FWIW, I started having the same issue as the OP after upgrading IE to version 9 (even though I use Firefox, not IE Running Win7x64). The IERenderer install solved the problem. I rarely come here these days, so don't know if this is a commonly reported issue, but this thread popped out immediately. Thank you!!
-Ron
<p>FWIW, I started having the same issue as the OP after upgrading IE to version 9 (even though I use Firefox, not IE&nbsp; Running Win7x64).&nbsp; The IERenderer install solved the problem.&nbsp; I rarely come here these days, so don't know if this is a commonly reported issue, but this thread popped out immediately.&nbsp; Thank you!!</p><p>-Ron
