If a different driver doesn't do the trick consider AlwaysMouseWheel by Nenad HRG.
http://www.softwareok.com/?seite=Freeware/AlwaysMouseWheel.
I haven't used it but I really like his Windows Explorer replacement Q-Dir. A good thing about his stuff, at least the apps I've looked at, is that they are available as portable apps so can be tested without the install/uninstall aggravation.
<p>If a different driver doesn't do the trick consider AlwaysMouseWheel by Nenad HRG.&nbsp;
</p><p>http://www.softwareok.com/?seite=Freeware/AlwaysMouseWheel.&nbsp;</p><p>I haven't used it but I really like his Windows Explorer replacement&nbsp; Q-Dir.&nbsp; A good thing about his stuff, at least the apps I've looked at, is that they are available as portable apps so can be tested without the install/uninstall aggravation.
