Copy to self problem – redirected need fixing.
[quote user="bfluet"]
This folder is where I would expect the autofilter to be.
Also, right clicking on a folder name shows an Autofilters > "Manage autofilter folders" option which might provide some insight.
Greetings Brian,
Bingo. Right-on. ...and Thank you.
That was indeed the source of my issue.
The auto-filtering at the folder level was turned on and the culprit
was my own email address listed in the addresses column.
Oddly enough I have no recollection of
setting this up. I must have enabled this accidentally. Being my
satellite system it went unnoticed. Also of interest (at least to me)
on my main system the vast majority of my filters were set up
manually for years, probably well before the “auto-filter”
feature was introduced. Thanks again for all your help.
Cheers
Kevin  [:D]
[quote user="bfluet"]<p style="margin-bottom:0cm;">This folder is where I would expect the autofilter to be. </p><p style="margin-bottom:0cm;">Also, right clicking on a folder name shows an Autofilters > "Manage autofilter folders" option which might provide some insight. </p><p style="margin-bottom:0cm;"> </p><p>[/quote]</p><p> </p><p style="margin-bottom: 0cm">Greetings Brian,</p> <p style="margin-bottom: 0cm"> </p> <p style="margin-bottom: 0cm">Bingo. Right-on. ...and Thank you.</p> <p style="margin-bottom: 0cm">That was indeed the source of my issue. The auto-filtering at the folder level was turned on and the culprit was my own email address listed in the addresses column.</p> <p style="margin-bottom: 0cm">Oddly enough I have no recollection of setting this up. I must have enabled this accidentally. Being my satellite system it went unnoticed. Also of interest (at least to me) on my main system the vast majority of my filters were set up manually for years, probably well before the “auto-filter” feature was introduced. Thanks again for all your help.</p> <p style="margin-bottom: 0cm">Cheers</p> <p style="margin-bottom: 0cm">Kevin  [:D] </p> <p> </p>
Although
only recently observed, I've encountered the problem that my outgoing
email are not being posted to my 'copy to self' folder since Jan
21st, 2013.
I
upgraded from PM 4.61 to 4.63 about 4 days ago – problem not
resolved.
I
have confirmed that under “Tools/Options/Outgoing Mail/Copies to
self ('outbox') is engaged and that the folder selected is 'Copies
to self'
In
testing I've created another folder “Copy to me' – and set it
accordingly – result = problem not resolved. (Copy self folder is
now reset back to original)
I
have generated several test emails to confirm that the 'sticky' bit
in the message editor is set (checked). = Validated.
I've
checked the various filtering rules options available. Nothing is set
under filters. FYI this is my lap-top install of PM and all emails
are directed / copied to my ISP email address anyway.
Under
'Spam and Content control'; Content control is disabled, Global White
List is enabled and set to 750 entries, and there is lots and lots of
unused room remaining. Spamhalter is enabled, the junk folder is set
to 'Junk or suspicious mail', and no valid copy-to-self messages are
stored there.
As
per a forum entry (near below) The “STATE.PMJ” folder was edited
to to remove the 'select a mail folder RS=”. After restarting PM
and testing – the problem was not resolved.
From
forms: Copy to Self stopped working
STATE.PMJ,
either in the user's home or new mailbox directory (see Help
=> About Pegasus Mail => Info
for paths). Close Pegasus Mail, open the file with a simple plain
text editor like NotePad and remove the line starting with Select
a mail folder RS=
in the [SELFOL] section. After restarting Pegasus Mail it should
return to using default values.
PGP Plugin for Pegasus Mail:
<http://www.pmpgp.de/pmpgp/>
S/MIME Certificate Fingerprint:
26 5c a3 60 02 c6 e3 8a 75 70 d5 6a 67 ff d3 8d b0 b5 5e 5b
HOWEVER.
After grepping around I discovered that my 'copies to self' are being
re-directed to another folder (within a sub-folder). Coincidentally
it's turned out to be my girlfriends message folder. Not
that the coincidence is relevant, but that the copy operation is
being redirected elsewhere.
At
present I'm unable to determine where or how or why my 'copies' are
being directed to 'another folder'. As noted above the configuration
has been set and reset on several occasions yet this does not affect
the incorrect redirection.
The
Article
“Solution
found! I opened cache.pmm in a text editor,”
by
twegner
on 01-23-2011, 13:34 did not work either. I'm not using auto
filtering.
Request:
Does any one know what the fix is for this glitch?
in advance.
 Kevin
&lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;Although only recently observed, I&#039;ve encountered the problem that my outgoing email are not being posted to my &#039;copy to self&#039; folder since Jan 21&lt;sup&gt;st&lt;/sup&gt;, 2013.&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;I upgraded from PM 4.61 to 4.63 about 4 days ago &ndash; problem not resolved.&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;I have confirmed that under &ldquo;Tools/Options/Outgoing Mail/Copies to self (&#039;outbox&#039;) is engaged and that the folder selected is &#039;&lt;span lang=&quot;en-CA&quot;&gt;Copies to self&#039;&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;In testing I&#039;ve created another folder &ldquo;Copy to me&#039; &ndash; and set it accordingly &ndash; result = problem not resolved. (Copy self folder is now reset back to original)&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;I have generated several test emails to confirm that the &#039;sticky&#039; bit in the message editor is set (checked). = Validated.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;I&#039;ve checked the various filtering rules options available. Nothing is set under filters. FYI this is my lap-top install of PM and all emails are directed / copied to my ISP email address anyway.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;Under &#039;Spam and Content control&#039;; Content control is disabled, Global White List is enabled and set to 750 entries, and there is lots and lots of unused room remaining. Spamhalter is enabled, the junk folder is set to &#039;Junk or suspicious mail&#039;, and no valid copy-to-self messages are stored there.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-right: -0.11cm; margin-bottom: 0cm&quot;&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;As per a forum entry (near below) The &ldquo;STATE.PMJ&rdquo; folder was edited to to remove the &#039;select a mail folder RS=&rdquo;. After restarting PM and testing &ndash; the problem was not resolved.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt; &lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;a class=&quot;&quot; name=&quot;ctl00_ctl01_bcr_ctl00___ForumName&quot;&gt;&lt;/a&gt; &lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt; &lt;/span&gt;&lt;span lang=&quot;en-CA&quot;&gt;From forms: Copy to Self stopped working&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-left: 2.4cm&quot; align=&quot;JUSTIFY&quot;&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;STATE.PMJ, either in the user&#039;s home or new mailbox directory (see &lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;em&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;Help =&amp;gt; About Pegasus Mail =&amp;gt; Info&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;/em&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt; for paths). Close Pegasus Mail, open the file with a simple plain text editor like NotePad and remove the line starting with &lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;em&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;Select a mail folder RS=&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;/em&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt; in the [SELFOL] section. After restarting Pegasus Mail it should return to using default values.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;hr align=&quot;CENTER&quot; size=&quot;1&quot; width=&quot;142&quot;&gt; &lt;p style=&quot;margin-left: 2.4cm&quot; align=&quot;LEFT&quot;&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;Michael -- PGP Key ID (RSA 2048): 0xC45D831B PGP Plugin for Pegasus Mail: &amp;lt;http://www.pmpgp.de/pmpgp/&amp;gt; S/MIME Certificate Fingerprint: 26 5c a3 60 02 c6 e3 8a 75 70 d5 6a 67 ff d3 8d b0 b5 5e 5b &lt;/font&gt;&lt;/font&gt;&lt;/font&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;b&gt;&lt;font color=&quot;#dc2300&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;HOWEVER. After grepping around I discovered that my &#039;copies to self&#039; are being re-directed to another folder (within a sub-folder). Coincidentally it&#039;s turned out to be my girlfriends message folder. &lt;/span&gt;&lt;span lang=&quot;en-CA&quot;&gt;Not that the coincidence is relevant, but that the copy operation is being redirected elsewhere.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;/b&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;At present I&#039;m unable to determine where or how or why my &#039;copies&#039; are being directed to &#039;another folder&#039;. As noted above the configuration has been set and reset on several occasions yet this does not affect the incorrect redirection.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;The &lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;Article &lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;: &ldquo;&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;font color=&quot;#0000ff&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;Solution found! I opened cache.pmm in a text editor,&rdquo;&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt; by &lt;img src=&quot;http://community.pmail.com/Themes/default/images/user_IsOffline.gif&quot; name=&quot;graphics1&quot; align=&quot;BOTTOM&quot; border=&quot;0&quot; height=&quot;2&quot; width=&quot;2&quot;&gt; &lt;a href=&quot;http://community.pmail.com/members/twegner.aspx&quot;&gt;twegner&lt;/a&gt; &lt;img src=&quot;http://community.pmail.com/Themes/default/images/icon_post_show.gif&quot; name=&quot;graphics2&quot; align=&quot;BOTTOM&quot; border=&quot;0&quot; height=&quot;11&quot; width=&quot;10&quot;&gt;&amp;nbsp; on 01-23-2011, 13:34 did not work either. I&#039;m not using auto filtering.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;font color=&quot;#dc2300&quot;&gt;&lt;span lang=&quot;en-CA&quot;&gt;Request:&lt;/span&gt;&lt;/font&gt;&lt;span lang=&quot;en-CA&quot;&gt; Does any one know what the fix is for this glitch?&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&amp;nbsp;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;Thanks in advance. &lt;/font&gt;&lt;/font&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&amp;nbsp;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;Kevin&lt;/font&gt;&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt; &lt;/p&gt;
You've obviously worked hard at trying to figure this out but it sure sounds like a filter is directing the copies to self.
You said you don't use autofilters which should be confirmed by looking at the that the 'autofilter folders' entry in the Pegasus Mail information screen (Help > About Pegasus Mail > Info button). It should show zero.
Are there any copy to self filter rules in place (Tools > Mail filtering rules > Edit copy-self filtering rules)?
&lt;p&gt;You&#039;ve obviously worked hard at trying to figure this out but it sure sounds like a filter is directing the copies to self.&amp;nbsp; &lt;/p&gt;&lt;p&gt;You said you don&#039;t use autofilters which should be confirmed by looking at the that the &#039;autofilter folders&#039; entry in the Pegasus Mail information screen (Help &amp;gt; About Pegasus Mail &amp;gt; Info button). It should show zero. &lt;/p&gt;&lt;p&gt;Are there any copy to self filter rules in place (Tools &amp;gt; Mail filtering rules &amp;gt; Edit copy-self filtering rules)? &lt;/p&gt;
show zero.
Interesting. The output from the
Help/.../Info Button, contained the following line.
Autofiltering
folders: 1 (1 active, 0 inactive)
HOWEVER: The
(Tools /.../ Edit copy-self filtering rules)? indicates.
 &lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&amp;nbsp;bfluet Wrote:&lt;font color=&quot;#0000ff&quot;&gt;: You said you don&#039;t use autofilters which should be confirmed by looking at the that the &#039;autofilter folders&#039; entry in the Pegasus Mail information screen (Help &amp;gt; About Pegasus Mail &amp;gt; Info button). It should show zero. &lt;/font&gt; &lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;Interesting. The output from the Help/.../Info Button, contained the following line.&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font color=&quot;#dc2300&quot;&gt; Autofiltering folders: 1 (1 active, 0 inactive)&lt;/font&gt;&lt;/p&gt; &lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&lt;font color=&quot;#000000&quot;&gt;HOWEVER: The (Tools /.../ Edit copy-self filtering rules)? indicates.&lt;/font&gt;&lt;/p&gt;&lt;p style=&quot;margin-bottom: 0cm&quot;&gt;&amp;nbsp;&lt;img src=&quot;http://community.pmail.com/forums/data:image/png;base64,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&quot; alt=&quot;&quot;&gt;&lt;img src=&quot;http://community.pmail.com/forums/data:image/png;base64,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&quot; mce_src=&quot;http://community.pmail.com/forums/data:image/png;base64,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
In your first post you wrote:
[quote user="Kevin"]HOWEVER.
After grepping around I discovered that my 'copies to self' are being
re-directed to another folder (within a sub-folder). Coincidentally
it's turned out to be my girlfriends message folder. Not
that the coincidence is relevant, but that the copy operation is
being redirected elsewhere. [/quote]
This folder is where I would expect the autofilter to be.
Also, right clicking on a folder name shows an Autofilters > "Manage autofilter folders" option which might provide some insight.
&lt;p&gt;In your first post you wrote: &lt;/p&gt;&lt;p style=&quot;margin-bottom:0cm;&quot;&gt;[quote user=&quot;Kevin&quot;]&lt;b&gt;&lt;font color=&quot;#dc2300&quot;&gt;&lt;font face=&quot;Arial, sans-serif&quot;&gt;&lt;font size=&quot;2&quot;&gt;&lt;span&gt;HOWEVER. After grepping around I discovered that my &#039;copies to self&#039; are being re-directed to another folder (within a sub-folder). Coincidentally it&#039;s turned out to be my girlfriends message folder. &lt;/span&gt;&lt;span&gt;Not that the coincidence is relevant, but that the copy operation is being redirected elsewhere.&lt;/span&gt;&lt;/font&gt;&lt;/font&gt;&lt;/font&gt;&lt;/b&gt; [/quote]&lt;/p&gt;&lt;p style=&quot;margin-bottom:0cm;&quot;&gt;This folder is where I would expect the autofilter to be. &lt;/p&gt;&lt;p style=&quot;margin-bottom:0cm;&quot;&gt;Also, right clicking on a folder name shows an Autofilters &amp;gt; &quot;Manage autofilter folders&quot; option which might provide some insight. &lt;/p&gt;&lt;p style=&quot;margin-bottom:0cm;&quot;&gt;&amp;nbsp;&lt;/p&gt;
