Pegasus 4.62 displays empty mail body
You're right. Anyhow, thanks again.
 Arthur
<p>You're right. Anyhow, thanks again.</p><p> Arthur <img src="http://community.pmail.com/emoticons/emotion-1.gif"></p>
I recently updated to Pegasus 4.62. Since then some of the mails I receive don't show their message in the mail message body, but leave this body entirely blank. I have to either forward such a message to my own mail adress or to switch to ther "raw view" in order to read its content. I presume that this problem has something to do with the message format for if I send a message in "rich text" format to myself I encounter the same problem. I have tried to solve this problem by changing various settings but so far to no avail. I would appreciate if anybody could give me any clue as to how I might solve this problem.
Which format do those messages have?
Did you activate MIME (it's in the options in outgoing messages)?
bye   Olaf
<p>Which format do those messages have? </p><p>Did you activate MIME (it's in the options in outgoing messages)?</p><p>bye   Olaf</p><p> </p>
The MIME option is activated.
I'm not sure about the format. I assume HTML, since I encounter the same problem with test e-mails to my own e-mail adress when I use "rich text" format.
Bye Arthur
<p>The MIME option is activated. </p><p>I'm not sure about the format. I assume HTML, since I encounter the same problem with test e-mails to my own e-mail adress when I use "rich text" format. </p><p>Bye Arthur </p>
[quote user="kayser_ad"]I recently updated to Pegasus 4.62. Since then some of the mails I receive don't show their message in the mail message body, but leave this body entirely blank.[/quote]
See this thread for possible solutions.
<p>[quote user="kayser_ad"]I recently updated to Pegasus 4.62. Since then some of the mails I receive don't show their message in the mail message body, but leave this body entirely blank.[/quote]</p><p>See <a href="/forums/thread/31758.aspx" mce_href="/forums/thread/31758.aspx" target="_blank">this thread</a> for possible solutions.</p>
Hi Michael,
Thanks for your thread. The solution for my problem was already given by "Terry in Oz" on August, 11. It turns out that not Pegasus, but AVG causes the problem which can easily be solved by turning off the Certification Message that it issues.
<p>Hi Michael,</p><p> </p><p>Thanks for your thread. The solution for my problem was already given by "<u>Terry in Oz" </u>on August, 11. It turns out that not Pegasus, but AVG causes the problem which can easily be solved by turning off the Certification Message that it issues. </p>
[quote user="kayser_ad"]The solution for my problem was already given by "Terry in Oz" on August, 11.[/quote]
Actually November, 8th ...[;)]
<p>[quote user="kayser_ad"]The solution for my problem was already given by "<u>Terry in Oz" </u>on August, 11.[/quote]</p><p>Actually November, 8th ...[;)]</p>
