Web Admin Question
I have been hosting a trial of Mercury on a computer and have been using the Web Admin add-on to access the server tools.  Now that we have a license we have installed Mercury onto an actual computer and everything seems to be working fine, except for the Web Admin.  I can still access all the local mail boxes with the addon, but the server tools through the postmaster has some type of password on it and I cannot figure out where to set the password at.  Could someone tell me where this is?
It will simply use the Admin password in Mercury.
<p>It will simply use the Admin password in Mercury.</p><p>/Rolf </p>
Check Core configuration for "Username of postmaster" (defaults to Admin). It's the password for this user that you should use. If you don't remember it you can open the PASSWD.PM file in the mail folder for that user with Notepad and get it there.
<p>Check Core configuration for "Username of postmaster" (defaults to Admin). It's the password for this user that you should use. If you don't remember it you can open the PASSWD.PM file in the mail folder for that user with Notepad and get it there.</p><p>/Rolf </p>
