Thanks guys :)
The RTF option is on by default. I also tried turning it off.
We don't use identities. A member of staff starts Pegasus Mail with the -i <username> switch specified. Just one account is used for each staff member. If they need to look at another account, a second shortcut is created that uses the -i switch and the second username. Both shortcuts will then have the -ms switch specified so that multiple copies of Pegasus Mail can be opened at the same time.
It's a strange issue.
<P>Thanks guys :)</P>
<P>The RTF option is on by default. I also tried turning it off.</P>
<P>We don't use identities. A member of staff starts Pegasus Mail with the -i &lt;username&gt; switch specified. Just one account is used for each staff member. If they need to look at another account, a second shortcut is created that uses the -i switch and the second username. Both shortcuts will then have the -ms switch specified so that multiple copies of Pegasus Mail can be opened at the same time.</P>
<P>It's a strange issue.</P>
