Problem with outgoing mail in pegasus going thru optonline.net
i can't send out emails since i switched from verizon to optonline a few days ago. i get the following error message:
[*] Connection established to 167.206.5.250
>> 0095 +OK Messaging Multiplexor (Sun Java(tm) System Messaging Server 6.2-8.04 (built Feb 28 2007))
<< 0018 USER dkolleeny26
>> 0044 +OK password required for user dkolleeny26
<< 0015 PASS XXXXXXXX
>> 0035 -ERR [AUTH] Authentication failed
My settings for outgoing mail are:
General:
server host name: mail.optonline.net
server tcp/ip port: 587; time out: 360
Security: SMTP Authentication -
Login to the SMTP server using the following details:
user id and password
Please can someone help me solve this frustrating situation?
thank you!
derek kolleeny
&lt;p&gt;i can&#039;t send out emails since i switched from verizon to optonline a few days ago. i get the following error message: &lt;/p&gt;&lt;p&gt;[*] Connection established to 167.206.5.250 &amp;gt;&amp;gt; 0095 +OK Messaging Multiplexor (Sun Java(tm) System Messaging Server 6.2-8.04 (built Feb 28 2007)) &amp;lt;&amp;lt; 0018 USER dkolleeny26 &amp;gt;&amp;gt; 0044 +OK password required for user dkolleeny26 &amp;lt;&amp;lt; 0015 PASS XXXXXXXX &amp;gt;&amp;gt; 0035 -ERR [AUTH] Authentication failed &lt;/p&gt;&lt;p&gt;My settings for outgoing mail are:&lt;/p&gt;&lt;p&gt;General:&lt;/p&gt;&lt;p&gt;server host name: mail.optonline.net&lt;/p&gt;&lt;p&gt;server tcp/ip port: 587; time out: 360&lt;/p&gt;&lt;p&gt;Security: SMTP Authentication - &lt;/p&gt;&lt;p&gt;Login to the SMTP server using the following details: &lt;/p&gt;&lt;p&gt;user id and password&lt;/p&gt;&lt;p&gt;Please can someone help me solve this frustrating situation? &lt;/p&gt;&lt;p&gt;thank you!&lt;/p&gt;&lt;p&gt;derek kolleeny&lt;/p&gt;
[quote user="dkolleeny"]Security: SMTP Authentication -
derek kolleeny[/quote]
There is an SSL/TLS security option above SMTP authentication. I am using port 587 for my gmail account and have the Via STARTTLS option enabled. That might work for you.
&lt;p&gt;[quote user=&quot;dkolleeny&quot;]Security: SMTP Authentication - &lt;/p&gt;&lt;p&gt;derek kolleeny[/quote] &lt;/p&gt;&lt;p&gt;There is an SSL/TLS security option above SMTP authentication. I am using port 587 for my gmail account and have the Via STARTTLS option enabled. That might work for you. &lt;/p&gt;
Steffan,
Thanks very much but adding that option didn't help, i still get the same error!
Derek
&lt;p&gt;Steffan,&lt;/p&gt;&lt;p&gt;Thanks very much but adding that option didn&#039;t help, i still get the same error!&lt;/p&gt;&lt;p&gt;Derek &lt;/p&gt;
