[quote user="deadstick"]There is a "Default timeout for
network connections" on the main Internet options screen and there is a
timeout setting for each host (SMTP & POP3). The timeout setting in the host configuration takes precedence when set to anything other than zero. Some folks have had to set a timeout
value as high as 300 while others have no problems with the default of
30.  Setting the timeout value higher than you need can cause problems so a little trial and error may be needed.[/quote]
I am running into a problem in which the POP3 host sometimes doesn't respond, resulting in delay when waiting for timeouts.  Then I can try again.   A previous timeout is not an indication that the server is unavailable, so short timeout are advantageous because a subsequent attempt will usually work.   A 10 sec. timeout works as well as a 45 sec. timout -- it either "takes" or doesn't "take".   So a short timeout is very advantageous.
The problem is with large files.  If the timeout is too short, an otherwise successful POP call fails.  Specifically, the large email displays a % of download countdown and eventually times out before completion.
I don't mind waiting for the fat email to download (unless it's a spam), but I don't know how to shorten the initial POP3 timeout without causing a large email to also timeout.  (I know about the file size limit option, but I actually *do* want to download these up to the ISP's limit.)
How can I adjust the initial POP3 call timeout but still allow downloads to complete?
