[quote user="RaspberryRipple"]Everytime I complete Set Up and get asked if I want the Tutorial. Windows tells me that there has been a problem and Pegasus stops working and closes. I am using Windows Vista. So what now?[/quote]
If you've got IE 9 installed on your system download and install the IERenderer update after completing Pegasus Mail's setup and launching it once (for creating its Registry entries). If the renderer setup fails (because of missing Registry entries due to the crashes) it might help to uninstall IERenderer first (via the control panel section for (un)installing all software, the entry is called Pegasus Mail HTML Renderer ...), then launch Pegasus Mail, close it and run the IERenderer update afterwards.
        <p>[quote user="RaspberryRipple"]Everytime I complete Set Up and get asked if I want the Tutorial. Windows tells me that there has been a problem and Pegasus stops working and closes. I am using Windows Vista. So what now?[/quote]</p><p>If you've got IE 9 installed on your system download and install the <a href="/forums/post/27909.aspx" mce_href="/forums/post/27909.aspx" target="_blank">IERenderer update</a> after completing Pegasus Mail's setup and launching it once (for creating its Registry entries). If the renderer setup fails (because of missing Registry entries due to the crashes) it might help to uninstall IERenderer first (via the control panel section for (un)installing all software, the entry is called <em>Pegasus Mail HTML Renderer ...</em>), then launch Pegasus Mail, close it and run the IERenderer update afterwards.</p>
