[quote user="BENJ STEVENS"]
Hi
Thanks for all your help
I have now sorted out how it
works. !!!!!
In Tools/options/signature
 First I set signature 1 to
have the same signature in all four options
I renamed Signature 1 as “BENJ”
I set BENJ as my default signature.
I also TICKED to make this variant to be the default when messages are
created
 Now with this
set, each time you create a new mail you will see the signature set in BENJ in
every mail. The Sig option on this page shows BENJ does not appear to have any influence
on your signature. If you set it to no signature or another signature the BENJ Signature
still appears in the mail and is sent out.  I think
it should be greyed out!!
 Or -
I set “BENJ” as my default
signature in Tools/options/signature
I DID NOT tick  to make
this variant to be the default when messages are created
Now with this
set, each time you create a new mail you will NOT see the signature set in BENJ.
The Sig option will show BENJ. When the message is sent it will include the
signature BENJ.
If you set
the Sig option to no Signature then no signature is sent.
If you have
set other signatures then these can also be selected
Or -
I set “No Signature” as my
default signature in Tools/options/signature
I DID NOT tick to make this variant to be the default when
Now with
this set, No signature is sent. The Sig option will shows No Signature. If you
change the Sig option to BENJ, the signature will not be displayed in the mail
but will be sent.
If you have
<!--Regards Benj [if gte mso 9]><xml>
</p><p> <w:WordDocument>
</p><p>  <w:View>Normal</w:View>
</p><p>  <w:Zoom>0</w:Zoom>
</p><p>  <w:TrackMoves/>
</p><p>  <w:TrackFormatting/>
</p><p>  <w:PunctuationKerning/>
</p><p>  <w:ValidateAgainstSchemas/>
</p><p>  <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
</p><p>  <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
</p><p>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
</p><p>  <w:DoNotPromoteQF/>
</p><p>  <w:LidThemeOther>EN-GB</w:LidThemeOther>
</p><p>  <w:LidThemeAsian>X-NONE</w:LidThemeAsian>
</p><p>  <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
</p><p>  <w:Compatibility>
</p><p>   <w:BreakWrappedTables/>
</p><p>   <w:SnapToGridInCell/>
</p><p>   <w:WrapTextWithPunct/>
</p><p>   <w:UseAsianBreakRules/>
</p><p>   <w:DontGrowAutofit/>
</p><p>   <w:SplitPgBreakAndParaMark/>
</p><p>   <w:DontVertAlignCellWithSp/>
</p><p>   <w:DontBreakConstrainedForcedTables/>
</p><p>   <w:DontVertAlignInTxbx/>
</p><p>   <w:Word11KerningPairs/>
</p><p>   <w:CachedColBalance/>
</p><p>  </w:Compatibility>
</p><p>  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</p><p>  <m:mathPr>
</p><p>   <m:mathFont m:val="Cambria Math"/>
</p><p>   <m:brkBin m:val="before"/>
</p><p>   <m:brkBinSub m:val="--"/>
</p><p>   <m:smallFrac m:val="off"/>
</p><p>   <m:dispDef/>
</p><p>   <m:lMargin m:val="0"/>
</p><p>   <m:rMargin m:val="0"/>
</p><p>   <m:defJc m:val="centerGroup"/>
</p><p>   <m:wrapIndent m:val="1440"/>
</p><p>   <m:intLim m:val="subSup"/>
</p><p>   <m:naryLim m:val="undOvr"/>
</p><p>  </m:mathPr></w:WordDocument>
</p><p></xml><![endif][if gte mso 9]><xml>
</p><p> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
</p><p>  DefSemiHidden="true" DefQFormat="false" DefPriority="99"
</p><p>  LatentStyleCount="267">
</p><p>  <w:LsdException Locked="false" Priority="0" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Normal"/>
</p><p>  <w:LsdException Locked="false" Priority="9" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="heading 1"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/>
</p><p>  <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 1"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 2"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 3"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 4"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 5"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 6"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 7"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 8"/>
</p><p>  <w:LsdException Locked="false" Priority="39" Name="toc 9"/>
</p><p>  <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/>
</p><p>  <w:LsdException Locked="false" Priority="10" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Title"/>
</p><p>  <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/>
</p><p>  <w:LsdException Locked="false" Priority="11" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/>
</p><p>  <w:LsdException Locked="false" Priority="22" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Strong"/>
</p><p>  <w:LsdException Locked="false" Priority="20" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/>
</p><p>  <w:LsdException Locked="false" Priority="59" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Table Grid"/>
</p><p>  <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/>
</p><p>  <w:LsdException Locked="false" Priority="1" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/>
</p><p>  <w:LsdException Locked="false" Priority="60" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Light Shading"/>
</p><p>  <w:LsdException Locked="false" Priority="61" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Light List"/>
</p><p>  <w:LsdException Locked="false" Priority="62" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Light Grid"/>
</p><p>  <w:LsdException Locked="false" Priority="63" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1"/>
</p><p>  <w:LsdException Locked="false" Priority="64" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2"/>
</p><p>  <w:LsdException Locked="false" Priority="65" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium List 1"/>
</p><p>  <w:LsdException Locked="false" Priority="66" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium List 2"/>
</p><p>  <w:LsdException Locked="false" Priority="67" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1"/>
</p><p>  <w:LsdException Locked="false" Priority="68" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2"/>
</p><p>  <w:LsdException Locked="false" Priority="69" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3"/>
</p><p>  <w:LsdException Locked="false" Priority="70" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Dark List"/>
</p><p>  <w:LsdException Locked="false" Priority="71" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading"/>
</p><p>  <w:LsdException Locked="false" Priority="72" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Colorful List"/>
</p><p>  <w:LsdException Locked="false" Priority="73" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid"/>
</p><p>   UnhideWhenUsed="false" Name="Light Shading Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Light List Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Light Grid Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>
</p><p>  <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/>
</p><p>  <w:LsdException Locked="false" Priority="34" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/>
</p><p>  <w:LsdException Locked="false" Priority="29" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Quote"/>
</p><p>  <w:LsdException Locked="false" Priority="30" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Dark List Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful List Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>
</p><p>   UnhideWhenUsed="false" Name="Light Shading Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Light List Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Light Grid Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Dark List Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful List Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>
</p><p>   UnhideWhenUsed="false" Name="Light Shading Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Light List Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Light Grid Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Dark List Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful List Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>
</p><p>   UnhideWhenUsed="false" Name="Light Shading Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Light List Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Light Grid Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Dark List Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful List Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>
</p><p>   UnhideWhenUsed="false" Name="Light Shading Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Light List Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Light Grid Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Dark List Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful List Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>
</p><p>   UnhideWhenUsed="false" Name="Light Shading Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Light List Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Light Grid Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Dark List Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful List Accent 6"/>
</p><p>   UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>
</p><p>  <w:LsdException Locked="false" Priority="19" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/>
</p><p>  <w:LsdException Locked="false" Priority="21" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/>
</p><p>  <w:LsdException Locked="false" Priority="31" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/>
</p><p>  <w:LsdException Locked="false" Priority="32" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/>
</p><p>  <w:LsdException Locked="false" Priority="33" SemiHidden="false"
</p><p>   UnhideWhenUsed="false" QFormat="true" Name="Book Title"/>
</p><p>  <w:LsdException Locked="false" Priority="37" Name="Bibliography"/>
</p><p>  <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/>
</p><p> </w:LatentStyles>
</p><p></xml><![endif][if gte mso 10]>
</p><p><style>
</p><p> /* Style Definitions */
</p><p> table.MsoNormalTable
</p><p>	{mso-style-name:"Table Normal";
</p><p>	mso-tstyle-rowband-size:0;
</p><p>	mso-tstyle-colband-size:0;
</p><p>	mso-style-noshow:yes;
</p><p>	mso-style-priority:99;
</p><p>	mso-style-qformat:yes;
</p><p>	mso-style-parent:"";
</p><p>	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
</p><p>	mso-para-margin:0cm;
</p><p>	mso-para-margin-bottom:.0001pt;
</p><p>	mso-pagination:widow-orphan;
</p><p>	font-size:11.0pt;
</p><p>	font-family:"Calibri","sans-serif";
</p><p>	mso-ascii-font-family:Calibri;
</p><p>	mso-ascii-theme-font:minor-latin;
</p><p>	mso-fareast-font-family:"Times New Roman";
</p><p>	mso-fareast-theme-font:minor-fareast;
</p><p>	mso-hansi-font-family:Calibri;
</p><p>	mso-hansi-theme-font:minor-latin;
</p><p>	mso-bidi-font-family:"Times New Roman";
</p><p>	mso-bidi-theme-font:minor-bidi;}
</p><p></style>
</p><p><![endif]-->[/quote]
All of which the explanatory notes have already told you.
        [quote user="BENJ STEVENS"]<p class="MsoNormal"><span style="font-size:10.0pt;">Hi</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">Thanks for all your help</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">I have now sorted out how it
works. !!!!!</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">In Tools/options/signature</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">&nbsp;First I set signature 1 to
have the same signature in all four options</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">I renamed Signature 1 as “BENJ”</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">I set BENJ as my default signature.</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">I also <b style="mso-bidi-font-weight:normal;"><u>TICKED</u></b> to make this variant to be the default when messages are
created</span></p>
<p class="MsoListParagraphCxSpFirst"><span style="font-size:10.0pt;">&nbsp;Now with this
still appears in the mail and is sent out. <span style="mso-spacerun:yes;">&nbsp;</span>I think
it should be greyed out!!</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">&nbsp;Or -</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">&nbsp;</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">I set “BENJ” as my default
signature in Tools/options/signature</span></p>
<p class="MsoNormal"><span style="font-size:10.0pt;">I <b style="mso-bidi-font-weight:normal;"><u>DID NOT tick </u></b><span style="mso-spacerun:yes;">&nbsp;</span>to make
this variant to be the default when messages are created</span></p>
<p class="MsoListParagraphCxSpFirst"><span style="font-size:10.0pt;">Now with this
signature BENJ. </span></p>
<p class="MsoListParagraphCxSpMiddle"><span style="font-size:10pt;">If you set
the Sig option to no Signature then no signature is sent.</span></p><p class="MsoListParagraphCxSpMiddle"><span style="font-size:10pt;">If you have
set other signatures then these can also be selected</span></p>
<p class="MsoNormal"><span style="font-size:10pt;">Or -</span></p>
<p class="MsoNormal"><span style="font-size:10pt;">I set “No Signature” as my
default signature in Tools/options/signature</span></p><p class="MsoNormal"><span style="font-size:10pt;">I <b><u>DID NOT tick</u></b> to make this variant to be the default when
<p class="MsoListParagraphCxSpMiddle"><span style="font-size:10.0pt;">Now with
but will be sent.</span></p>
<p class="MsoListParagraphCxSpLast"><span style="font-size:10pt;">If you have
set other signatures then these can also be selected</span></p><p class="MsoListParagraphCxSpLast">&nbsp;</p><p><!--Regards Benj [if gte mso 9]><xml>
 <w:WordDocument>
  <w:Zoom>0</w:Zoom>
  <w:TrackMoves/>
  <w:DoNotPromoteQF/>
  <w:Compatibility>
  </w:Compatibility>
  <m:mathPr>
   <m:brkBinSub m:val="&#45;-"/>
   <m:dispDef/>
 </w:LatentStyles>
<style>
	font-size:11.0pt;
</style>
<![endif]-->[/quote]</p><p>All of which the explanatory notes have already told you.
