Hi, Thanks for the answer
I try again.
Core config is: internet name 87.57.133.33,
local domain:localhost - localhost
localhost - [87.57.133.33] (dynamic ipadress from ISP)
localhost - local.com ( just a testsite for magento)
MercuryC config is:
smarthost name: my realworld ISP's SMTPserver
conn.port: 587 ( my realworld ISP's SMTPport)
Actually, with this I can send testmessage from mercury, but I still get errors!?
I am using this for a testsite in magento and need to test mail sending from the system before I go live!
Here is the sessions log from mercuryC:
20:34:21.796: --- Wed Nov 30 20:34:21 2011 ---
20:34:22.796: Connect to 'asmtp.mail.dk', timeout 30.
20:34:23.921: >> 220 Welcome to asmtp.mail.dk!<cr><lf>
20:34:23.921: << EHLO 87.57.133.33<cr><lf>
20:34:23.953: >> 250-fep41.mail.dk says EHLO to 87.57.135.17:23780<cr><lf>
20:34:23.968: >> 250-PIPELINING<cr><lf>
20:34:23.968: >> 250-ENHANCEDSTATUSCODES<cr><lf>
20:34:23.968: >> 250-AUTH=PLAIN LOGIN<cr><lf>
20:34:23.968: >> 250-AUTH PLAIN LOGIN<cr><lf>
20:34:23.968: >> 250 8BITMIME<cr><lf>
20:34:23.968: << AUTH LOGIN<cr><lf>
// removed !!!!
20:34:23.125: >> 235 Authed. Go on.<cr><lf>
20:34:23.125: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.296: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.296: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.359: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.375: << RSET<cr><lf>
20:34:23.390: >> 250 RSET OK<cr><lf>
20:34:23.390: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.421: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.421: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.453: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.468: << RSET<cr><lf>
20:34:23.500: >> 250 RSET OK<cr><lf>
20:34:23.500: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.531: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.531: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.562: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.578: << RSET<cr><lf>
20:34:23.593: >> 250 RSET OK<cr><lf>
20:34:23.609: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.640: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.640: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.671: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.687: << RSET<cr><lf>
20:34:23.703: >> 250 RSET OK<cr><lf>
20:34:23.703: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.734: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.750: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.765: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.796: << RSET<cr><lf>
20:34:24.812: >> 250 RSET OK<cr><lf>
20:34:24.812: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.843: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.859: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.875: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.890: << RSET<cr><lf>
20:34:24.921: >> 250 RSET OK<cr><lf>
20:34:24.921: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.953: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.953: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.984: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.015: << RSET<cr><lf>
20:34:24.046: >> 250 RSET OK<cr><lf>
20:34:24.046: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.078: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.078: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.109: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.125: << RSET<cr><lf>
20:34:24.156: >> 250 RSET OK<cr><lf>
20:34:24.156: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.187: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.187: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.218: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.234: << RSET<cr><lf>
20:34:24.265: >> 250 RSET OK<cr><lf>
20:34:24.265: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.296: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.296: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.328: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.343: << RSET<cr><lf>
20:34:24.375: >> 250 RSET OK<cr><lf>
20:34:24.375: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.406: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.406: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.437: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.453: << RSET<cr><lf>
20:34:24.484: >> 250 RSET OK<cr><lf>
20:34:24.484: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.515: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.515: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.546: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.562: << RSET<cr><lf>
20:34:24.593: >> 250 RSET OK<cr><lf>
20:34:24.593: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.625: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.625: << RCPT TO:<xxx@xx.xx><cr><lf>
20:34:24.656: >> 250 RCPT TO accepted<cr><lf>
20:34:24.671: << DATA<cr><lf>
20:34:24.687: >> 354 continue. finished with "\r\n.\r\n"<cr><lf>
20:34:24.703: << Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO000029;<cr><lf> 30 Nov 2011 20:34:24 +0100<cr><lf>
20:34:24.703: << Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100<cr><lf>
20:34:24.703: << From: "E-Mail Administrator" <postmaster@["192.168.177.176"]><cr><lf>
20:34:24.703: << To: xxx@xx.xx<cr><lf>
20:34:24.703: << Subject: test<cr><lf>
20:34:24.703: << Date: Wed, 23 Nov 2011 21:15:37 +0100<cr><lf>
20:34:24.718: << MIME-Version: 1.0<cr><lf>
20:34:24.718: << Content-type: Text/plain; charset=US-ASCII<cr><lf>
20:34:24.718: << Message-ID: <C0D4FE7.4ECD627C.0009@["192.168.177.176"]><cr><lf>
20:34:24.718: << <cr><lf>
20:34:24.718: << the product currently ran agencies going building sites agencies code legitimate <cr><lf>
20:34:24.718: << The files vulnerable taking that attacks patches and also there need asked <cr><lf>
20:34:24.734: << and hundred attacks ubiquitous north attacks attacks north strings malicious <cr><lf>
20:34:24.734: << that to are The helps welcome and injected hundred are vulnerable as across <cr><lf>
20:34:24.734: << <cr><lf>
20:34:24.734: << in to to longest hundred patches also no institutions vulnerable dedicate <cr><lf>
20:34:24.734: << building quick hundred ran welcome in across to security technique institutions <cr><lf>
20:34:24.734: << organizations bugs files also institutions to there haunted are and reside <cr><lf>
20:34:24.750: << into other the financial that making patches range comprehensive are need <cr><lf>
20:34:24.750: << attacks system for institutions are technique ran agencies making security <cr><lf>
20:34:24.750: << currently comprehensive to attacks patches no injected security vulnerable <cr><lf>
20:34:24.750: << <cr><lf>
20:34:24.750: << by ubiquitous in into which known applets haunted the building ran operated <cr><lf>
20:34:24.750: << patches movies organizations movies other welcome bugs building dedicate <cr><lf>
20:34:24.750: << Internet dedicate for security product reside The ubiquitous institutions <cr><lf>
20:34:24.750: << currently sites sites vulnerable quick going that taking hundred no product <cr><lf>
20:34:24.750: << are and files scripting are helps code helps need ubiquitous through by <cr><lf>
20:34:24.750: << graphics going helps found blocks other asked organizations the are taking <cr><lf>
20:34:24.765: << agencies security graphics and financial are dedicate blocks code range <cr><lf>
20:34:24.765: << <cr><lf>
20:34:24.765: << taking making currently found product need there movies security The sites <cr><lf>
20:34:24.765: << haunted range asked the files injected malicious range bugs into across <cr><lf>
20:34:24.765: << files attacks product the also bugs to The vulnerable security bugs The <cr><lf>
20:34:24.765: << currently which need asked as malicious quick scripting are asked taking <cr><lf>
20:34:24.765: << currently to dedicate are taking in also by strings currently also haunted <cr><lf>
20:34:24.765: << into asked scripting strings patches financial going that bugs free in <cr><lf>
20:34:24.765: << ran agencies injected attacks government code ubiquitous attacks ran bugs <cr><lf>
20:34:24.765: << which north they them making found helps product building operated injected <cr><lf>
20:34:24.765: << in scripting are agencies and making Internet are sites graphics them graphics <cr><lf>
20:34:24.781: << need the helps strings into hundred The to in found applets going institutions <cr><lf>
20:34:24.781: << no in going blocks across which as operated animate security system hundred <cr><lf>
20:34:24.781: << <cr><lf>
20:34:24.781: << them applets Internet also into longest other vulnerable them through Internet <cr><lf>
20:34:24.781: << longest by there operated need the need there <cr><lf>
20:34:24.781: << .<cr><lf>
20:34:25.875: >> 250 OK A0/50-11301-14586DE4<cr><lf>
20:34:25.875: << RSET<cr><lf>
20:34:25.906: >> 250 RSET OK<cr><lf>
20:34:25.906: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:25.937: >> 250 MAIL FROM accepted<cr><lf>
20:34:25.937: << RCPT TO:<xxx@xx.xx><cr><lf>
20:34:25.968: >> 250 RCPT TO accepted<cr><lf>
20:34:25.968: << DATA<cr><lf>
20:34:25.000: >> 354 continue. finished with "\r\n.\r\n"<cr><lf>
20:34:25.000: << Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002A;<cr><lf> 30 Nov 2011 20:34:25 +0100<cr><lf>
20:34:25.015: << Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100<cr><lf>
20:34:25.015: << From: "E-Mail Administrator" <postmaster@["192.168.177.176"]><cr><lf>
20:34:25.015: << To: xxx@xx.xx<cr><lf>
20:34:25.015: << Subject: test<cr><lf>
20:34:25.015: << Date: Wed, 23 Nov 2011 21:15:37 +0100<cr><lf>
20:34:25.031: << MIME-Version: 1.0<cr><lf>
20:34:25.031: << Content-type: Text/plain; charset=US-ASCII<cr><lf>
20:34:25.031: << Message-ID: <C0D5026.4ECD627C.000A@["192.168.177.176"]><cr><lf>
20:34:25.031: << <cr><lf>
20:34:25.031: << found found graphics technique building agencies by vulnerable reside found <cr><lf>
20:34:25.046: << ubiquitous asked scripting technique ubiquitous welcome security welcome <cr><lf>
20:34:25.046: << <cr><lf>
20:34:25.046: << in agencies helps blocks through by which to are system across the are <cr><lf>
20:34:25.046: << and no as ran across in comprehensive ran files quick malicious security <cr><lf>
20:34:25.046: << them reside ubiquitous to vulnerable ubiquitous attacks currently security <cr><lf>
20:34:25.046: << patches operated no to vulnerable legitimate ubiquitous code north range <cr><lf>
20:34:25.062: << comprehensive are other applets The system which technique making asked <cr><lf>
20:34:25.062: << legitimate security making the product across are files other animate Internet <cr><lf>
20:34:25.062: << <cr><lf>
20:34:25.078: << files organizations files ubiquitous are graphics and in hundred institutions <cr><lf>
20:34:25.078: << <cr><lf>
20:34:25.078: << quick into sites patches are reside asked injected agencies hundred need <cr><lf>
20:34:25.093: << north range making found also going building and are ran security graphics <cr><lf>
20:34:25.093: << them strings vulnerable and product scripting malicious and comprehensive <cr><lf>
20:34:25.093: << injected range reside comprehensive code in The and into currently The <cr><lf>
20:34:25.093: << quick as currently taking asked across helps technique across animate agencies <cr><lf>
20:34:25.093: << and government which them The by financial building the to injected dedicate <cr><lf>
20:34:25.093: << helps patches injected product comprehensive the blocks asked attacks there <cr><lf>
20:34:25.093: << <cr><lf>
20:34:25.093: << patches product to are comprehensive dedicate going found sites as into <cr><lf>
20:34:25.093: << building legitimate no range and blocks the other free through patches <cr><lf>
20:34:25.093: << into for graphics The comprehensive scripting haunted other through north <cr><lf>
20:34:25.093: << in north in across that need known hundred as blocks they The free helps <cr><lf>
20:34:25.109: << security taking in ran range building in the graphics which by the asked <cr><lf>
20:34:25.109: << by patches ran building and which going injected animate ubiquitous blocks <cr><lf>
20:34:25.109: << also haunted institutions which which welcome helps ubiquitous organizations <cr><lf>
20:34:25.109: << making through that legitimate injected operated found by that found making <cr><lf>
20:34:25.109: << <cr><lf>
20:34:25.109: << animate quick scripting they are no security to blocks found ran hundred <cr><lf>
20:34:25.109: << they haunted also animate graphics sites them government dedicate for attacks <cr><lf>
20:34:25.109: << asked also and in ran they welcome making animate patches reside attacks <cr><lf>
20:34:25.109: << the bugs code haunted dedicate hundred making as organizations quick which <cr><lf>
20:34:25.109: << found as as attacks technique also are free scripting comprehensive scripting <cr><lf>
20:34:25.109: << .<cr><lf>
20:34:25.203: >> 250 OK B0/50-11301-24586DE4<cr><lf>
20:34:25.218: << RSET<cr><lf>
20:34:25.250: >> 250 RSET OK<cr><lf>
20:34:25.250: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:25.281: >> 250 MAIL FROM accepted<cr><lf>
20:34:25.281: << RCPT TO:<xxx@xx.xx><cr><lf>
20:34:25.312: >> 250 RCPT TO accepted<cr><lf>
20:34:25.328: << DATA<cr><lf>
20:34:25.359: >> 354 continue. finished with "\r\n.\r\n"<cr><lf>
20:34:25.359: << Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002E;<cr><lf> 30 Nov 2011 20:34:25 +0100<cr><lf>
20:34:25.359: << Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100<cr><lf>
20:34:25.359: << From: "E-Mail Administrator" <postmaster@["192.168.177.176"]><cr><lf>
20:34:25.375: << To: xxx@xx.xx<cr><lf>
20:34:25.375: << Subject: test<cr><lf>
20:34:25.375: << Date: Wed, 23 Nov 2011 21:15:37 +0100<cr><lf>
20:34:25.375: << MIME-Version: 1.0<cr><lf>
20:34:25.375: << Content-type: Text/plain; charset=US-ASCII<cr><lf>
20:34:25.375: << Message-ID: <C0D51AC.4ECD627C.000E@["192.168.177.176"]><cr><lf>
20:34:25.375: << <cr><lf>
20:34:25.375: << reside blocks technique there found the asked the range operated known <cr><lf>
20:34:25.375: << currently they them patches the bugs helps institutions the security organizations <cr><lf>
20:34:25.390: << haunted helps animate the ran in and hundred movies that animate ubiquitous <cr><lf>
20:34:25.390: << institutions building as need no other dedicate and animate strings across <cr><lf>
20:34:25.390: << <cr><lf>
20:34:25.390: << malicious welcome by currently ran currently helps for for across and asked <cr><lf>
20:34:25.390: << known to haunted vulnerable technique institutions product product graphics <cr><lf>
20:34:25.390: << technique patches range to sites no into ran graphics movies for dedicate <cr><lf>
20:34:25.390: << in making they injected taking there quick ran institutions them asked <cr><lf>
20:34:25.390: << scripting there organizations legitimate there government which vulnerable <cr><lf>
20:34:25.406: << security the ran no comprehensive across organizations free by bugs reside <cr><lf>
20:34:25.406: << government patches making institutions also graphics animate by comprehensive <cr><lf>
20:34:25.406: << currently government and free taking the injected quick haunted code graphics <cr><lf>
20:34:25.406: << product north haunted product ran currently vulnerable haunted animate <cr><lf>
20:34:25.406: << <cr><lf>
20:34:25.406: << across scripting by scripting comprehensive vulnerable blocks that ran <cr><lf>
20:34:25.406: << haunted asked range animate scripting applets are and security patches <cr><lf>
20:34:25.406: << found free north found quick for legitimate blocks also asked which comprehensive <cr><lf>
20:34:25.421: << the code haunted ran The range the into applets need organizations through <cr><lf>
20:34:25.421: << making legitimate quick The and ran making technique security to making <cr><lf>
20:34:25.421: << <cr><lf>
20:34:25.421: << quick taking blocks currently which need helps across injected them and <cr><lf>
20:34:25.421: << they system Internet product sites in making building malicious legitimate <cr><lf>
20:34:25.421: << are <cr><lf>
20:34:25.421: << .<cr><lf>
20:34:25.500: >> 250 OK D0/50-11301-24586DE4<cr><lf>
20:34:25.515: << RSET<cr><lf>
20:34:25.546: >> 250 RSET OK<cr><lf>
20:34:25.546: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:25.578: >> 421 4.5.1 No more messages on this connection, se venligst http://postmaster.tdc.dk/publish.php?id=23413<cr><lf>
20:34:25.593: << RSET<cr><lf>
20:34:25.609: << QUIT<cr><lf>
20:34:25.609: --- Connection closed normally at Wed Nov 30 20:34:25 2011. ---
20:34:25.609:
<p>Hi, Thanks for the answer</p><p>I try again.</p><p>Core config is: internet name 87.57.133.33,&nbsp;
MercuryC config is:
conn.port: 587 ( my realworld ISP's SMTPport)</p><p>
</p><p>Actually, with this I can send testmessage from mercury, but I still get errors!?</p><p>
</p><p>I am using this for a testsite in magento and need to test mail sending from the system before I go live!
</p><p>
</p><p>Here is the sessions log from mercuryC:</p><p>20:34:21.796: --- Wed Nov 30 20:34:21 2011 ---
20:34:23.921: &gt;&gt; 220 Welcome to asmtp.mail.dk!&lt;cr&gt;&lt;lf&gt;
20:34:23.921: &lt;&lt; EHLO 87.57.133.33&lt;cr&gt;&lt;lf&gt;
20:34:23.953: &gt;&gt; 250-fep41.mail.dk says EHLO to 87.57.135.17:23780&lt;cr&gt;&lt;lf&gt;
20:34:23.968: &gt;&gt; 250-PIPELINING&lt;cr&gt;&lt;lf&gt;
20:34:23.968: &gt;&gt; 250-ENHANCEDSTATUSCODES&lt;cr&gt;&lt;lf&gt;
20:34:23.968: &gt;&gt; 250-AUTH=PLAIN LOGIN&lt;cr&gt;&lt;lf&gt;
20:34:23.968: &gt;&gt; 250-AUTH PLAIN LOGIN&lt;cr&gt;&lt;lf&gt;
20:34:23.968: &gt;&gt; 250 8BITMIME&lt;cr&gt;&lt;lf&gt;
20:34:23.968: &lt;&lt; AUTH LOGIN&lt;cr&gt;&lt;lf&gt;
// removed !!!!
20:34:23.125: &gt;&gt; 235 Authed. Go on.&lt;cr&gt;&lt;lf&gt;
20:34:23.125: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.296: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:23.296: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.359: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:23.375: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:23.390: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:23.390: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.421: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:23.421: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.453: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:23.468: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:23.500: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:23.500: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.531: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:23.531: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.562: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:23.578: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:23.593: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:23.609: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.640: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:23.640: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.671: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:23.687: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:23.703: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:23.703: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.734: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:23.750: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:23.765: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:23.796: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.812: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.812: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.843: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.859: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.875: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.890: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.921: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.921: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.953: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.953: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.984: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.015: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.046: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.046: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.078: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.078: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.109: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.125: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.156: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.156: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.187: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.187: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.218: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.234: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.265: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.265: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.296: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.296: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.328: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.343: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.375: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.375: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.406: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.406: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.437: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.453: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.484: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.484: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.515: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.515: &lt;&lt; RCPT TO:&lt;Admin@87.57.133.33&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.546: &gt;&gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&lt;cr&gt;&lt;lf&gt;
20:34:24.562: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:24.593: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:24.593: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.625: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.625: &lt;&lt; RCPT TO:&lt;xxx@xx.xx&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.656: &gt;&gt; 250 RCPT TO accepted&lt;cr&gt;&lt;lf&gt;
20:34:24.671: &lt;&lt; DATA&lt;cr&gt;&lt;lf&gt;
20:34:24.687: &gt;&gt; 354 continue. finished with "\r\n.\r\n"&lt;cr&gt;&lt;lf&gt;
20:34:24.703: &lt;&lt; Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO000029;&lt;cr&gt;&lt;lf&gt; 30 Nov 2011 20:34:24 +0100&lt;cr&gt;&lt;lf&gt;
20:34:24.703: &lt;&lt; Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100&lt;cr&gt;&lt;lf&gt;
20:34:24.703: &lt;&lt; From: "E-Mail Administrator" &lt;postmaster@["192.168.177.176"]&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.703: &lt;&lt; To: xxx@xx.xx&lt;cr&gt;&lt;lf&gt;
20:34:24.703: &lt;&lt; Subject: test&lt;cr&gt;&lt;lf&gt;
20:34:24.703: &lt;&lt; Date: Wed, 23 Nov 2011 21:15:37 +0100&lt;cr&gt;&lt;lf&gt;
20:34:24.718: &lt;&lt; MIME-Version: 1.0&lt;cr&gt;&lt;lf&gt;
20:34:24.718: &lt;&lt; Content-type: Text/plain; charset=US-ASCII&lt;cr&gt;&lt;lf&gt;
20:34:24.718: &lt;&lt; Message-ID: &lt;C0D4FE7.4ECD627C.0009@["192.168.177.176"]&gt;&lt;cr&gt;&lt;lf&gt;
20:34:24.718: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:24.718: &lt;&lt; the product currently ran agencies going building sites agencies code legitimate &lt;cr&gt;&lt;lf&gt;
20:34:24.718: &lt;&lt; The files vulnerable taking that attacks patches and also there need asked &lt;cr&gt;&lt;lf&gt;
20:34:24.734: &lt;&lt; and hundred attacks ubiquitous north attacks attacks north strings malicious &lt;cr&gt;&lt;lf&gt;
20:34:24.734: &lt;&lt; that to are The helps welcome and injected hundred are vulnerable as across &lt;cr&gt;&lt;lf&gt;
20:34:24.734: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:24.734: &lt;&lt; in to to longest hundred patches also no institutions vulnerable dedicate &lt;cr&gt;&lt;lf&gt;
20:34:24.734: &lt;&lt; building quick hundred ran welcome in across to security technique institutions &lt;cr&gt;&lt;lf&gt;
20:34:24.734: &lt;&lt; organizations bugs files also institutions to there haunted are and reside &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; into other the financial that making patches range comprehensive are need &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; attacks system for institutions are technique ran agencies making security &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; currently comprehensive to attacks patches no injected security vulnerable &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; by ubiquitous in into which known applets haunted the building ran operated &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; patches movies organizations movies other welcome bugs building dedicate &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; Internet dedicate for security product reside The ubiquitous institutions &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; currently sites sites vulnerable quick going that taking hundred no product &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; are and files scripting are helps code helps need ubiquitous through by &lt;cr&gt;&lt;lf&gt;
20:34:24.750: &lt;&lt; graphics going helps found blocks other asked organizations the are taking &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; agencies security graphics and financial are dedicate blocks code range &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; taking making currently found product need there movies security The sites &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; haunted range asked the files injected malicious range bugs into across &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; files attacks product the also bugs to The vulnerable security bugs The &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; currently which need asked as malicious quick scripting are asked taking &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; currently to dedicate are taking in also by strings currently also haunted &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; into asked scripting strings patches financial going that bugs free in &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; ran agencies injected attacks government code ubiquitous attacks ran bugs &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; which north they them making found helps product building operated injected &lt;cr&gt;&lt;lf&gt;
20:34:24.765: &lt;&lt; in scripting are agencies and making Internet are sites graphics them graphics &lt;cr&gt;&lt;lf&gt;
20:34:24.781: &lt;&lt; need the helps strings into hundred The to in found applets going institutions &lt;cr&gt;&lt;lf&gt;
20:34:24.781: &lt;&lt; no in going blocks across which as operated animate security system hundred &lt;cr&gt;&lt;lf&gt;
20:34:24.781: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:24.781: &lt;&lt; them applets Internet also into longest other vulnerable them through Internet &lt;cr&gt;&lt;lf&gt;
20:34:24.781: &lt;&lt; longest by there operated need the need there &lt;cr&gt;&lt;lf&gt;
20:34:24.781: &lt;&lt; .&lt;cr&gt;&lt;lf&gt;
20:34:25.875: &gt;&gt; 250 OK A0/50-11301-14586DE4&lt;cr&gt;&lt;lf&gt;
20:34:25.875: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:25.906: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:25.906: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.937: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:25.937: &lt;&lt; RCPT TO:&lt;xxx@xx.xx&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.968: &gt;&gt; 250 RCPT TO accepted&lt;cr&gt;&lt;lf&gt;
20:34:25.968: &lt;&lt; DATA&lt;cr&gt;&lt;lf&gt;
20:34:25.000: &gt;&gt; 354 continue. finished with "\r\n.\r\n"&lt;cr&gt;&lt;lf&gt;
20:34:25.000: &lt;&lt; Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002A;&lt;cr&gt;&lt;lf&gt; 30 Nov 2011 20:34:25 +0100&lt;cr&gt;&lt;lf&gt;
20:34:25.015: &lt;&lt; Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100&lt;cr&gt;&lt;lf&gt;
20:34:25.015: &lt;&lt; From: "E-Mail Administrator" &lt;postmaster@["192.168.177.176"]&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.015: &lt;&lt; To: xxx@xx.xx&lt;cr&gt;&lt;lf&gt;
20:34:25.015: &lt;&lt; Subject: test&lt;cr&gt;&lt;lf&gt;
20:34:25.015: &lt;&lt; Date: Wed, 23 Nov 2011 21:15:37 +0100&lt;cr&gt;&lt;lf&gt;
20:34:25.031: &lt;&lt; MIME-Version: 1.0&lt;cr&gt;&lt;lf&gt;
20:34:25.031: &lt;&lt; Content-type: Text/plain; charset=US-ASCII&lt;cr&gt;&lt;lf&gt;
20:34:25.031: &lt;&lt; Message-ID: &lt;C0D5026.4ECD627C.000A@["192.168.177.176"]&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.031: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.031: &lt;&lt; found found graphics technique building agencies by vulnerable reside found &lt;cr&gt;&lt;lf&gt;
20:34:25.046: &lt;&lt; ubiquitous asked scripting technique ubiquitous welcome security welcome &lt;cr&gt;&lt;lf&gt;
20:34:25.046: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.046: &lt;&lt; in agencies helps blocks through by which to are system across the are &lt;cr&gt;&lt;lf&gt;
20:34:25.046: &lt;&lt; and no as ran across in comprehensive ran files quick malicious security &lt;cr&gt;&lt;lf&gt;
20:34:25.046: &lt;&lt; them reside ubiquitous to vulnerable ubiquitous attacks currently security &lt;cr&gt;&lt;lf&gt;
20:34:25.046: &lt;&lt; patches operated no to vulnerable legitimate ubiquitous code north range &lt;cr&gt;&lt;lf&gt;
20:34:25.062: &lt;&lt; comprehensive are other applets The system which technique making asked &lt;cr&gt;&lt;lf&gt;
20:34:25.062: &lt;&lt; legitimate security making the product across are files other animate Internet &lt;cr&gt;&lt;lf&gt;
20:34:25.062: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.078: &lt;&lt; files organizations files ubiquitous are graphics and in hundred institutions &lt;cr&gt;&lt;lf&gt;
20:34:25.078: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.078: &lt;&lt; quick into sites patches are reside asked injected agencies hundred need &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; north range making found also going building and are ran security graphics &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; them strings vulnerable and product scripting malicious and comprehensive &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; injected range reside comprehensive code in The and into currently The &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; quick as currently taking asked across helps technique across animate agencies &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; and government which them The by financial building the to injected dedicate &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; helps patches injected product comprehensive the blocks asked attacks there &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; patches product to are comprehensive dedicate going found sites as into &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; building legitimate no range and blocks the other free through patches &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; into for graphics The comprehensive scripting haunted other through north &lt;cr&gt;&lt;lf&gt;
20:34:25.093: &lt;&lt; in north in across that need known hundred as blocks they The free helps &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; security taking in ran range building in the graphics which by the asked &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; by patches ran building and which going injected animate ubiquitous blocks &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; also haunted institutions which which welcome helps ubiquitous organizations &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; making through that legitimate injected operated found by that found making &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; animate quick scripting they are no security to blocks found ran hundred &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; they haunted also animate graphics sites them government dedicate for attacks &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; asked also and in ran they welcome making animate patches reside attacks &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; the bugs code haunted dedicate hundred making as organizations quick which &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; found as as attacks technique also are free scripting comprehensive scripting &lt;cr&gt;&lt;lf&gt;
20:34:25.109: &lt;&lt; .&lt;cr&gt;&lt;lf&gt;
20:34:25.203: &gt;&gt; 250 OK B0/50-11301-24586DE4&lt;cr&gt;&lt;lf&gt;
20:34:25.218: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:25.250: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:25.250: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.281: &gt;&gt; 250 MAIL FROM accepted&lt;cr&gt;&lt;lf&gt;
20:34:25.281: &lt;&lt; RCPT TO:&lt;xxx@xx.xx&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.312: &gt;&gt; 250 RCPT TO accepted&lt;cr&gt;&lt;lf&gt;
20:34:25.328: &lt;&lt; DATA&lt;cr&gt;&lt;lf&gt;
20:34:25.359: &gt;&gt; 354 continue. finished with "\r\n.\r\n"&lt;cr&gt;&lt;lf&gt;
20:34:25.359: &lt;&lt; Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002E;&lt;cr&gt;&lt;lf&gt; 30 Nov 2011 20:34:25 +0100&lt;cr&gt;&lt;lf&gt;
20:34:25.359: &lt;&lt; Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100&lt;cr&gt;&lt;lf&gt;
20:34:25.359: &lt;&lt; From: "E-Mail Administrator" &lt;postmaster@["192.168.177.176"]&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; To: xxx@xx.xx&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; Subject: test&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; Date: Wed, 23 Nov 2011 21:15:37 +0100&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; MIME-Version: 1.0&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; Content-type: Text/plain; charset=US-ASCII&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; Message-ID: &lt;C0D51AC.4ECD627C.000E@["192.168.177.176"]&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; reside blocks technique there found the asked the range operated known &lt;cr&gt;&lt;lf&gt;
20:34:25.375: &lt;&lt; currently they them patches the bugs helps institutions the security organizations &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; haunted helps animate the ran in and hundred movies that animate ubiquitous &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; institutions building as need no other dedicate and animate strings across &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; malicious welcome by currently ran currently helps for for across and asked &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; known to haunted vulnerable technique institutions product product graphics &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; technique patches range to sites no into ran graphics movies for dedicate &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; in making they injected taking there quick ran institutions them asked &lt;cr&gt;&lt;lf&gt;
20:34:25.390: &lt;&lt; scripting there organizations legitimate there government which vulnerable &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; security the ran no comprehensive across organizations free by bugs reside &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; government patches making institutions also graphics animate by comprehensive &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; currently government and free taking the injected quick haunted code graphics &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; product north haunted product ran currently vulnerable haunted animate &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; across scripting by scripting comprehensive vulnerable blocks that ran &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; haunted asked range animate scripting applets are and security patches &lt;cr&gt;&lt;lf&gt;
20:34:25.406: &lt;&lt; found free north found quick for legitimate blocks also asked which comprehensive &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; the code haunted ran The range the into applets need organizations through &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; making legitimate quick The and ran making technique security to making &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; quick taking blocks currently which need helps across injected them and &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; they system Internet product sites in making building malicious legitimate &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; are &lt;cr&gt;&lt;lf&gt;
20:34:25.421: &lt;&lt; .&lt;cr&gt;&lt;lf&gt;
20:34:25.500: &gt;&gt; 250 OK D0/50-11301-24586DE4&lt;cr&gt;&lt;lf&gt;
20:34:25.515: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:25.546: &gt;&gt; 250 RSET OK&lt;cr&gt;&lt;lf&gt;
20:34:25.546: &lt;&lt; MAIL FROM:&lt;yyy@yy.yy&gt;&lt;cr&gt;&lt;lf&gt;
20:34:25.578: &gt;&gt; 421 4.5.1 No more messages on this connection, se venligst http://postmaster.tdc.dk/publish.php?id=23413&lt;cr&gt;&lt;lf&gt;
20:34:25.593: &lt;&lt; RSET&lt;cr&gt;&lt;lf&gt;
20:34:25.609: &lt;&lt; QUIT&lt;cr&gt;&lt;lf&gt;
20:34:25.609:
</p><p>
</p><p>
