[quote user="Thomas R. Stephenson"]> Uhm, sir as I said I can email to the users I created in Mercury using
> File> Send Mail Message ... in Mercury Mail..... also I can receive
> the emails that I sent using Pegasus which means POP3(receiving) is
> working in both Mercury and Pegasus.
Ok, Pegasus Mail send mail via Mercury in two ways,
1. Sends mail via the built in mailer to MercuryS using the Mercury/32 host name or IP address. This host name or IP address point to the system on the LAN, generally this is a non-routable IP address when the IP address is used. You can use Start | Run telnet <IP address> 25 to verify Mercury is receiving on this port. If port 25 is being blocked then set MercuryS to receive on port 587 and then telnet using this port after you re-boot Mercury. If you can connect via telnet then use that data for Pegasus Mail.
2. Sends mail via a User Defined Gateway (UDG) You use Configuration | Pegasus Mail ... In Mercury/32 to create the UDG. You can also manage this using pconfig.exe in the Pegasus Mail program directory and select the Mercury UDG. It will normally look like this.
Gateway name : [INTERNET ]
*New mail path :
Is a program to run? : N
*New mail search mask :
*Outgoing mail path : C:\MERCURY\QUEUE
*Run for outgoing mail :
*Filename format : ~d~d.PMX
Run to validate address :
*Reply address format : "~p" <~L~L~8@host.domain>
Accepts SMTP addresses? : Y
Simple message headers? : 'Glue' headers
UUEncode attachments? : Y
Burst messages? : N Gateway processes BCC? : N
Strip gateway name? : Y
Force all mail through? : N
The ~p is the personal name, ~8 the account name. You can also use ~p<~r> and the Reply to: address will be used.
> But when I try to send an email using Pegasus nothing happens (which
> means remains on the same page/ email page and no email sent).
If it cannot even send the mail to the queue then this means that Pegasus Mail cannot write the file to the queue. If Pegasus Mail cannot connect then this means the address used for the server is bad or the the port is blocked.
> No "connecting to" message in the bottom left part of the Pegasus
> interface either. Is this clear enough? Sorry and Thanks!!!
Actually this is still not clear. How are you trying to send the mail?
I'm using option number 1 sir, ..... I am sending mail through Pegasus SMTP here are the screens of my network settings in Pegasus:
Here are the links in case u couldnt see them here...
Mail Option Security Settings : http://flic.kr/p/av5V7d
Mail Option General Settings : http://flic.kr/p/av3dZ6
Internet Mail Options : http://flic.kr/p/av5V2L
Pegasus Mail Page : http://flic.kr/p/av3dU4
Is there something wrong here? Thank you .. I tried the telnet and it connected in port 25 so yes I think mercury and pegasus can connect and the port is not blocked... I think the network settings is the problem. Thank you for your patience!
<P>[quote user="Thomas R. Stephenson"]&gt; Uhm, sir as I said I can email to the users I created in Mercury using
&gt; File&gt; Send Mail Message ... in Mercury Mail..... also I can receive
&gt; the emails that I sent using Pegasus which means POP3(receiving) is
&gt; working in both Mercury and Pegasus.
1.&nbsp;&nbsp; &nbsp;Sends mail via the built in mailer to MercuryS using the Mercury/32 host name or IP address.&nbsp; This host name or IP address point to the system on the LAN, generally this is a non-routable IP address when the IP address is used.&nbsp; You can use Start | Run telnet &lt;IP address&gt; 25 to verify Mercury is receiving on this port.&nbsp; If port 25 is being blocked then set MercuryS to receive on port 587 and then telnet using this port after you re-boot Mercury.&nbsp; If you can connect via telnet then use that data for Pegasus Mail.
2.&nbsp;&nbsp; &nbsp;Sends mail via a User Defined Gateway (UDG)&nbsp; You use Configuration | Pegasus Mail ... In Mercury/32 to create the UDG.&nbsp; You can also manage this using pconfig.exe in the Pegasus Mail program directory and select the Mercury UDG.&nbsp; It will normally look like this.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Gateway name : [INTERNET&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; *New mail path :
&nbsp;&nbsp;&nbsp; Is a program to run? :&nbsp; N
&nbsp;&nbsp;&nbsp;&nbsp; *New mail search mask :
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; *Outgoing mail path :&nbsp; C:\MERCURY\QUEUE
&nbsp;&nbsp;&nbsp; *Run for outgoing mail :
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; *Filename format :&nbsp; ~d~d.PMX
&nbsp;&nbsp; Run to validate address :
&nbsp;&nbsp;&nbsp;&nbsp; *Reply address format :&nbsp; "~p" &lt;~L~L~8@host.domain&gt;
&nbsp;&nbsp; Accepts SMTP addresses? :&nbsp; Y
&nbsp;&nbsp; Simple message headers? :&nbsp; 'Glue' headers
&nbsp;&nbsp;&nbsp;&nbsp; UUEncode attachments? :&nbsp; Y
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Burst messages? :&nbsp; N&nbsp;&nbsp;&nbsp; Gateway processes BCC? : N
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Strip gateway name? :&nbsp; Y
&nbsp;&nbsp; Force all mail through? :&nbsp; N
The ~p is the personal name, ~8 the account name.&nbsp; You can also use ~p&lt;~r&gt; and the Reply to: address will be used. &nbsp;
&gt; But when I try to send an email using Pegasus nothing happens (which
&gt; means remains on the same page/ email page and no email sent).
If it cannot even send the mail to the queue then this means that Pegasus Mail cannot write the file to the queue.&nbsp; If Pegasus Mail cannot connect then this means the address used for the server is bad or the the port is blocked.
&gt; No "connecting to" message in the bottom left part of the Pegasus
&gt; interface either. Is this clear enough? Sorry and Thanks!!!
Actually this is still not clear.&nbsp; How are you trying to send the mail? &nbsp;
[/quote]</P>
<P>I'm using option number 1 sir, ..... I am sending mail through Pegasus SMTP here are the screens of my network settings in Pegasus:</P>
<P><IMG style="WIDTH: 200px; HEIGHT: 150px" title="Mail Option Security Settings" border=1 hspace=1 alt="Mail Option Security Settings" vspace=1 src="http://www.flickr.com/photos/68557535@N03/6236348396/" width=200 height=150 mce_src="http://www.flickr.com/photos/68557535@N03/6236348396/">&nbsp;<IMG style="WIDTH: 200px; HEIGHT: 150px" title="Mail Option General Settings" border=1 hspace=1 alt="Mail Option General Settings" vspace=1 src="http://flic.kr/p/av3dZ6" width=200 height=150 mce_src="http://flic.kr/p/av3dZ6">&nbsp;<IMG style="WIDTH: 200px; HEIGHT: 150px" title=InternetMailOptions border=1 hspace=1 alt=InternetMailOptions vspace=1 src="http://flic.kr/p/av5V2L" width=200 height=150 mce_src="http://flic.kr/p/av5V2L">&nbsp;<IMG style="WIDTH: 200px; HEIGHT: 150px" title="Pegasus Mail Page" border=1 hspace=1 alt="Pegasus Mail Page" vspace=1 src="http://flic.kr/p/av3dU4" width=200 height=150 mce_src="http://flic.kr/p/av3dU4"></P>
<P>Here are the links in case u couldnt see them here... </P>
<P>Mail Option Security Settings : <A href="http://flic.kr/p/av5V7d">http://flic.kr/p/av5V7d</A></P>
<P>Mail Option General Settings : <A href="http://flic.kr/p/av3dZ6">http://flic.kr/p/av3dZ6</A></P>
<P>Internet Mail Options : <A href="http://flic.kr/p/av5V2L">http://flic.kr/p/av5V2L</A></P>
<P>Pegasus Mail Page : <A href="http://flic.kr/p/av3dU4">http://flic.kr/p/av3dU4</A></P>
<P>Is there something wrong here? Thank you .. I tried the telnet and it connected in port 25 so yes I think mercury and pegasus can connect and the port is not blocked... I think the network settings is the problem. Thank you for your patience!</P>
