> So what I'm asking is "Is there a way of separating these uses of the
domain name assigned in the SMTP
> relay client or am I barking up the
wrong tree and I can change this value without breaking anything"
You are not ISP.NET so you should not use that in the Configuration | Mercury core "Internet name for this system" or a local domain. You should change this to something like mercury.isp.net or [<your IP address>] in the name of the system and in the domains. If you are receiving mail as user@isp.net using MercuryD then use an alias to point user@isp.net to user@mercury.isp.net or user@[<your IP address>]
You can also set MercuryC Announce myself as [<your IP address>] to solve the immediate problem.From the MercuryD help:
Announce myself as
The SMTP protocol has an identification phase, during which the client will tell the server its name. MercuryC will usually tell the server the name defined under Internet name for this system in the Mercury Core configuration dialog, but on rare cases you may need it to use a different name. If this is the case, enter that name here, otherwise leave this field blank. This option is inherently quite technical and you should enter a value here only if you are sure of what you are doing.
<p>&gt; So what I'm asking is "Is there a way of separating these uses of the
&gt; relay client or am I barking up the
wrong tree and I can change this value without breaking anything"</p><p>You are not ISP.NET so you should not use that in the Configuration |&nbsp; Mercury core "Internet name for this system" or a local domain.&nbsp; You should change this to something like mercury.isp.net or [&lt;your IP address&gt;] in the name of the system and in the domains.&nbsp; If you are receiving mail as user@isp.net using MercuryD then use an alias to point user@isp.net to user@mercury.isp.net or user@[&lt;your IP address&gt;]
</p><p>You can also set MercuryC&nbsp; Announce myself as [&lt;your IP address&gt;] to solve the immediate problem.From the MercuryD help:</p><p><b>Announce myself as</b>
</p><p><b>The SMTP protocol has an identification phase, during which the client will tell the server its name. MercuryC will usually tell the server the name defined under Internet name for this system in the Mercury Core configuration dialog, but on rare cases you may need it to use a different name. If this is the case, enter that name here, otherwise leave this field blank. This option is inherently quite technical and you should enter a value here only if you are sure of what you are doing.</b>
