Notice: Undefined offset: 68 in /var/www/codoforum/sys/CODOF/Forum/Category.php on line 241
Notice: Trying to get property 'cat_name' of non-object in /var/www/codoforum/sys/CODOF/Forum/Category.php on line 241
Notice: Undefined offset: 68 in /var/www/codoforum/sys/CODOF/Forum/Category.php on line 242
Notice: Trying to get property 'cat_alias' of non-object in /var/www/codoforum/sys/CODOF/Forum/Category.php on line 242
Notice: Undefined offset: 68 in /var/www/codoforum/sys/CODOF/Forum/Category.php on line 238
Notice: Trying to get property 'cat_pid' of non-object in /var/www/codoforum/sys/CODOF/Forum/Category.php on line 238
Error Forwarding/Replying with "Encryption.." box unchecked | PMAIL COMMUNITY
Encryption
[quote user="radhx"]>7: Socket read error 2746.[/quote]
According to MSDN this translates to An existing connection was forcibly closed by the remote host.
[quote user="radhx"]The same forwarded mail goes through with "Encryption.." box checked.[/quote]
Since encryption modifies the contents seen by the server it must be something within the contents of the message causing the error.
<p>[quote user="radhx"]>7: Socket read error 2746.[/quote]</p><p>According to MSDN this translates to <em>An existing connection was forcibly closed by the remote host</em>.</p><p>[quote user="radhx"]The same forwarded mail goes through with "Encryption.." box checked.[/quote]</p><p>Since encryption modifies the contents seen by the server it must be something within the contents of the message causing the error.</p>
I am using idw's S/MIME Front-End for email encryption.
But for few of my recipients I was unchecking the "Encrypt.." check-box for specific emails, as they had complained about some error regarding email certificate on their side (outlook express) while accessing my mail.
That's where the problem lies. If I  uncheck the "Encrypt.." box for a particular mail, I end up invariably with -
>> 0046 354 Start mail input; end with <CRLF>.<CRLF>
error while sending such mails .
But if I don't uncheck Encrypt check-box, the same mails (new/reply/forward) go through properly.
How can we address this issue?
Thanks & Regards,
Rad.
&lt;p&gt;Hi,&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;I am using idw&#039;s S/MIME Front-End for email encryption.&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;But for few of my&amp;nbsp;recipients&amp;nbsp;I was unchecking the &quot;Encrypt..&quot;&amp;nbsp;check-box&amp;nbsp;for specific emails, as they had complained about some error regarding email certificate on their side (outlook express) while accessing my mail.&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;That&#039;s where the problem lies. If I &amp;nbsp;uncheck the &quot;Encrypt..&quot; box for a particular mail, I end up invariably with -&lt;/p&gt;&lt;div style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;&amp;gt;&amp;gt; 0046 354 Start mail input; end with &amp;lt;CRLF&amp;gt;.&amp;lt;CRLF&amp;gt;&lt;/div&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;7: Socket read error 2746.&amp;nbsp;&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;error while sending such mails .&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;But if I don&#039;t uncheck Encrypt check-box, the same mails (new/reply/forward) go through properly.&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;How can we address this issue?&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;Thanks &amp;amp; Regards,&lt;/p&gt;&lt;p&gt;&lt;span style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;Rad.&lt;/span&gt;&lt;/p&gt;&lt;p&gt;&lt;span style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;&lt;/span&gt; &lt;/p&gt;
[quote user="radhx"]That's where the problem lies. If I  uncheck the "Encrypt.." box for a particular mail, I end up invariably with -
But if I don't uncheck Encrypt check-box, the same mails (new/reply/forward) go through properly.[/quote]
What happens if you disable the extension (rename its fff-file and restart Pegasus Mail)?
[quote user=&quot;radhx&quot;]That&#039;s where the problem lies. If I &amp;nbsp;uncheck the &quot;Encrypt..&quot; box for a particular mail, I end up invariably with -&lt;div style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;&amp;gt;&amp;gt; 0046 354 Start mail input; end with &amp;lt;CRLF&amp;gt;.&amp;lt;CRLF&amp;gt;&lt;/div&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;7: Socket read error 2746.&amp;nbsp;&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;error while sending such mails .&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;But if I don&#039;t uncheck Encrypt check-box, the same mails (new/reply/forward) go through properly.[/quote]&lt;/p&gt;&lt;p style=&quot;font-family: Tahoma, Arial, Helvetica; font-size: 12px; text-align: left; &quot;&gt;What happens if you disable the extension (rename its fff-file and restart Pegasus Mail)?&lt;/p&gt;
I renamed PMSMMain.fff in D:\PMAIL\Programs\PMSM\Resources folder but still Front-end is active for PMail.
Which file I should rename?
Or should i change Tools->options->Encryption->Default Encryption Method to "Built-in Encryptor"?
Currently it is "idw's S/MIME Front-end".
Thanks & Regards,
Rad.
&lt;p&gt;I renamed PMSMMain.fff in D:\PMAIL\Programs\PMSM\Resources folder but still Front-end is active for PMail.&lt;/p&gt;&lt;p&gt;Which file I should rename?&lt;/p&gt;&lt;p&gt;Or should i change Tools-&amp;gt;options-&amp;gt;Encryption-&amp;gt;Default Encryption Method to &quot;Built-in Encryptor&quot;?&lt;/p&gt;&lt;p&gt;Currently it is &quot;idw&#039;s S/MIME Front-end&quot;.&amp;nbsp;&lt;/p&gt;&lt;p&gt;Thanks &amp;amp; Regards,&lt;/p&gt;&lt;p&gt;Rad.&lt;/p&gt;&lt;p&gt; &amp;nbsp;&lt;/p&gt;
Ok, I tried sending mail with same scenario (PMSMMain.ff renamed in Resources).... Front-end is disabled even if it shows in the menu.
Though Front-end is disabled, same error persists.
When I uncheck "Encrypt.." box, I get following error -
[*] Connection established to 202.54.124.244
>> 0036 220 webmail37.rediffmail.com ESMTP
<< 0020 EHLO [1.187.147.6]
>> 0030 250-webmail37.rediffmail.com
>> 0016 250-PIPELINING
>> 0014 250 8BITMIME
<< 0034 MAIL FROM:<radhx@rediffmail.com>
>> 0008 250 ok
<< 0027 RCPT TO:<hxrad@yahoo.com>
>> 0008 250 ok
<< 0006 DATA
And when sent with "Encrypt.." box checked, Forward/Reply went through.
Looks like not Front-end issue but PMail one. Or is it some missing setup?
Thanks & Regards,
Rad.
&lt;p&gt;Ok, I tried sending mail with same scenario (PMSMMain.ff renamed in Resources).... Front-end is disabled even if it shows in the menu.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;Though Front-end is disabled, same error persists.&lt;/p&gt;&lt;p&gt;When I uncheck &quot;Encrypt..&quot; box, I get following error -&lt;/p&gt;&lt;p&gt;[*] Connection established to 202.54.124.244&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0036 220 webmail37.rediffmail.com ESMTP&lt;/p&gt;&lt;p&gt;&amp;lt;&amp;lt; 0020 EHLO [1.187.147.6]&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0030 250-webmail37.rediffmail.com&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0016 250-PIPELINING&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0014 250 8BITMIME&lt;/p&gt;&lt;p&gt;&amp;lt;&amp;lt; 0034 MAIL FROM:&amp;lt;radhx@rediffmail.com&amp;gt;&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0008 250 ok&lt;/p&gt;&lt;p&gt;&amp;lt;&amp;lt; 0027 RCPT TO:&amp;lt;hxrad@yahoo.com&amp;gt;&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0008 250 ok&lt;/p&gt;&lt;p&gt;&amp;lt;&amp;lt; 0006 DATA&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0046 354 Start mail input; end with &amp;lt;CRLF&amp;gt;.&amp;lt;CRLF&amp;gt;&lt;/p&gt;&lt;p&gt;7: Socket read error 2746.&lt;/p&gt;&lt;p&gt;And when sent with &quot;Encrypt..&quot; box checked, Forward/Reply went through.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;Looks like not Front-end issue but PMail one. Or is it some missing setup?&lt;/p&gt;&lt;p&gt;Thanks &amp;amp; Regards,&lt;/p&gt;&lt;p&gt;Rad.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
[quote user="radhx"]Ok, I tried sending mail with same scenario (PMSMMain.ff renamed in Resources).... Front-end is disabled even if it shows in the menu.[/quote]
You need to rename all fff-files starting with PMSM... in the respective (Pegasus Mail) user's mailbox directory, the ones you renamed aren't used by Pegasus Mail, they are used for enabling the extension for additional users only.
&lt;p&gt;[quote user=&quot;radhx&quot;]Ok, I tried sending mail with same scenario (PMSMMain.ff renamed in Resources).... Front-end is disabled even if it shows in the menu.[/quote]&lt;/p&gt;&lt;p&gt;You need to rename all fff-files starting with PMSM... in the respective (Pegasus Mail) user&#039;s mailbox directory, the ones you renamed aren&#039;t used by Pegasus Mail, they are used for enabling the extension for additional users only.&lt;/p&gt;
Renamed PMSMCryptor.fff and PMSMMain.fff.
Now Front-end options are not available on menu.
Forwarding email with encryption OFF, got the following error -
[*] Connection established to 203.199.83.104
>> 0036 220 webmail38.rediffmail.com ESMTP
<< 0024 EHLO [112.110.223.124]
>> 0030 250-webmail38.rediffmail.com
>> 0016 250-PIPELINING
>> 0014 250 8BITMIME
>> 0008 250 ok
>> 0008 250 ok
<< 0006 DATA
Then I tried to Forward other mails, of which most went through except a few.
So I again activated Front-end and repeated same procedure.
What I could derive from this exercise is this error occurs only for the forwarded email which has -
1] already been forwarded more than once.
part of the email contains something like this -
------- Forwarded message follows -------
From:                         Rajesh A. Deshpande <radhx@rediffmail.com>
To:                            Flipkart Customer Support <cs@flipkart.com>
Subject:                     (Fwd) Replacement and Return for Order No. OD20528110359
Date sent:                  Tue, 19 Jun 2012 19:26:18 +0530
Subject:                     Replacement and Return for Order No. OD20528110359
Date sent:                  Sun, 17 Jun 2012 12:48:56 +0530
I was forwarding this email for the third time.
2] and "Encryption.." box unchecked.
I saw a similar query in Pegasus Mail Community Support Forum:
http://community.pmail.com/forums/thread/34990.aspx
may be it is some different issue altogether.
Thanks & Regards,
Rad.
&lt;div&gt;Renamed PMSMCryptor.fff and PMSMMain.fff.&lt;/div&gt;&lt;div&gt;Now Front-end options are not available on menu.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;Forwarding email with encryption OFF, got the following error -&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;[*] Connection established to 203.199.83.104&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0036 220 webmail38.rediffmail.com ESMTP&lt;/div&gt;&lt;div&gt;&amp;lt;&amp;lt; 0024 EHLO [112.110.223.124]&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0030 250-webmail38.rediffmail.com&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0016 250-PIPELINING&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0014 250 8BITMIME&lt;/div&gt;&lt;div&gt;&amp;lt;&amp;lt; 0034 MAIL FROM:&amp;lt;radhx@rediffmail.com&amp;gt;&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0008 250 ok&lt;/div&gt;&lt;div&gt;&amp;lt;&amp;lt; 0027 RCPT TO:&amp;lt;hxrad@yahoo.com&amp;gt;&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0008 250 ok&lt;/div&gt;&lt;div&gt;&amp;lt;&amp;lt; 0006 DATA&lt;/div&gt;&lt;div&gt;&amp;gt;&amp;gt; 0046 354 Start mail input; end with &amp;lt;CRLF&amp;gt;.&amp;lt;CRLF&amp;gt;&lt;/div&gt;&lt;div&gt;7: Socket read error 2746.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;Then I tried to Forward other mails, of which most went through except a few.&lt;/div&gt;&lt;div&gt;So I again activated Front-end and repeated same procedure.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;What I could derive from this exercise is this error occurs only for the forwarded email which has -&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;1] already been forwarded more than once.&lt;/div&gt;&lt;div&gt;part of the email contains something like this -&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;------- Forwarded message follows -------&lt;/div&gt;&lt;div&gt;From: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; Rajesh A. Deshpande &amp;lt;radhx@rediffmail.com&amp;gt;&lt;/div&gt;&lt;div&gt;To: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;Flipkart Customer Support &amp;lt;cs@flipkart.com&amp;gt;&lt;/div&gt;&lt;div&gt;Subject: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; (Fwd) Replacement and Return for Order No. OD20528110359&lt;/div&gt;&lt;div&gt;Date sent: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;Tue, 19 Jun 2012 19:26:18 +0530&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;------- Forwarded message follows -------&lt;/div&gt;&lt;div&gt;From: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; Rajesh A. Deshpande &amp;lt;radhx@rediffmail.com&amp;gt;&lt;/div&gt;&lt;div&gt;To: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;Flipkart Customer Support &amp;lt;cs@flipkart.com&amp;gt;&lt;/div&gt;&lt;div&gt;Subject: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; Replacement and Return for Order No. OD20528110359&lt;/div&gt;&lt;div&gt;Date sent: &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;Sun, 17 Jun 2012 12:48:56 +0530&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;I was forwarding this email for the third time.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;2] and &quot;Encryption..&quot; box unchecked.&lt;/div&gt;&lt;div&gt;The same forwarded mail goes through with &quot;Encryption..&quot; box checked.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;I saw a similar query in Pegasus Mail Community Support Forum:&lt;/div&gt;&lt;div&gt;http://community.pmail.com/forums/thread/34990.aspx&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;may be it is some different issue altogether.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;&lt;div&gt;Thanks &amp;amp; Regards,&lt;/div&gt;&lt;div&gt;Rad.&lt;/div&gt;&lt;div&gt; &lt;/div&gt;
