Terrible problem
[quote user="bfluet"]I don't know anything about SEZNAM but it know when retrieving message from GMAIL via POP3 you can configure GMAIL to archive retrieved messages.  If SEZNAM isn't configured as such or that isn't an option then I believe the only way to do it is to bounce (forward without editing) all of the messages to your SEZNAM account.[/quote]
Sounds to me that IMAP would be an option here, if possible ...
<p>[quote user="bfluet"]I don't know anything about SEZNAM but it know when retrieving message from GMAIL via POP3 you can configure GMAIL to archive retrieved messages.  If SEZNAM isn't configured as such or that isn't an option then I believe the only way to do it is to bounce (forward without editing) all of the messages to your SEZNAM account.[/quote]</p><p>Sounds to me that IMAP would be an option here, if possible ...</p>
Dears,
I have a small terrible problem with PegasusMail. Up to this day I used my internet email account on SEZNAM.CZ.
I wanted to test your Pegasus because I was very curious.
Unfortunately, I run PegasusMail and Pegasus downloaded all emails to my home
PC and DELETED !!! all my emails on my internet account SEZNAM.CZ. Terrible !!!.
How can I move back all my emails from my home PC to my internet account SEZNAM.CZ
Many thanks and with best regards
Jerry
<font size="2" face="Arial, Helvetica, sans-serif">Dears,</font><div style="font-family: sans-serif; font-size: 14px; "></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif"> </font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">I have a small terrible problem with PegasusMail. Up to this day I used my internet email account on SEZNAM.CZ.</font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">I wanted to test your Pegasus because I was very curious. </font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "> </div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">Unfortunately, I run PegasusMail and Pegasus downloaded all emails to my home</font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">PC and DELETED !!! all my emails on my internet account </font><span style="font-family: Arial, Helvetica, sans-serif; font-size: small; ">SEZNAM.CZ. Terrible !!!.</span></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><span style="font-family: Arial, Helvetica, sans-serif; font-size: small; "> </span></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">How can I move back all my emails from my home PC to my internet account SEZNAM.CZ</font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif"> </font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">Many thanks and with best regards</font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif"> </font></div><div style="font-family: 'Arial CE', Arial, helvetica, sans-serif; "><font size="2" face="Arial, Helvetica, sans-serif">Jerry</font></div>
You can control whether Pegasus Mail deletes the messages from your SEZNAM account after it retrieves them  The setting is in the configuration of the POP3 host in Pegasus Mail.  Look for the check box labeled "Delete mail from host once it has been successfully retrieved".  Uncheck it to leave the messages on your SEZNAM account.  If you do this you may also want to go into the "Downloads control" tab of the POP3 host configuration and tick the "Download only unread mail" option. There are some considerations when using this setting so read the help file first.
<p>I don't know anything about SEZNAM but it know when retrieving message from GMAIL via POP3 you can configure GMAIL to archive retrieved messages.  If SEZNAM isn't configured as such or that isn't an option then I believe the only way to do it is to bounce (forward without editing) all of the messages to your SEZNAM account.  </p><p>You can control whether Pegasus Mail deletes the messages from your SEZNAM account after it retrieves them  The setting is in the configuration of the POP3 host in Pegasus Mail.  Look for the check box labeled "Delete mail from host once it has been successfully retrieved".  Uncheck it to leave the messages on your SEZNAM account.  If you do this you may also want to go into the "Downloads control" tab of the POP3 host configuration and tick the "Download only unread mail" option. There are some considerations when using this setting so read the help file first.</p><p> </p>
