Scrolling new messages problem when it is HTML and no IERenederer loaded
[quote user="peggy"]When you deinstall the IERenderer (simply rename "IERenderer.fff" / "IERenderer.fde" when Pmail is closed) scrolling the open new messages with the mouse wheel do not work any more for new incoming messages, if the messages are HTML mails. ( no preview mode)[/quote]
Don't do this: If you mess around with these files IERenderer is not disabled, it simply falls back into BearHtml mode since it hasn't been properly initialized (which may cause unwanted side effects as you just encountered since IERenderer needs to implement some BearHtml related workarounds as well). If you want to uninstall IERenderer go to the control panel's uninstall page and use the (un)installer: As long as there's still a file called Renderer.pm IERenderer will not be disabled but only loaded "on demand" instead of on Pegasus Mail's startup. IOW: If you want to uninstall it use the (un)installer, if you want to disable it use its button menu, don't touch the files!
<p>[quote user="peggy"]When you deinstall the IERenderer (simply rename "IERenderer.fff" / "IERenderer.fde" when Pmail is closed) scrolling the open new messages with the mouse wheel do not work any more for new incoming messages, if the messages are HTML mails. ( no preview mode)[/quote]</p><p><em>Don't</em> do this: If you mess around with these files IERenderer is <em>not</em> disabled, it simply falls back into BearHtml mode since it hasn't been properly initialized (which may cause unwanted side effects as you just encountered since IERenderer needs to implement some BearHtml related workarounds as well). If you want to uninstall IERenderer go to the control panel's uninstall page and use the (un)installer: As long as there's still a file called Renderer.pm IERenderer will not be disabled but only loaded "on demand" instead of on Pegasus Mail's startup. IOW: If you want to uninstall it use the (un)installer, if you want to disable it use its button menu, don't touch the files!</p>
When you only disable the IERenderer at the config menue (not to use it) scrolling works.
WinPMail version: Version 4.62 (Win32), Aug 11 2011
Language resources: German Module by Sven Henze, v4.61 R1 (04 Feb 2011)
(Os WIN-XP Pro)
Bearhtml Version: 4.6.7.2
settings in Bearhtml.ini
ScrollPixels=20
ScrollRepeat=1
ScrollDelayMs=1
<FONT size=2 face=Arial><FONT size=2 face=Arial> <P>When you deinstall the IERenderer (simply rename "IERenderer.fff" / "IERenderer.fde" when Pmail is closed) scrolling the open new messages with the mouse wheel do not work any more for new incoming messages, if the messages are HTML mails. ( no preview mode)</P> <P>When you only disable the IERenderer at the config menue (not to use it) scrolling works. </P> <P>WinPMail version: Version 4.62 (Win32), Aug 11 2011</P> <P>Language resources: German Module by Sven Henze, v4.61 R1 (04 Feb 2011)</P> <P>(Os WIN-XP Pro) </P> <P>Bearhtml Version: 4.6.7.2</P> <P>settings in Bearhtml.ini</P> <P>ScrollPixels=20</P> <P>ScrollRepeat=1</P> <P>ScrollDelayMs=1</P> <P>......</P></FONT></FONT>
