Pls show recipient (not sender) in "From" column of "Sent" folders
It doesn't matter in which folder the copy to self is ... Pegasus shows the recipient due to the special format of his copy to self. For me it works in every IMAP-Folder. Have a look at the raw text.
If you generate a outgoing copy with another mailreader on same IMAP-Mailbox, that mailreader will generate a simple copy of that mail in SENT. For Pegasus this is a normal mail - no copy to self.
Note: Copy to Self with Pegasus is not the same as Outgoing Copy with any other mailreader.
bye   Olaf
<p>It doesn't matter in which folder the copy to self is ... Pegasus shows the recipient due to the special format of his copy to self. For me it works in every IMAP-Folder. Have a look at the raw text.</p><p>If you generate a outgoing copy with another mailreader on same IMAP-Mailbox, that mailreader will generate a simple copy of that mail in SENT. For Pegasus this is a normal mail - no copy to self. </p><p> Note: Copy to Self with Pegasus is not the same as Outgoing Copy with any other mailreader.</p><p>bye   Olaf</p><p> </p>
In Pegasus's local "Copies to Self" folder (the default location for copies of outgoing mail), it very sensibly shows the recipient rather than the sender in column 1 (even though, as in all other folders, the column-header says "From"). Is there a reason why it doesn't do the same in IMAP folders called "Sent"? It would be very helpful to be able to sort such folders by the value in the "From" column -- but only if it shows the recipient; it's pretty useless sorting such folders by sender when the sender is the same (yourself) for all emails in that folder.
Perhaps this is something the development team for the beta 5 version could consider?
<p>In Pegasus's local "Copies to Self" folder (the default location for copies of outgoing mail), it very sensibly shows the recipient rather than the sender in column 1 (even though, as in all other folders, the column-header says "From"). Is there a reason why it doesn't do the same in IMAP folders called "Sent"? It would be very helpful to be able to sort such folders by the value in the "From" column -- but only if it shows the recipient; it's pretty useless sorting such folders by sender when the sender is the same (yourself) for all emails in that folder. Perhaps this is something the development team for the beta 5 version could consider?</p><p> </p>
