Hello.
Today I just encountered a sudden problem that I cannot resolve.
I have my M/32 with MercuryS configured to relay only authenticated connections (no ssl); the password file has been created months ago, and for months all worked without a single problem.
Today, the server suddenly started to refuse connections, assuming an incorrect login.
It happened two times, and the only way to solve was restarting M/32.
Here is one session log as example (I masked username and password, but I assure you that both were right).
15:23:50.328: Connection from 192.168.1.102, Tue Jul 31 15:23:50 2012<lf>
15:23:50.328: << 220 myserver.it ESMTP server ready.<cr><lf>
15:23:50.328: >> EHLO ugenerico2<cr><lf>
15:23:50.328: << 250-myserver.it Hello ugenerico2; ESMTPs are:<cr><lf>250-TIME<cr><lf>
15:23:50.328: << 250-SIZE 0<cr><lf>
15:23:50.328: << 250-AUTH CRAM-MD5 LOGIN<cr><lf>
15:23:50.328: << 250-AUTH=LOGIN<cr><lf>
15:23:50.328: << 250 HELP<cr><lf>
15:23:50.484: >> AUTH LOGIN<cr><lf>
15:23:50.484: << 334 VXNlcm5hbWU6<cr><lf>
15:23:50.484: >> HereGoesTheCorrectUsername<cr><lf>
15:23:50.484: << 334 UGFzc3dvcmQ6<cr><lf>
15:23:50.484: >> HereGoesTheCorrectPW<cr><lf>
15:23:50.484: << 501 Authentication failed - bad user or password.<cr><lf>
15:23:50.484: --- Connection closed normally at Tue Jul 31 15:23:50 2012. ---
15:23:50.484:
I really don't know what to think.
Any idea?
Best regards
Filippo
        <p>Hello.
15:23:50.328: Connection from 192.168.1.102, Tue Jul 31 15:23:50 2012&lt;lf&gt;
15:23:50.328: &lt;&lt; 220 myserver.it ESMTP server ready.&lt;cr&gt;&lt;lf&gt;
15:23:50.328: &gt;&gt; EHLO ugenerico2&lt;cr&gt;&lt;lf&gt;
15:23:50.328: &lt;&lt; 250-myserver.it Hello ugenerico2; ESMTPs are:&lt;cr&gt;&lt;lf&gt;250-TIME&lt;cr&gt;&lt;lf&gt;
15:23:50.328: &lt;&lt; 250-SIZE 0&lt;cr&gt;&lt;lf&gt;
15:23:50.328: &lt;&lt; 250-AUTH CRAM-MD5 LOGIN&lt;cr&gt;&lt;lf&gt;
15:23:50.328: &lt;&lt; 250-AUTH=LOGIN&lt;cr&gt;&lt;lf&gt;
15:23:50.328: &lt;&lt; 250 HELP&lt;cr&gt;&lt;lf&gt;
15:23:50.484: &gt;&gt; AUTH LOGIN&lt;cr&gt;&lt;lf&gt;
15:23:50.484: &lt;&lt; 334 VXNlcm5hbWU6&lt;cr&gt;&lt;lf&gt;
15:23:50.484: &gt;&gt; HereGoesTheCorrectUsername&lt;cr&gt;&lt;lf&gt;
15:23:50.484: &lt;&lt; 334 UGFzc3dvcmQ6&lt;cr&gt;&lt;lf&gt;
15:23:50.484: &gt;&gt; HereGoesTheCorrectPW&lt;cr&gt;&lt;lf&gt;
15:23:50.484: &lt;&lt; 501 Authentication failed - bad user or password.&lt;cr&gt;&lt;lf&gt;
15:23:50.484:
I really don't know what to think.</p><p>Any idea?</p><p>&nbsp;</p><p>Best regards</p><p>Filippo
