook settings, my IMAP server is set to use SSL on port 993.
I can connect to that same remote Mercury server using both Pegasus and Thunderbird.
Does anyone have this combination working?
Regards
Richard
<p>I'm using Mercury 4.73 and Microsoft Office Outlook 2003.</p><p>From looking at other posts here, it seems others have Outlook talking to Mercury, but  maybe not via IMAP.</p><p> </p><p>In Mercury's IMAP configuration, I have</p><p>Enable support for SSL/TLS checked</p><p>Disable plaintest logins for non-SSL connections checked. </p><p>Support for deprecated direct-connect SSL Port=993, Interface left blank. </p><p> </p><p>In the Outlook settings, my IMAP server is set to use SSL on port 993.</p><p>I can connect to that same remote Mercury server using both Pegasus and Thunderbird. </p><p> </p><p>Does anyone have this combination working?</p><p> </p><p>Regards</p><p>Richard </p><p> </p><p> </p>
 I do not use Outlook 2003 but Outlook 2002 works for me using SSL.
I do not have this checked.
Same here
 > In the Outlook settings, my IMAP server is set to use SSL on port 993.
Same here
You might want to turn on session logging in MercuryI to see what happens when you try to connect with Outlook.
<p>> I'm using Mercury 4.73 and Microsoft Office Outlook 2003. > From looking at other posts here, it seems others have Outlook talking to Mercury, but  maybe not via IMAP.</p><p> I do not use Outlook 2003 but Outlook 2002 works for me using SSL. </p><p>> In Mercury's IMAP configuration, I have > Enable support for SSL/TLS checked > Disable plaintest logins for non-SSL connections checked. </p><p>I do not have this checked. </p><p>> Support for deprecated direct-connect SSL Port=993, Interface left blank. </p><p>Same here </p><p> > In the Outlook settings, my IMAP server is set to use SSL on port 993.</p><p>Same here </p><p>> I can connect to that same remote Mercury server using both Pegasus and Thunderbird. </p><p>You might want to turn on session logging in MercuryI to see what happens when you try to connect with Outlook.</p>
