Problem with receiving messages
[quote user="emil.sekula"]My Tools / Internet options / Receiving (POP3) definition: http://postimage.org/image/kagn28w4/[/quote]
The POP3 definition is actually contained in what gets displayed when you doubleclick the highlighted "ddo099c ..." entry, no need to post it here (for privacy/security reasons), just check it for containing the proper information.
In my C:/Archivos de programa/Pegasus Mail/MAIL/Admin there is not any wpm file: http://postimage.org/image/25suygfvo/[/quote]
These files are only created in the same Pegasus Mail session in which you enable the Create Internet session logs ... option on Tools => Internet optiony => General: After restarting Pegasus Mail this option will be disabled again for avoiding waste of disk storage. Every attempt to pop or send emails should create a new TCP????.WPM file (question marks replaced with digits).
<p>[quote user="emil.sekula"]My Tools / Internet options / Receiving (POP3) definition: http://postimage.org/image/kagn28w4/[/quote]</p><p>The POP3 definition is actually contained in what gets displayed when you doubleclick the highlighted "ddo099c ..." entry, no need to post it here (for privacy/security reasons), just check it for containing the proper information.</p><p> [quote user="emil.sekula"] In my C:/Archivos de programa/Pegasus Mail/MAIL/Admin there is not any wpm file: http://postimage.org/image/25suygfvo/[/quote]</p><p>These files are only created in the same Pegasus Mail session in which you enable the <em>Create Internet session logs ...</em> option on <em>Tools => Internet optiony => General</em>: After restarting Pegasus Mail this option will be disabled again for avoiding waste of disk storage. Every attempt to pop or send emails should create a new TCP????.WPM file (question marks replaced with digits).</p>
I have installed Pegasus Mail and I have problem with receiving new messages. There is not any error message.
Any idea why ?
Regards,
Emil
<p>Hello,</p><p>I have installed Pegasus Mail and I have problem with receiving new messages. There is not any error message.</p><p>Any idea why ?</p><p>Regards,</p><p>Emil  </p><p> </p><p> </p><p> </p>
In Pegasus Mail do Tools, Internet Options, General and down near bottom check Internet session log item. Follow instructions and warning message. View the resulting *.wpm file to see all of the conversation between you and the mail server and any error messages contained in that plain text file. Do not copy or send the file to anybody before you edit out your account name and password information first.
The session log is also described in the Help, Commandline options, -z 32 section as that is another way to start and run session log.
<p>In Pegasus Mail do Tools, Internet Options, General and down near bottom check Internet session log item. Follow instructions and warning message. View the resulting *.wpm file to see all of the conversation between you and the mail server and any error messages contained in that plain text file. Do not copy or send the file to anybody before you edit out your account name and password information first.</p><p>The session log is also described in the Help, Commandline options, -z 32 section as that is another way to start and run session log. </p>
I am marking Internet session logs:
http://postimage.org/image/32vih14hw/
but nothing happens.
<p>I am marking Internet session logs:</p><p>http://postimage.org/image/32vih14hw/</p><p>but nothing happens.</p><p> </p><p> </p><p> </p><p> </p>
Not sure what you mean.  Are you saying there are no TCP????.WPM files created in your home mail directory?
BTW, what version of Pegasus Mail are you using?  I could not tell the language from the graphic.
<p>> I am marking Internet session logs: > > http://postimage.org/image/32vih14hw/ > > but nothing happens. Not sure what you mean.  Are you saying there are no TCP????.WPM files created in your home mail directory? </p><p>BTW, what version of Pegasus Mail are you using?  I could not tell the language from the graphic. </p>
I can't see any TCP track and there is not any wpm file saved.
I am using version 4.61
<p>I can't see any TCP track and there is not any wpm file saved.</p><p>I am using version 4.61 </p><p> </p>
Check the setting of Tools | Options | Advanced and verify that the Winsock is set to "Always".  If this needs to change, close and reopen WinPMail to affect the change.
For what language?  German?  French? Italian?
<p>> I can't see any TCP track and there is not any wpm file saved.</p><p>Check the setting of Tools | Options | Advanced and verify that the Winsock is set to "Always".  If this needs to change, close and reopen WinPMail to affect the change.</p><p>> I am using version 4.61</p><p>For what language?  German?  French? Italian? </p>
I have ´Always´ marked for Load Windows Internet Services:
http://postimage.org/image/1i795tc90/
I am using English language for Pegasus.
<p>I have ´Always´ marked for Load Windows Internet Services:</p><p>http://postimage.org/image/1i795tc90/</p><p>I am using English language for Pegasus.  </p>
Could you provide a copy of Help | about Pegasus Mail | Info in a reply to this message?  Just copy and paste it into the reply.
That's really strange since the image at http://postimage.org/image/32vih14hw/ shows another language, i.e. Acceptar, Cancelar & Ayuda  Are you sure you are not using any of the language support modules?
<p>> I have ´Always´ marked for Load Windows Internet Services:</p><p>> http://postimage.org/image/1i795tc90/</p><p>Could you provide a copy of Help | about Pegasus Mail | Info in a reply to this message?  Just copy and paste it into the reply. </p><p>> I am using English language for Pegasus. </p><p>That's really strange since the image at <a href="http://postimage.org/image/32vih14hw/" title="http://postimage.org/image/32vih14hw/" mce_href="http://postimage.org/image/32vih14hw/">http://postimage.org/image/32vih14hw/</a> shows another language, i.e. Acceptar, Cancelar & Ayuda  Are you sure you are not using any of the language support modules? </p>
[quote user="Thomas R. Stephenson"]That's really strange since the image at http://postimage.org/image/32vih14hw/ shows another language, i.e. Acceptar, Cancelar & Ayuda  Are you sure you are not using any of the language support modules? [/quote]
Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the English version of Pegasus Mail:
<p>[quote user="Thomas R. Stephenson"]That's really strange since the image at <a href="http://postimage.org/image/32vih14hw/" title="http://postimage.org/image/32vih14hw/" mce_href="http://postimage.org/image/32vih14hw/">http://postimage.org/image/32vih14hw/</a> shows another language, i.e. Acceptar, Cancelar & Ayuda  Are you sure you are not using any of the language support modules? [/quote]</p><p>Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the English version of Pegasus Mail:</p>
[quote user="idw"]
Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the Englich version of Pegasus Mail:
But in this case there is some language other then English being used, on the operating system, is that correct?  Is this not significant to the analysis of a WinPMail problem?
[quote user="idw"]<p>[quote user="Thomas R. Stephenson"]That's really strange since the image at <a href="http://postimage.org/image/32vih14hw/" title="http://postimage.org/image/32vih14hw/" mce_href="http://postimage.org/image/32vih14hw/">http://postimage.org/image/32vih14hw/</a> shows another language, i.e. Acceptar, Cancelar & Ayuda  Are you sure you are not using any of the language support modules? [/quote]</p><p>Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the Englich version of Pegasus Mail:</p><p>[/quote]</p><p>But in this case there is some language other then English being used, on the operating system, is that correct?  Is this not significant to the analysis of a WinPMail problem?</p><p>  </p><p> </p>
[quote user="Thomas R. Stephenson"][quote user="idw"]Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the Englich version of Pegasus Mail:[/quote]
But in this case there is some language other then English being used, on the operating system, is that correct?  Is this not significant to the analysis of a WinPMail problem?[/quote]
I'm not sure I understand: Of course, the button language is the default language of the user's system, but what problem should this be causing? It's this way ever since Pegasus Mail uses these dialogs ...
[quote user="Thomas R. Stephenson"][quote user="idw"]Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the Englich version of Pegasus Mail:[/quote]<p>But in this case there is some language other then English being used, on the operating system, is that correct?  Is this not significant to the analysis of a WinPMail problem?[/quote]</p><p>I'm not sure I understand: Of course, the button language is the default language of the user's system, but what problem should this be causing? It's this way ever since Pegasus Mail uses these dialogs ...</p>
[quote user="idw"][quote user="Thomas R. Stephenson"][quote user="idw"]Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the Englich version of Pegasus Mail:[/quote]
I have no idea but we should always know the environment where the program is being used especially since this looks like it could be related somewhat to the operating system since he's turned on session logging and is not getting any session logs at all.
[quote user="idw"][quote user="Thomas R. Stephenson"][quote user="idw"]Thomas, if Pegasus Mail uses standard system dialogs the buttons show the local language (Spanish in this case) no matter what Pegasus Mail's language setting is, here's the German version of such a dialog in the Englich version of Pegasus Mail:[/quote]<p>But in this case there is some language other then English being used, on the operating system, is that correct?  Is this not significant to the analysis of a WinPMail problem?[/quote]</p><p>I'm not sure I understand: Of course, the button language is the default language of the user's system, but what problem should this be causing? It's this way ever since Pegasus Mail uses these dialogs ...</p><p>[/quote]</p><p>I have no idea but we should always know the environment where the program is being used especially since this looks like it could be related somewhat to the operating system since he's turned on session logging and is not getting any session logs at all.</p><p> </p>
Here you have Help Info:
<!--[if gte mso 9]><xml> </p><p> <w:WordDocument> </p><p> <w:View>Normal</w:View> </p><p> <w:Zoom>0</w:Zoom> </p><p> <w:TrackMoves/> </p><p> <w:TrackFormatting/> </p><p> <w:HyphenationZone>21</w:HyphenationZone> </p><p> <w:PunctuationKerning/> </p><p> <w:ValidateAgainstSchemas/> </p><p> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> </p><p> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> </p><p> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> </p><p> <w:DoNotPromoteQF/> </p><p> <w:LidThemeOther>ES</w:LidThemeOther> </p><p> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> </p><p> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> </p><p> <w:Compatibility> </p><p> <w:BreakWrappedTables/> </p><p> <w:SnapToGridInCell/> </p><p> <w:WrapTextWithPunct/> </p><p> <w:UseAsianBreakRules/> </p><p> <w:DontGrowAutofit/> </p><p> <w:SplitPgBreakAndParaMark/> </p><p> <w:DontVertAlignCellWithSp/> </p><p> <w:DontBreakConstrainedForcedTables/> </p><p> <w:DontVertAlignInTxbx/> </p><p> <w:Word11KerningPairs/> </p><p> <w:CachedColBalance/> </p><p> </w:Compatibility> </p><p> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </p><p> <m:mathPr> </p><p> <m:mathFont m:val="Cambria Math"/> </p><p> <m:brkBin m:val="before"/> </p><p> <m:brkBinSub m:val="&#45;-"/> </p><p> <m:smallFrac m:val="off"/> </p><p> <m:dispDef/> </p><p> <m:lMargin m:val="0"/> </p><p> <m:rMargin m:val="0"/> </p><p> <m:defJc m:val="centerGroup"/> </p><p> <m:wrapIndent m:val="1440"/> </p><p> <m:intLim m:val="subSup"/> </p><p> <m:naryLim m:val="undOvr"/> </p><p> </m:mathPr></w:WordDocument> </p><p></xml><![endif]--><!--[if gte mso 9]><xml> </p><p> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" </p><p> DefSemiHidden="true" DefQFormat="false" DefPriority="99" </p><p> LatentStyleCount="267"> </p><p> <w:LsdException Locked="false" Priority="0" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Normal"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> </p><p> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> </p><p> <w:LsdException Locked="false" Priority="10" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Title"/> </p><p> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> </p><p> <w:LsdException Locked="false" Priority="11" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> </p><p> <w:LsdException Locked="false" Priority="22" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Strong"/> </p><p> <w:LsdException Locked="false" Priority="20" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="59" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Table Grid"/> </p><p> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> </p><p> <w:LsdException Locked="false" Priority="1" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> </p><p> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> </p><p> <w:LsdException Locked="false" Priority="34" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> </p><p> <w:LsdException Locked="false" Priority="29" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Quote"/> </p><p> <w:LsdException Locked="false" Priority="30" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="19" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="21" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="31" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> </p><p> <w:LsdException Locked="false" Priority="32" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> </p><p> <w:LsdException Locked="false" Priority="33" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> </p><p> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> </p><p> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </p><p> </w:LatentStyles> </p><p></xml><![endif]--><!--[if gte mso 10]> </p><p><style> </p><p> /* Style Definitions */ </p><p> table.MsoNormalTable </p><p> {mso-style-name:"Tabla normal"; </p><p> mso-tstyle-rowband-size:0; </p><p> mso-tstyle-colband-size:0; </p><p> mso-style-noshow:yes; </p><p> mso-style-priority:99; </p><p> mso-style-qformat:yes; </p><p> mso-style-parent:""; </p><p> mso-padding-alt:0cm 5.4pt 0cm 5.4pt; </p><p> mso-para-margin-top:0cm; </p><p> mso-para-margin-right:0cm; </p><p> mso-para-margin-bottom:10.0pt; </p><p> mso-para-margin-left:0cm; </p><p> line-height:115%; </p><p> mso-pagination:widow-orphan; </p><p> font-size:11.0pt; </p><p> font-family:"Calibri","sans-serif"; </p><p> mso-ascii-font-family:Calibri; </p><p> mso-ascii-theme-font:minor-latin; </p><p> mso-fareast-font-family:"Times New Roman"; </p><p> mso-fareast-theme-font:minor-fareast; </p><p> mso-hansi-font-family:Calibri; </p><p> mso-hansi-theme-font:minor-latin;} </p><p></style> </p><p><![endif]-->
Pegasus
Mail for Microsoft Windows
Copyright
(C) 1992-2011, David Harris, all rights reserved
Electronic
mail to support@pmail.gen.nz.
WinPMail
version: Version 4.61 (Win32), Feb  5
2011
Language
resources: Standard UK English resource set
Extension
Manager version: 1.13
Operating
mode: Standalone
User name
and ID: Admin, 0
Windows
version: 5.1
Windows
flag word: 0
WINPMAIL.EXE
directory: C:\Archivos de programa\Pegasus Mail\Programs
Home
mailbox location: C:\Archivos de programa\Pegasus Mail\MAIL\Admin
New mailbox
TMP environment variable: C:\DOCUME~1\cial-3\CONFIG~1\Temp
TEMP environment variable: C:\DOCUME~1\cial-3\CONFIG~1\Temp
LAN-based
SMTP support: N, N, N
NetWare MHS
support: N, N, N
Built-in
TCP/IP support: Enabled
  - WINSOCK path:
C:\WINDOWS\system32\WSOCK32.DLL
Commandline:
-A
Active -Z
options: 32768
PMR
variable: (None)
PML
variable: (None)
MAI
variable: (None)
NB
variable: (None)
Last new mail count: 0
&lt;p&gt;Here you have Help Info:&lt;/p&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:TrackMoves/&gt; &lt;w:TrackFormatting/&gt; &lt;w:HyphenationZone&gt;21&lt;/w:HyphenationZone&gt; &lt;w:PunctuationKerning/&gt; &lt;w:ValidateAgainstSchemas/&gt; &lt;w:SaveIfXMLInvalid&gt;false&lt;/w:SaveIfXMLInvalid&gt; &lt;w:IgnoreMixedContent&gt;false&lt;/w:IgnoreMixedContent&gt; &lt;w:AlwaysShowPlaceholderText&gt;false&lt;/w:AlwaysShowPlaceholderText&gt; &lt;w:DoNotPromoteQF/&gt; &lt;w:LidThemeOther&gt;ES&lt;/w:LidThemeOther&gt; &lt;w:LidThemeAsian&gt;X-NONE&lt;/w:LidThemeAsian&gt; &lt;w:LidThemeComplexScript&gt;X-NONE&lt;/w:LidThemeComplexScript&gt; &lt;w:Compatibility&gt; &lt;w:BreakWrappedTables/&gt; &lt;w:SnapToGridInCell/&gt; &lt;w:WrapTextWithPunct/&gt; &lt;w:UseAsianBreakRules/&gt; &lt;w:DontGrowAutofit/&gt; &lt;w:SplitPgBreakAndParaMark/&gt; &lt;w:DontVertAlignCellWithSp/&gt; &lt;w:DontBreakConstrainedForcedTables/&gt; &lt;w:DontVertAlignInTxbx/&gt; &lt;w:Word11KerningPairs/&gt; &lt;w:CachedColBalance/&gt; &lt;/w:Compatibility&gt; &lt;w:BrowserLevel&gt;MicrosoftInternetExplorer4&lt;/w:BrowserLevel&gt; &lt;m:mathPr&gt; &lt;m:mathFont m:val=&quot;Cambria Math&quot;/&gt; &lt;m:brkBin m:val=&quot;before&quot;/&gt; &lt;m:brkBinSub m:val=&quot;&amp;#45;-&quot;/&gt; &lt;m:smallFrac m:val=&quot;off&quot;/&gt; &lt;m:dispDef/&gt; &lt;m:lMargin m:val=&quot;0&quot;/&gt; &lt;m:rMargin m:val=&quot;0&quot;/&gt; &lt;m:defJc m:val=&quot;centerGroup&quot;/&gt; &lt;m:wrapIndent m:val=&quot;1440&quot;/&gt; &lt;m:intLim m:val=&quot;subSup&quot;/&gt; &lt;m:naryLim m:val=&quot;undOvr&quot;/&gt; &lt;/m:mathPr&gt;&lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:LatentStyles DefLockedState=&quot;false&quot; DefUnhideWhenUsed=&quot;true&quot; DefSemiHidden=&quot;true&quot; DefQFormat=&quot;false&quot; DefPriority=&quot;99&quot; LatentStyleCount=&quot;267&quot;&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;0&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Normal&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;heading 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;35&quot; QFormat=&quot;true&quot; Name=&quot;caption&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;10&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Title&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;1&quot; Name=&quot;Default Paragraph Font&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;11&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Subtitle&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;22&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Strong&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;20&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;59&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Table Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Placeholder Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;1&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;No Spacing&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Revision&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;34&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;List Paragraph&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;29&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Quote&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;30&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Intense Quote&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;19&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Subtle Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;21&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Intense Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;31&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Subtle Reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;32&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Intense Reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;33&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Book Title&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;37&quot; Name=&quot;Bibliography&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; QFormat=&quot;true&quot; Name=&quot;TOC Heading&quot;/&gt; &lt;/w:LatentStyles&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 10]&gt; &lt;style&gt; /* Style Definitions */ table.MsoNormalTable {mso-style-name:&quot;Tabla normal&quot;; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:&quot;&quot;; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:&quot;Calibri&quot;,&quot;sans-serif&quot;; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:&quot;Times New Roman&quot;; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} &lt;/style&gt; &lt;![endif]--&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Pegasus Mail for Microsoft Windows&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Copyright (C) 1992-2011, David Harris, all rights reserved&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Electronic mail to support@pmail.gen.nz.&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;&amp;nbsp;&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;WinPMail version: Version 4.61 (Win32), Feb&lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp; &lt;/span&gt;5 2011&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Language resources: Standard UK English resource set&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Extension Manager version: 1.13&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Operating mode: Standalone&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;User name and ID: Admin, 0&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Windows version: 5.1&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Windows flag word: 0&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;WINPMAIL.EXE directory: C:\Archivos de programa\Pegasus Mail\Programs&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Home mailbox location: C:\Archivos de programa\Pegasus Mail\MAIL\Admin&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;New mailbox location: C:\Archivos de programa\Pegasus Mail\MAIL\Admin&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;TMP environment variable: C:\DOCUME~1\cial-3\CONFIG~1\Temp&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;TEMP environment variable: C:\DOCUME~1\cial-3\CONFIG~1\Temp&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;LAN-based SMTP support: N, N, N&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;NetWare MHS support: N, N, N&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Built-in TCP/IP support: Enabled&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;&lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp; &lt;/span&gt;- WINSOCK version: WinSock 2.0&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;&lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp; &lt;/span&gt;- WINSOCK path: C:\WINDOWS\system32\WSOCK32.DLL&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Commandline: -A&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Active -Z options: 32768&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;PMR variable: (None)&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;PML variable: (None)&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;MAI variable: (None)&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;NB variable: (None)&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Autofiltering folders: 0 (0 active, 0 inactive)&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Last new mail count: 0&lt;/p&gt;
[quote user="emil.sekula"]I have installed Pegasus Mail and I have problem with receiving new messages. There is not any error message.[/quote]
What have you put in the Tools / Internet options / Receiving (POP3) definition?  Are you clicking on the icon 'Check host for new mail?'
&lt;P&gt;[quote user=&quot;emil.sekula&quot;]I&amp;nbsp;have installed Pegasus Mail and I have problem with receiving new messages. There is not any error message.[/quote]&lt;/P&gt; &lt;P&gt;What have you put in the Tools / Internet options / Receiving (POP3) definition?&amp;nbsp; Are you clicking on the icon &#039;Check host for new mail?&#039;&lt;/P&gt;
[quote user="emil.sekula"]I can't see any TCP track and there is not any wpm file saved.[/quote]
Did you look in the proper place? According to the info you posted they should go to C:\Archivos de programa\Pegasus Mail\MAIL\Admin. If there's nothing it's rather likely that your POP3 definition is somehow invalid and Pegasus Mail doesn't try to connect at all. What kind of Internet connection do you use (i.e. dial-up or permanent)?
&lt;p&gt;[quote user=&quot;emil.sekula&quot;]I can&#039;t see any TCP track and there is not any wpm file saved.[/quote]&lt;/p&gt;&lt;p&gt;Did you look in the proper place? According to the info you posted they should go to &lt;em&gt;C:\Archivos de programa\Pegasus Mail\MAIL\Admin&lt;/em&gt;. If there&#039;s nothing it&#039;s rather likely that your POP3 definition is somehow invalid and Pegasus Mail doesn&#039;t try to connect at all. What kind of Internet connection do you use (i.e. dial-up or permanent)?&lt;/p&gt;
My Tools / Internet options / Receiving (POP3) definition:
http://postimage.org/image/kagn28w4/
What do you mean with 'Check host for new mail' icon ?
In my C:/Archivos de programa/Pegasus Mail/MAIL/Admin there is not any wpm file:
http://postimage.org/image/25suygfvo/
&lt;p&gt;My Tools / Internet options / Receiving (POP3) definition:&lt;/p&gt;&lt;p&gt;http://postimage.org/image/kagn28w4/&lt;/p&gt;&lt;p&gt;What do you mean with &#039;Check host for new mail&#039; icon ? &lt;/p&gt;&lt;p&gt;In my C:/Archivos de programa/Pegasus Mail/MAIL/Admin there is not any wpm file:&lt;/p&gt;&lt;p&gt;http://postimage.org/image/25suygfvo/&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
