<!--[if gte mso 9]><xml>
</p><p> <w:WordDocument>
</p><p> <w:View>Normal</w:View>
</p><p> <w:Zoom>0</w:Zoom>
</p><p> <w:TrackMoves/>
</p><p> <w:TrackFormatting/>
</p><p> <w:HyphenationZone>21</w:HyphenationZone>
</p><p> <w:PunctuationKerning/>
</p><p> <w:ValidateAgainstSchemas/>
</p><p> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
</p><p> <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
</p><p> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
</p><p> <w:DoNotPromoteQF/>
</p><p> <w:LidThemeOther>NL</w:LidThemeOther>
</p><p> <w:LidThemeAsian>X-NONE</w:LidThemeAsian>
</p><p> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
</p><p> <w:Compatibility>
</p><p> <w:BreakWrappedTables/>
</p><p> <w:SnapToGridInCell/>
</p><p> <w:WrapTextWithPunct/>
</p><p> <w:UseAsianBreakRules/>
</p><p> <w:DontGrowAutofit/>
</p><p> <w:SplitPgBreakAndParaMark/>
</p><p> <w:DontVertAlignCellWithSp/>
</p><p> <w:DontBreakConstrainedForcedTables/>
</p><p> <w:DontVertAlignInTxbx/>
</p><p> <w:Word11KerningPairs/>
</p><p> <w:CachedColBalance/>
</p><p> </w:Compatibility>
</p><p> <m:mathPr>
</p><p> <m:mathFont m:val="Cambria Math"/>
</p><p> <m:brkBin m:val="before"/>
</p><p> <m:brkBinSub m:val="--"/>
</p><p> <m:smallFrac m:val="off"/>
</p><p> <m:dispDef/>
</p><p> <m:lMargin m:val="0"/>
</p><p> <m:rMargin m:val="0"/>
</p><p> <m:defJc m:val="centerGroup"/>
</p><p> <m:wrapIndent m:val="1440"/>
</p><p> <m:intLim m:val="subSup"/>
</p><p> <m:naryLim m:val="undOvr"/>
</p><p> </m:mathPr></w:WordDocument>
</p><p></xml><![endif]-->
Have been
using Pegasus version 4.63 build 325 on a W7 64bit (ultimate) system without problems.
Decided to make use of the Microsoft offer and to migrate slowly to W8 64bit (prof).
On W7 the
mailbox is located on a partition with other data. Loaded Pegasus into W8 and connected
it to the same mailbox as used in W7. All folders are visible and can be
opened. However, the New Mail folder, the identities and network configuration
are completely empty.
Under W7
the program remains functioning fine.
Any suggestion for cause and/or solution.
<w:WordDocument>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:DoNotPromoteQF/>
<w:Compatibility>
</w:Compatibility>
<m:mathPr>
<m:brkBinSub m:val="&#45;-"/>
<m:dispDef/>
</xml><![endif]-->
<p class="MsoNormal"><span style="mso-ansi-language:EN-GB" lang="EN-GB">Have been
Decided to make use of the Microsoft offer and to migrate slowly to W8 64bit (prof).</span></p>
<p class="MsoNormal"><span style="mso-ansi-language:EN-GB" lang="EN-GB">On W7 the
are completely empty.</span></p>
<p class="MsoNormal"><span style="mso-ansi-language:EN-GB" lang="EN-GB">Under W7
the program remains functioning fine.<span style="mso-spacerun:yes">&nbsp;
</span>Any suggestion for cause and/or solution. <span style="mso-spacerun:yes">&nbsp;</span><span style="mso-spacerun:yes">&nbsp;</span><span style="mso-spacerun:yes">&nbsp;</span></span></p><p class="MsoNormal">
