I want to set up my email so that Pegasus will download all unread email to my PC but leaving everything on the ISP's server. I want to be able to download any/all email to my ipad for remote access and I need this to work even if I have left my home PC turned on with Pegasus running.That way, if I am out but waiting for an urgent reply, I can still get it.
So I have created a rule that will delete all email left on server after 7 days but it doesn't appear to delete any email older than the 7 days.At the moment the mail is just accumulating and I have to manually delete it using Webmail.
The rule was created under Tools>mail filtering rules>Create edit POP3 rule set. Then this rule has been selected to run under Receiving (POP3)>POP3 mail download definitions>Edit>Download Controls>Server-side mail filtering (uses POP3 filtering rule set) where I have selected my "Del on Server after 1 week" rule.
I am presuming that the 7 day rule would kick in when Pegasus on the PC checks for new mail i.e. it would download the unread mail but also leave it on the server (this seems to work okay). During the checking for (and downloading any new mail) the rule would also delete anything still at the ISP older than 7 days but it doesn't.
The iPad is set to download only and leave everything behind.This would give me the most useful way to have access to email anywhere. If I go away on holiday I just have to extend the 7 days to a longer period. No mail gets missed and it wouldn't clog the ISP.
I have a feeling that I am not using the POP3 rule set correctly but am at a loss as to how to apply it differently.
Has anybody made this work ?
        <p>I want to set up my email so that Pegasus will download all unread email to my PC but leaving everything on the ISP's server. I want to be able to download any/all email to my ipad for remote access and I need this to work even if I have left my home PC turned on with Pegasus running.That way, if I am out but waiting for an urgent reply, I can still get it.
</p><p>So I have created a rule that will delete all email left on server after 7 days but it doesn't appear to delete any email older than the 7 days.At the moment the mail is just accumulating and I have to manually delete it using Webmail.
</p><p>The rule was created under Tools&gt;mail filtering rules&gt;Create edit POP3 rule set. Then this rule has been selected to run under Receiving (POP3)&gt;POP3 mail download definitions&gt;Edit&gt;Download Controls&gt;Server-side mail filtering (uses POP3 filtering rule set) where I have selected my "Del on Server after 1 week" rule.
</p><p>I am presuming that the 7 day rule would kick in when Pegasus on the PC checks for new mail i.e. it would download the unread mail but also leave it on the server (this seems to work okay). During the checking for (and downloading any new mail) the rule would also delete anything still at the ISP older than 7 days but it doesn't.</p><p>The iPad is set to download only and leave everything behind.This would give me the most useful way to have access to email anywhere. If I go away on holiday I just have to extend the 7 days to a longer period. No mail gets missed and it wouldn't clog the ISP.
</p><p>I have a feeling that I am not using the POP3 rule set correctly but am at a loss as to how to apply it differently. </p><p>Has anybody made this work ?
