Not a new issue - maybe a few months worth. Not bad if I don't send any attachments, but then a big problem.
Using Pegasus 4.63 and Win XP SP3.  Firewall is Comodo 5.10+.  Anti-Virus is Avast 6.0137+/-.  I use four different identities in Pegasus, and do POP3  email via gmail. Have done so for "years."
Problem started some months back and is intermittent but serious. Frequently when sending with attachments, especially large ones, Pegasus starts to send, but then stops. Usually within 5 seconds or less, never more than 15 seconds.  I've reset my timeout lengths to 60 or 120 seconds - way longer than it takes prior to the error showing. Both on Internet General tab and SMTP General tab.
Error description is Connection timeout (no response from host). The Trace "always" ends:
<< 0006 DATA
>> 0033 354  Go ahead xxxxxxxx.x  (string of numbers)
(I'm not posting the full Trace.  When I tried asking for help here a month or two back I was told that the trace exposes email and password in hex format.  I had to change passwords.)
I've reset my SMTP stuff MULTIPLE times!!!! TLS and SSL and back again many times with variations of the authentication options.
Sometimes it works, but at times I can't send - every time it fails.  I have to delete the queued email, close,  Pegasus and then retry. Sometimes time after time, sometimes it then works right away.
I just did a test. A simple email sent OK AFTER I emptied the queue.
Then I sent with an attachment (a pdf file).  After three seconds of sending, the error came up.  I've now spent over an hour trying to send off three emails with attachments just under 3 Meg in size - way under gmail's 25 Meg limit. (Should have taken a minute or two.)  One sent.  The other two have had the repeated error after error.  VERY FRUSTRATING.  I'll send this, then reboot the computer and see if that helps.
Thanks.
Rich
        <p>Not a new issue - maybe a few months worth. Not bad if I don't send any attachments, but then a big problem.</p><p>Using Pegasus 4.63 and Win XP SP3. &nbsp;Firewall is Comodo 5.10+. &nbsp;Anti-Virus is Avast 6.0137+/-. &nbsp;I use four different identities in Pegasus, and do POP3 &nbsp;email via gmail. Have done so for "years."</p><p>Problem started some months back and is intermittent but serious. Frequently when sending with attachments, especially large ones, Pegasus starts to send, but then stops. Usually within 5 seconds or less, never more than 15 seconds. &nbsp;I've reset my timeout lengths to 60 or 120 seconds - way longer than it takes prior to the error showing. Both on Internet General tab and SMTP General tab.</p><p>Error description is Connection timeout (no response from host). The Trace "always" ends:</p><p>&lt;&lt; 0006 DATA
&gt;&gt; 0033 354  Go ahead xxxxxxxx.x &nbsp;(string of numbers)</p><p>(I'm not posting the full Trace. &nbsp;When I tried asking for help here a month or two back I was told that the trace exposes email and password in hex format. &nbsp;I had to change passwords.)</p><p>I've reset my SMTP stuff MULTIPLE times!!!! TLS and SSL and back again many times with variations of the authentication options.</p><p>Sometimes it works, but at times I can't send - every time it fails. &nbsp;I have to delete the queued email, close, &nbsp;Pegasus and then retry. Sometimes time after time, sometimes it then works right away.</p><p>
</p><p>I just did a test. A simple email sent OK AFTER I emptied the queue.</p><p>
</p><p>Then I sent with an attachment (a pdf file). &nbsp;After three seconds of sending, the error came up. &nbsp;I've now spent over an hour trying to send off three emails with attachments just under 3 Meg in size - way under gmail's 25 Meg limit. (Should have taken a minute or two.) &nbsp;One sent. &nbsp;The other two have had the repeated error after error. &nbsp;VERY FRUSTRATING. &nbsp;I'll send this, then reboot the computer and see if that helps.</p><p>
</p><p>Thanks.</p><p>
</p><p>Rich</p>
