Here is the ini file contents...
Note...this is the ini file on my home work station....I brought it home so that I could work on it.  The ip addresses will not be the same as discussed in earlier posts.
#  Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#  This sample file implements most of the possible switches for each
#  module, but you can edit it to do less if you wish.
#  Anything after a '#' to the end of the line is a comment and
#  is stripped out before parsing. Trailing and leading whitespace
#  is also stripped before parsing. Many sample commands have been
#  left in this file commented out for reference purposes.
#  Note that in general, manual modification of this file is NOT
#  RECOMMENDED - use the Mercury "Configuration" menu to change the
#  program's settings wherever possible.
[General]
myname:      [192.168.1.185]  # Canonical name for this server
timezone:    +0000         # Time Zone to add to date fields
file_api:    1                    # Use the file api instead of queues
mailqueue:   C:\MERCURY\QUEUE   # Where mail should be put for delivery
smtpqueue:   C:\MERCURY\QUEUE   # Where the SMTP client should look for mail
newmail_path: C:\MERCURY\MAIL\~N
[Protocols]
C:\MERCURY\mercurys.dll
C:\MERCURY\mercurye.dll
C:\MERCURY\mercuryp.dll
[Mercury]
failfile:     C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure notification template
confirmfile:  C:\MERCURY\Mercury\CONFIRM.MER  # Delivery confirmation template
aliasfile:    C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file
synfile:      C:\MERCURY\Mercury\SYNONYM.MER  # User synonym database
listfile:     C:\MERCURY\Mercury\LISTS.MER    # List of lists
logfile:      C:\MERCURY\Logs\Core\~y-~m-~d.log  # Traffic logging file
# bitnethost:   cunyvm.cuny.edu      # Relay host for ".bitnet" rewrites
poll:         10                   # Seconds between queue polling cycles
scratch:      C:\MERCURY\Scratch   # Where we can write temp files
returnlines:  15                   # How many lines of failed messages to return
postmaster:   Admin   # Local user who acts as postmaster
broadcast:    1                    # Yes, we want broadcast notifications, but
receipts:     0                    # ... no broadcasts for receipt confirmations
PM_notify:    1                    # Do/Don't send errors to the postmaster
change_owner: 1                    # Change message ownership to recipient
# noticeboards: SYS:PUBLIC/NB        # Where to find Pegasus Mail noticeboards
auto_tzone:   1                    # If NZ, obtain timezone information from OS
[MercuryC]
logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryC\    # Directory for session log files
Session_logmode : 0
host:             # mail mail host which relays for us
scratch:     C:\MERCURY\scratch           # Where we can write temp files
poll:        30                   # Seconds between queue polling cycles
failfile:    C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure template
esmtp:       1                    # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\   # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\    # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120               # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log
Timeout : 30
Relay : 0
Strict_Relay : 0
Allow_Illegals : 0
SMTP_Authentication : 1
Auth_File : mercuryPassWords.txt
Session_logging : C:\MERCURY\Sessions\MercuryS
Session_logmode : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryP\   # Directory for session log files
Session_logmode : 0
Timeout : 60
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup            :     TESTGRP
[Domains]
# NetWare Server           Domain name
[192  :  [192
[192  :  [192.168.1.185]
# [Rewrite]
# *                    : pmail.gen.nz
[Maiser]
Maiser               :     Maiser
Helpfile             :     C:\MERCURY\Mercury\MAISER.HLP
Lookupfile           :     C:\MERCURY\Mercury\MAISER.LKP
Send_dir             :     C:\MERCURY\Mercury\SENDABLE
Logfile              :     C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG
Notify               :     C:\MERCURY\Mercury\TMP
Local_only           :     Y
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log   # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
thanks.
        <p>Here is the ini file contents...</p><p>Note...this is the ini file on my home work station....I brought it home so that I could work on it.&nbsp; The ip addresses will not be the same as discussed in earlier posts.
</p><p>&nbsp;</p><p>#&nbsp; MERCURY.INI generated by Mercury Setup
#&nbsp; Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#&nbsp; This sample file implements most of the possible switches for each
#&nbsp; module, but you can edit it to do less if you wish.
#&nbsp; Anything after a '#' to the end of the line is a comment and
#&nbsp; is stripped out before parsing. Trailing and leading whitespace
#&nbsp; is also stripped before parsing. Many sample commands have been
#&nbsp; left in this file commented out for reference purposes.
#&nbsp; Note that in general, manual modification of this file is NOT
#&nbsp; RECOMMENDED - use the Mercury "Configuration" menu to change the
#&nbsp; program's settings wherever possible.
[General]
myname:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; [192.168.1.185]&nbsp; # Canonical name for this server
timezone:&nbsp;&nbsp;&nbsp; +0000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Time Zone to add to date fields
file_api:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Use the file api instead of queues
mailqueue:&nbsp;&nbsp; C:\MERCURY\QUEUE&nbsp;&nbsp; # Where mail should be put for delivery
smtpqueue:&nbsp;&nbsp; C:\MERCURY\QUEUE&nbsp;&nbsp; # Where the SMTP client should look for mail
[Protocols]
[Mercury]
failfile:&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\FAILURE.MER&nbsp; # Delivery failure notification template
confirmfile:&nbsp; C:\MERCURY\Mercury\CONFIRM.MER&nbsp; # Delivery confirmation template
aliasfile:&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\ALIAS.MER&nbsp;&nbsp;&nbsp; # System-wide alias file
synfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\SYNONYM.MER&nbsp; # User synonym database
listfile:&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\LISTS.MER&nbsp;&nbsp;&nbsp; # List of lists
logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Logs\Core\~y-~m-~d.log&nbsp; # Traffic logging file
# bitnethost:&nbsp;&nbsp; cunyvm.cuny.edu&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Relay host for ".bitnet" rewrites
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Seconds between queue polling cycles
scratch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Scratch&nbsp;&nbsp; # Where we can write temp files
returnlines:&nbsp; 15&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
postmaster:&nbsp;&nbsp; Admin&nbsp;&nbsp; # Local user who acts as postmaster
broadcast:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Yes, we want broadcast notifications, but
receipts:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # ... no broadcasts for receipt confirmations
PM_notify:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Do/Don't send errors to the postmaster
change_owner: 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Change message ownership to recipient
# noticeboards: SYS:PUBLIC/NB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Where to find Pegasus Mail noticeboards
auto_tzone:&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # If NZ, obtain timezone information from OS
[MercuryC]
logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryC\&nbsp;&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
host:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # mail mail host which relays for us
scratch:&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\scratch&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Where we can write temp files
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Seconds between queue polling cycles
returnlines: 15&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
failfile:&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\FAILURE.MER&nbsp; # Delivery failure template
esmtp:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\&nbsp;&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Timeout : 30
Relay : 0
Strict_Relay : 0
Allow_Illegals : 0
Session_logmode : 0
SSL_Mode : 0
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryP\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
Timeout : 60
UIDL_nul_list : 1
New_UIDs : 1
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; TESTGRP
[Domains]
# NetWare Server&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Domain name
[192&nbsp; :&nbsp; [192
[192&nbsp; :&nbsp; [192.168.1.185]
# [Rewrite]
# *&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; : pmail.gen.nz
[Maiser]
Maiser&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; Maiser
Helpfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\MAISER.HLP
Lookupfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\MAISER.LKP
Send_dir&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\SENDABLE
Logfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG
Notify&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\TMP
Local_only&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; Y
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
</p><p>thanks.</p><p>&nbsp;</p><p>&nbsp;</p>
