Problem with DNS
Figured out after some digging that I was running IIS in the background, turned it off and now the world makes more sense.  Thanks for everything![Y]
 Currently I'm testing Mercury Mail for the company I work for and have run into a slight problem that we can't seem to resolve.  The e-mails that send to our current server either send as GeneralEmailAddress or GeneralEmailAddress@host.  Unfortunately we have been unable to set-up Mercury to recieve from both types of e-mail addresses.  Whenever GeneralEmailAddress or GeneralEmailAddress@www.xxx.yyy.zzz (the IP of the machine) is used the core module resolves the host as local, but when we use GeneralEmailAddres@host the core module resolves as non-local and passes the email directly to the client.
Machine: Virtual Machine of Windows XP sp3
Modules: Core, SMTP Server S, SMTP Client C
- In appreciation
<P> Currently I'm testing Mercury Mail for the company I work for and have run into a slight problem that we can't seem to resolve.  The e-mails that send to our current server either send as <STRONG>GeneralEmailAddress</STRONG> or <STRONG>GeneralEmailAddress@host</STRONG><STRONG>.  </STRONG>Unfortunately we have been unable to set-up Mercury to recieve from both types of e-mail addresses.  Whenever <STRONG>GeneralEmailAddress</STRONG> or <STRONG>GeneralEmailAddress@www.xxx.yyy.zzz</STRONG> (the IP of the machine) is used the core module resolves the host as local, but when we use <STRONG>GeneralEmailAddres@host</STRONG> the core module resolves as non-local and passes the email directly to the client.  </P> <P mce_keep="true"> </P> <P>Machine: Virtual Machine of Windows XP sp3</P> <P>Modules: Core, SMTP Server S, SMTP Client C</P> <P mce_keep="true"> </P> <P>- In appreciation</P>
Looks like the domain and/or host name is not correct.  Let us see a copy of your mercury.ini file and provide us with real host and e-mail address info.
<p>> Whenever <b>GeneralEmailAddress</b> or <b>GeneralEmailAddress@www.xxx.yyy.zzz</b> (the IP of the machine) is used > the core module resolves the host as local, but when we use <b>GeneralEmailAddres@host</b> the core module > resolves as non-local and passes the email directly to the client. </p><p>Looks like the domain and/or host name is not correct.  Let us see a copy of your mercury.ini file and provide us with real host and e-mail address info.</p><p> </p>
Local computer engmonitor-01a @ 10.2.13.96
#  Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#  This sample file implements most of the possible switches for each
#  module, but you can edit it to do less if you wish.
#  Anything after a '#' to the end of the line is a comment and
#  is stripped out before parsing. Trailing and leading whitespace
#  is also stripped before parsing. Many sample commands have been
#  left in this file commented out for reference purposes.
#  Note that in general, manual modification of this file is NOT
#  RECOMMENDED - use the Mercury "Configuration" menu to change the
#  program's settings wherever possible.
[General]
myname:          10.2.13.96    # Canonical name for this server
timezone:        +0000    # Time Zone to add to date fields
file_api:        1    # Use the file api instead of queues
mailqueue:       C:\MERCURY\QUEUE    # Where mail should be put for delivery
smtpqueue:       C:\MERCURY\QUEUE    # Where the SMTP client should look for mail
newmail_path:    C:\MERCURY\MAIL\~N    # Where to find the users' WinPMail mailboxes.
[Protocols]
MERCURYS.DLL
# MERCURYP.DLL
# MERCURYE.DLL
MERCURYC.DLL
# MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile:      C:\MERCURY\Mercury\FAILURE.MER    # Delivery failure notification template
confirmfile:   C:\MERCURY\Mercury\CONFIRM.MER    # Delivery confirmation template
aliasfile:     C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file
synfile:       C:\MERCURY\Mercury\SYNONYM.MER    # User synonym database
listfile:      C:\MERCURY\Mercury\LISTS.MER    # List of lists
logfile:       C:\MERCURY\Logs\Core\~y-~m-~d.log    # Traffic logging file
logwidth:      30    # Width of address fields in logfile
retpath:       1    # Do/Don't use 'return-path' for errors
maxhops:       30    # Used to detect mailing loops
gullible:      0    # If NZ, don't validate 'From' fields
poll:          10   # Seconds between queue polling cycles
scratch:       C:\MERCURY\Scratch    # Where we can write temp files
returnlines:   15    # How many lines of failed messages to return
postmaster:    PA User    # NetWare UIC of postmaster
broadcast:     1    # Yes, we want broadcast notifications, but
receipts:      0    # ... no broadcasts for receipt confirmations
PM_notify:     1    # Do/Don't send errors to the postmaster
change_owner:  1    # Change message ownership to recipient
auto_tzone:    1    # If NZ, obtain timezone information from OS
LogLevel:      15    # System message reporting level
LogMax:        100    # Maximum number of system messages to store
RetryPeriod:   30    # Period between job retries (minutes)
MaxRetries:    16    # Maximum number of times a job can fail
TwoPasses:     1    # If NZ, process submission queue in 2 passes
Autoaddress:   0    # If NZ, auto-generate user addresses based on name
Daily_exit:    0    # If NZ, auto-restart each day after maintenance
No_Areply:     0    # If NZ, disable automatic replies system-wide
Alt_Forward:   0    # If NZ, allow alternate forwarding specification
Maint_hour:    2    # Hour for daily maintenance (24-hour clock)
Maint_min:     0    # Minute for daily maintenance
Retry_Mode:    0    # If NZ, use progressive backoff for queue retries
Local_DSNs:    1    # If NZ generate Delivery Status for local users only
DSN_time1:     10800    # Seconds deferred before first DSN is sent
DSN_time2:     86400    # Seconds deferred before second DSN is sent
DSN_time3:     259200    # Seconds deferred before third DSN is sent
Host_in_title: 0    # If NZ, show hostname in system tray and taskbar
Lingering:     0    # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60   # Seconds before a lingering mailbox is shut down
Alert_Host:    notify.pmail.com    # Host to check for licensee advisories
Alert_Interval: 720   # Frequency in minutes (min 240) for checks
Alert_Flags:   3    # Flags controlling advisory checks
[MercuryC]
Host : smtp1.alleghenytechnologies.com
Failfile : C:\MERCURY\Mercury\FAILURE.MER
Poll : 30
Scratch : C:\MERCURY\scratch
ReturnLines : 15
Timeout : 30
ESMTP : 1
POP3_Auth : 0
Logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log
Log_Verbose : 0
Session_logging : C:\MERCURY\Sessions\MercuryC
Session_logmode : 0
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\   # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\    # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120               # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log
Timeout : 30
Relay : 1
Strict_Relay : 0
Allow_Illegals : 1
SMTP_Authentication : 0
Session_logging : C:\MERCURY\Sessions\MercuryS
Session_logmode : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
Session_logging : C:\MERCURY\Sessions\MercuryP
Session_logmode : 0
Timeout : 60
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup            :     TESTGRP
[Domains]
10: 10
10: 10.2.13.96
[Maiser]
Helpfile:        C:\MERCURY\Mercury\MAISER.HLP   # Help sent on failed maiser requests
Lookupfile:      C:\MERCURY\Mercury\MAISER.LKP   # Format file for the 'lookup' command
Send_dir:        C:\MERCURY\Mercury\SENDABLE   # Directory for the 'send' command
Logfile:         C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG   # Mail server log file
Notify:          C:\MERCURY\Mercury\TMP   # Dir. for pending 'notify' commands
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log   # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags:    0  # Statistical reporting settings
STF_Hours:    24  # How often to write stat log files
STM_Hours:    24  # How often to e-mail stat log files
<P>Local computer engmonitor-01a @ 10.2.13.96 </P> <P mce_keep="true"> </P> <P>#  MERCURY.INI generated by Mercury Setup # # #  Sample Bindery Mode / Standalone Mode MERCURY.INI file. #  This sample file implements most of the possible switches for each #  module, but you can edit it to do less if you wish. # #  Anything after a '#' to the end of the line is a comment and #  is stripped out before parsing. Trailing and leading whitespace #  is also stripped before parsing. Many sample commands have been #  left in this file commented out for reference purposes. # #  Note that in general, manual modification of this file is NOT #  RECOMMENDED - use the Mercury "Configuration" menu to change the #  program's settings wherever possible. #</P> <P>[General] myname:          10.2.13.96    # Canonical name for this server timezone:        +0000    # Time Zone to add to date fields file_api:        1    # Use the file api instead of queues mailqueue:       C:\MERCURY\QUEUE    # Where mail should be put for delivery smtpqueue:       C:\MERCURY\QUEUE    # Where the SMTP client should look for mail newmail_path:    C:\MERCURY\MAIL\~N    # Where to find the users' WinPMail mailboxes.</P> <P>[Protocols] MERCURYS.DLL # MERCURYP.DLL # MERCURYE.DLL MERCURYC.DLL # MERCURYD.DLL # MERCURYH.DLL # MERCURYF.DLL # MERCURYW.DLL # MERCURYX.DLL # MERCURYI.DLL # MERCURYB.DLL</P> <P>[Mercury] failfile:      C:\MERCURY\Mercury\FAILURE.MER    # Delivery failure notification template confirmfile:   C:\MERCURY\Mercury\CONFIRM.MER    # Delivery confirmation template aliasfile:     C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file synfile:       C:\MERCURY\Mercury\SYNONYM.MER    # User synonym database listfile:      C:\MERCURY\Mercury\LISTS.MER    # List of lists logfile:       C:\MERCURY\Logs\Core\~y-~m-~d.log    # Traffic logging file logwidth:      30    # Width of address fields in logfile retpath:       1    # Do/Don't use 'return-path' for errors maxhops:       30    # Used to detect mailing loops gullible:      0    # If NZ, don't validate 'From' fields poll:          10   # Seconds between queue polling cycles scratch:       C:\MERCURY\Scratch    # Where we can write temp files returnlines:   15    # How many lines of failed messages to return postmaster:    PA User    # NetWare UIC of postmaster broadcast:     1    # Yes, we want broadcast notifications, but receipts:      0    # ... no broadcasts for receipt confirmations PM_notify:     1    # Do/Don't send errors to the postmaster change_owner:  1    # Change message ownership to recipient auto_tzone:    1    # If NZ, obtain timezone information from OS LogLevel:      15    # System message reporting level LogMax:        100    # Maximum number of system messages to store RetryPeriod:   30    # Period between job retries (minutes) MaxRetries:    16    # Maximum number of times a job can fail TwoPasses:     1    # If NZ, process submission queue in 2 passes Autoaddress:   0    # If NZ, auto-generate user addresses based on name Daily_exit:    0    # If NZ, auto-restart each day after maintenance No_Areply:     0    # If NZ, disable automatic replies system-wide Alt_Forward:   0    # If NZ, allow alternate forwarding specification Maint_hour:    2    # Hour for daily maintenance (24-hour clock) Maint_min:     0    # Minute for daily maintenance Retry_Mode:    0    # If NZ, use progressive backoff for queue retries Local_DSNs:    1    # If NZ generate Delivery Status for local users only DSN_time1:     10800    # Seconds deferred before first DSN is sent DSN_time2:     86400    # Seconds deferred before second DSN is sent DSN_time3:     259200    # Seconds deferred before third DSN is sent Host_in_title: 0    # If NZ, show hostname in system tray and taskbar Lingering:     0    # Enable or disable 'lingering mailboxes' Linger_Timeout: 60   # Seconds before a lingering mailbox is shut down Alert_Host:    notify.pmail.com    # Host to check for licensee advisories Alert_Interval: 720   # Frequency in minutes (min 240) for checks Alert_Flags:   3    # Flags controlling advisory checks</P> <P>[MercuryC] Host : smtp1.alleghenytechnologies.com Failfile : C:\MERCURY\Mercury\FAILURE.MER Poll : 30 Scratch : C:\MERCURY\scratch ReturnLines : 15 Timeout : 30 ESMTP : 1 POP3_Auth : 0 Logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log Log_Verbose : 0 Session_logging : C:\MERCURY\Sessions\MercuryC Session_logmode : 0</P> <P>[MercuryE] Poll : 15 Timeout : 60 logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryE\   # Directory for session log files Session_logmode : 0 # Nameservers : 139.80.64.1</P> <P>[MercuryD] Session_logging : C:\MERCURY\Sessions\MercuryD\    # Directory for session log files Session_logmode : 0 Scratch : C:\MERCURY\Scratch\MercuryD # Timeout : 30 # Poll : 120               # How often to check hosts for new mail (seconds)</P> <P>[MercuryS] Debug : 1 Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log Timeout : 30 Relay : 1 Strict_Relay : 0 Allow_Illegals : 1 SMTP_Authentication : 0 Session_logging : C:\MERCURY\Sessions\MercuryS Session_logmode : 0 Compliance_Settings : 0 Maximum_Failed_Rcpts : 4 Max_Relay_Attempts : 4 SSL_Mode : 0 ST_Blacklisting : 288 No_VRFY : 0 SMTP_ConnFlags : 0</P> <P>[MercuryP] Scratch : C:\MERCURY\Scratch\MercuryP Logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log Stack : 32768 Mark_Read : 1 SSL_Mode : 0 Login_Disabled : 0 UIDL_nul_list : 1 New_UIDs : 1 No_NUL_passwords : 1 Session_logging : C:\MERCURY\Sessions\MercuryP Session_logmode : 0 Timeout : 60</P> <P>[MercuryX] Drain_queues: 1 # Cmd_Delay: 10 # Cmd_Wait: 1 # IE4_Dialling: 0 # Use_ETRN: 1 # Clients_only: 1 # Sunday: 0800,1800,3,15,30,60 # Monday: 0830,2100,5,15,60,60 # Tuesday: 0830,2100,5,15,60,60 # Wednesday: 1500,1900,2,30,5,30 # Thursday: 0900,1900,2,30,0,0 # Friday: 0830,2100,5,15,60,60 # Saturday: 1031,1035,2,45,-1,0</P> <P># [Groups] # testgroup            :     TESTGRP</P> <P>[Domains] 10: 10 10: 10.2.13.96</P> <P>[Maiser] Maiser:          Maiser   # 'Username' of mail server account Helpfile:        C:\MERCURY\Mercury\MAISER.HLP   # Help sent on failed maiser requests Lookupfile:      C:\MERCURY\Mercury\MAISER.LKP   # Format file for the 'lookup' command Send_dir:        C:\MERCURY\Mercury\SENDABLE   # Directory for the 'send' command Logfile:         C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG   # Mail server log file Notify:          C:\MERCURY\Mercury\TMP   # Dir. for pending 'notify' commands NoList:          N   # If 'Y', disable the 'list' command Local_only:      Y   # If 'Y', local 'notify' commands only</P> <P>[MercuryH] logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log   # Traffic logging file # Addressbook : <A href="file://clio/SYS/SYSTEM/MERCURY/PH.PMR">\\CLIO\SYS\SYSTEM\MERCURY\PH.PMR</A> # MOTD : <A href="file://clio/SYS/SYSTEM/MERCURY/PH-MOTD.TXT">\\CLIO\SYS\SYSTEM\MERCURY\PH-MOTD.TXT</A> # Administrator : <A href="mailto:postmaster@clio.pmail.gen.nz">postmaster@clio.pmail.gen.nz</A> Timeout : 30</P> <P>[MercuryI] Scratch : C:\MERCURY\Scratch\MercuryI logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryI\   # Directory for session log files Session_logmode : 0 Timeout : 120 Server_Port : 143 Idle_Timeout : 1800</P> <P>[MercuryB] Scratch : C:\MERCURY\Scratch\MercuryB logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryB\   # Directory for session log files Session_logmode : 0 Timeout : 120 Server_Port : 80 Idle_Timeout : 1800 # URL_Base : enter_your_domain_here</P> <P>[Groups]</P> <P>[Rewrite]</P> <P>[Statistics] StatFlags:    0  # Statistical reporting settings STF_Hours:    24  # How often to write stat log files STM_Hours:    24  # How often to e-mail stat log files</P> <P mce_keep="true"> </P>
The form of a literal address like this is user@[<IP address>] or in this case
engmonitor-01a@[10.2.13.96] without any spaces at all
Ok, I assume there is no real host name or IP address except this internal IP address.
> [Protocols]
> MERCURYS.DLL
> MERCURYC.DLL
> [MercuryC]
Good SMTP host.
> [Domains]
> 10: 10
> 10: 10.2.13.96
This really should look something like
[Domains]
Server : Server
Server : [10.2.13.96]
With this setup any e-mail message received with the domain [10.2.13.96] will be considered local and will be delivered to a local user if one exists.
In the case of the e-mail address engmonitor-01a@[10.2.13.96] there must be a directory user C:\MERCURY\MAIL\engmonitor-01a and the name must also be in the C:\MERCURY\MAIL\PMAIL.USR file.  Use Configuration | Manage local users to verify.
&amp;gt; Local computer engmonitor-01a @ 10.2.13.96 The form of a literal address like this is user@[&amp;lt;IP address&amp;gt;] or in this case engmonitor-01a@[10.2.13.96] without any spaces at all &amp;gt; myname:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 10.2.13.96&amp;nbsp;&amp;nbsp;&amp;nbsp; # Canonical name for this server Ok, I assume there is no real host name or IP address except this internal IP address. &amp;gt; [Protocols] &amp;gt; MERCURYS.DLL &amp;gt; MERCURYC.DLL &amp;gt; [MercuryC] &amp;gt; Host : smtp1.alleghenytechnologies.com Good SMTP host. &amp;gt; [Domains] &amp;gt; 10: 10 &amp;gt; 10: 10.2.13.96 This really should look something like [Domains] Server : Server Server : [10.2.13.96] With this setup any e-mail message received with the domain [10.2.13.96] will be considered local and will be delivered to a local user if one exists. &amp;nbsp; In the case of the e-mail address engmonitor-01a@[10.2.13.96] there must be a directory user C:\MERCURY\MAIL\engmonitor-01a and the name must also be in the C:\MERCURY\MAIL\PMAIL.USR file.&amp;nbsp; Use Configuration | Manage local users to verify.
[quote user="Mithdring"]
[Domains]
10: 10
10: 10.2.13.96
 I'm no expert but I think your domains are not set up correctly.
Your server will have a domain name that you have set, let's call it yourdomain for now.
What I would expect to see in in the [Domains] section is
[Domians]
yourdomain: yourdomain
yourdomain: yourdomain.com
yourdomain: 10.2.13.96
yourdomain: host
yourdomain: anything-else-you-want-to-be-delivered-locally.com
So yourdomain is the name of your local server, anything on the right is the domain name of any thing you want to deliver locally.
For example if you send mail to GeneralEmailAddress@10.2.13.96 or GeneralEmailAddress@yourdomain.com it will deliver it locally, if you send it to GeneralEmailAddress@yourdomain.co.uk it will assume it's non-local.
Hope that helps.
Dave
[quote user=&quot;Mithdring&quot;] &lt;P&gt;[Domains] 10: 10 10: 10.2.13.96&lt;/P&gt; &lt;P&gt;[/quote]&lt;/P&gt; &lt;P&gt;&amp;nbsp;I&#039;m no expert but I think your domains are not set up correctly.&lt;/P&gt; &lt;P&gt;Your server will have a domain name that you have set, let&#039;s call it yourdomain for now. What I would expect to see in in the [Domains] section is&lt;/P&gt; &lt;P&gt;[Domians] yourdomain: yourdomain yourdomain: yourdomain.com yourdomain: 10.2.13.96 yourdomain: host yourdomain: anything-else-you-want-to-be-delivered-locally.com&lt;/P&gt; &lt;P&gt;So yourdomain is the name of your local server, anything on the right is the domain name of any thing you want to deliver locally.&lt;/P&gt; &lt;P&gt;For example if you send mail to &lt;A href=&quot;mailto:GeneralEmailAddress@10.2.13.96&quot;&gt;GeneralEmailAddress@10.2.13.96&lt;/A&gt; or &lt;A href=&quot;mailto:GeneralEmailAddress@yourdomain.com&quot;&gt;GeneralEmailAddress@yourdomain.com&lt;/A&gt; it will deliver it locally, if you send it to &lt;A href=&quot;mailto:GeneralEmailAddress@yourdomain.co.uk&quot;&gt;GeneralEmailAddress@yourdomain.co.uk&lt;/A&gt; it will assume it&#039;s non-local.&lt;/P&gt; &lt;P&gt;Hope that helps.&lt;/P&gt; &lt;P&gt;Dave&lt;/P&gt;
It worked perfectly Dave, thanks!
Sometimes after I modify part of Mercury the SMTP server stops recieving messages and I have to overwrite the whole directory from an earlier directory that I saved and packed away.  Is this a common problem or am I just missing something?
&lt;P&gt;It worked perfectly Dave, thanks!&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;Sometimes after I modify part of Mercury the SMTP server stops recieving messages and I have to overwrite the whole directory from an earlier directory that I saved and packed away.&amp;nbsp; Is this a common problem or am I just missing something?&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt;
