[quote user="Jerry Wise"]
Are you using your machine or are you using an USB stick inserted into a host machine away from home? What ports are you using now: the same as when at home or the ones you need to use when away from home on some WIFI connection for example. Often you must use different ports and authentication when away from home plus those ports must be open and allowed with the machine and network where you are located now.
If using USB stick has this one been tested away from home before?
Yes I am using my machine not any one else's, nor using a USB stick, SD Micro chip, 16gig. Installed as instructed by PMail, not tested away from home as there was not a reason to doubt it would work. This trip was necessary and a very short time to put it together. The ports should be the same as there has not been any reason to make any changes as Avast Antivirus FREE is doing my monitoring for any necessary security for my SSL authentication. I do not use WiFi, which are usually referencing public access, only Private Wireless networks.
Excuse me for neglecting to also have that within my sig, just forgot
[quote user="Jerry Wise"]<p>Are you using your machine or are you using an USB stick inserted into a host machine away from home? What ports are you using now: the same as when at home or the ones you need to use when away from home on some WIFI connection for example. Often you must use different ports and authentication when away from home plus those ports must be open and allowed with the machine and network where you are located now.</p><p>If using USB stick has this one been tested away from home before?
</p><p>[/quote]</p><p>Yes I am using my machine not any one else's, nor using a USB stick, SD Micro chip, 16gig.&nbsp; Installed as instructed by PMail, not tested away from home as there was not a reason to doubt it would work.&nbsp; This trip was necessary and a very short time to put it together.&nbsp; The ports should be the same as there has not been any reason to make any changes as Avast Antivirus FREE is doing my monitoring for any necessary security for my SSL authentication.&nbsp; I do not use WiFi, which are usually referencing public access, only Private Wireless networks.</p><p>Excuse me for neglecting to also have that within my sig, just forgot
