Fonts and reading pain
Thank you very much .  That will help
<p>Thank you very much .  That will help</p><p>  </p>
Trying out Pegasus.  Tired of Thunderbird.  Filters just don't work
Quick question.  I have terrible eyesight and need way to adjust font in reading pain.  I don't want to set a certain font for every email as they never appear the same in every email.
Does Pegasus have the ability to adjust the reading pane size by doing something like ALT and then using the scroll wheel on mouse  or like Alt and then + or -?
Thank you for your time and replies
Todd
<p>Trying out Pegasus.  Tired of Thunderbird.  Filters just don't work</p><p>Quick question.  I have terrible eyesight and need way to adjust font in reading pain.  I don't want to set a certain font for every email as they never appear the same in every email.</p><p>Does Pegasus have the ability to adjust the reading pane size by doing something like ALT and then using the scroll wheel on mouse  or like Alt and then + or -?</p><p>Thank you for your time and replies</p><p> </p><p>Todd</p><p> </p><p> </p>
something like ALT
and then + or -?
For HTML use CTRL+PageUp/PageDown to change the font size.  You do not need this for plain text since they all use the font that you have set to display the message.
<p>> Does Pegasus have the ability to adjust the reading pane size by doing something like ALT > and then using the scroll wheel on mouse  or like Alt and then + or -?</p><p>For HTML use CTRL+PageUp/PageDown to change the font size.  You do not need this for plain text since they all use the font that you have set to display the message. </p>
