I'm having problems when I move or delete multiple messages
in GMAIL/IMAP folders. I use other IMAP accounts and none are causing this
issue.
I can delete/move one message but as soon as I want to
process more than one, I usually get error messages. Most of the times, I have
to refresh the folder each time I want to move/delete.
Anyone using GMAIL imap connections experiencing this?
If you do use Pegasus 4.61 with GMAIL and do not have the issue, what
setup/configuration do you use?
Thank you.
        <p class="MsoNormal">I'm having problems when I move or delete multiple messages
issue.</p>
<p class="MsoNormal">I can delete/move one message but as soon as I want to
to refresh the folder each time I want to move/delete.</p>
<p class="MsoNormal">Anyone using GMAIL imap connections experiencing this?</p>
<p class="MsoNormal">If you do use Pegasus 4.61 with GMAIL and do not have the issue, what
setup/configuration do you use?</p><p class="MsoNormal">Thank you.</p>
