It sounds like your reply button is configured to do a quick reply
with last options but the reply options have changed making it behave
differently than what you expect.  Hitting the "R" key while reading a
message will invoke a reply with the reply options box.  Change the reply option settings as needed to get the results you
want.  This may take multiple test replies.  These settings are sticky
so they apply to future replies until changed.
You can change the
behavior of the reply button by clicking on the black arrow to the right
 of the reply button and selecting the behavior you want.
You might also consider testing with IERenderer enabled and disabled to
see if that makes a difference.  Make sure you have the most current
version of IERenderer which is v2.4.7.4.
I am puzzled by the reply results being different when generated
from viewing in text mode versus viewing in fancy mode.  I can't
duplicate that here.  Perhaps your efforts in resetting the reply
options will give a clue.  Please let us know how you make out.
        <p>It sounds like your reply button is configured to do a quick reply
differently than what you expect.&nbsp; Hitting the "R" key while reading a
message will invoke a reply with the reply options box.&nbsp; Change the reply option settings as needed to get the results you
want.&nbsp; This may take multiple test replies.&nbsp; These settings are sticky
so they apply to future replies until changed.</p><p>You can change the
 of the reply button and selecting the behavior you want.</p><p>You might also consider testing with IERenderer enabled and disabled to
see if that makes a difference.&nbsp; Make sure you have the most current
version of IERenderer which is v2.4.7.4.&nbsp;
</p><p>I am puzzled by the reply results being different when generated
from viewing in text mode versus viewing in fancy mode.&nbsp; I can't
duplicate that here.&nbsp; Perhaps your efforts in resetting the reply
options will give a clue.&nbsp; Please let us know how you make out.</p>
