pegasus problems sending messages
[quote user="veblen"]
 After a slight  glitch with my Dell laptop I was left able to download messages but unable to send .
When one of the mail servers that I use is acting up,  I have found that I can send mail using Gmail configured for
"Sending mail from a different address", <https://support.google.com/mail/answer/22370>.
[quote user=&quot;veblen&quot;]&lt;p&gt;&amp;nbsp;After a slight&amp;nbsp; glitch with my Dell laptop I was left able to download messages but unable to send .&lt;/p&gt;&lt;p&gt;[/quote]&lt;/p&gt;&lt;p&gt;When one of the mail servers that I use is acting up,&amp;nbsp; I have found that I can send mail using Gmail configured for&lt;/p&gt;&lt;p&gt;&quot;Sending mail from a different address&quot;, &amp;lt;https://support.google.com/mail/answer/22370&amp;gt;.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
messages but unable to send .This is what came back to me as undelivered
message:
   550-mgt.gla.ac.uk not hosted on this server - please use correct MX
Your original mail message follows:
X-PM-Identity: <Default>
To: dryden@mgt.gla.ac.uk
Date: Fri, 25 Oct 2013 11:34:59 +0100
MIME-Version: 1.0
Subject: test 5
Message-ID: <526A4953.10275.454164@dryden.mgt.gla.ac.uk>
X-Confirm-Reading-To: "Myles" <dryden@mgt.gla.ac.uk>
X-pmrqc: 1
Return-receipt-to: "Myles" <dryden@mgt.gla.ac.uk>
Priority: normal
X-mailer: Pegasus Mail for Windows (4.52)
Content-type: text/plain; charset=US-ASCII
Content-transfer-encoding: 7BIT
I am using Pegasus Mail  4.5 with Vista.
Can anyone please help me to get back on track!
&lt;p&gt;&amp;nbsp;After a slight&amp;nbsp; glitch with my Dell laptop I was left able to download messages but unable to send .This is what came back to me as undelivered message:&lt;/p&gt;&lt;p&gt;*******************************************************************&lt;/p&gt;&lt;p&gt;Delivery has failed on the enclosed message for the following reasons reported either by the mail delivery system on the mail relay host or by the local TCP/IP transport module:&lt;/p&gt;&lt;p&gt;&amp;nbsp;&amp;nbsp; 550-mgt.gla.ac.uk not hosted on this server - please use correct MX&lt;/p&gt;&lt;p&gt;Your original mail message follows: --------------------------------------------------------&lt;/p&gt;&lt;p&gt;X-PM-Identity: &amp;lt;Default&amp;gt; From: &quot;Myles&quot; &amp;lt;&lt;a href=&quot;mailto:dryden@mgt.gla.ac.uk&quot;&gt;dryden@mgt.gla.ac.uk&lt;/a&gt;&amp;gt; To: &lt;a href=&quot;mailto:dryden@mgt.gla.ac.uk&quot;&gt;dryden@mgt.gla.ac.uk&lt;/a&gt; Date: Fri, 25 Oct 2013 11:34:59 +0100 MIME-Version: 1.0 Subject: test 5 Message-ID: &amp;lt;&lt;a href=&quot;mailto:526A4953.10275.454164@dryden.mgt.gla.ac.uk&quot;&gt;526A4953.10275.454164@dryden.mgt.gla.ac.uk&lt;/a&gt;&amp;gt; X-Confirm-Reading-To: &quot;Myles&quot; &amp;lt;&lt;a href=&quot;mailto:dryden@mgt.gla.ac.uk&quot;&gt;dryden@mgt.gla.ac.uk&lt;/a&gt;&amp;gt; X-pmrqc: 1 Return-receipt-to: &quot;Myles&quot; &amp;lt;&lt;a href=&quot;mailto:dryden@mgt.gla.ac.uk&quot;&gt;dryden@mgt.gla.ac.uk&lt;/a&gt;&amp;gt; Priority: normal X-mailer: Pegasus Mail for Windows (4.52) Content-type: text/plain; charset=US-ASCII Content-transfer-encoding: 7BIT Content-description: Mail message body&lt;/p&gt;&lt;p&gt; ******************************************************************************************* &amp;nbsp;&lt;/p&gt;&lt;p&gt;I am using Pegasus Mail&amp;nbsp; 4.5 with Vista.&lt;/p&gt;&lt;p&gt;Can anyone please help me to get back on track!&lt;/p&gt;&lt;p&gt;Thanks&lt;/p&gt;
Almost certainly a configuration error at the recipient server.  Try sending it again - if you still get an error, check your outgoing server is correct.
Almost certainly a configuration error at the recipient server.&amp;nbsp;&amp;nbsp;Try sending it again - if you still get an error, check your outgoing server is correct.
the entry for smtp is ok in pegasus config.I think some other setting has been disturbed .
I think there is a program involved called  TC/IP but i,m not familiar with its settings.
&lt;p&gt;the entry for smtp is ok in pegasus config.I think some other setting has been disturbed .&lt;/p&gt;&lt;p&gt;I think there is a program involved called&amp;nbsp; TC/IP but i,m not familiar with its settings.&amp;nbsp;&lt;/p&gt;
TCP/IP is just the protocol used to transport the message over the internet.  Is all your other outgoing mail working?
What server are you using for your outgoing (SMTP) mail?
[quote user=&quot;veblen&quot;] &lt;P&gt;the entry for smtp is ok in pegasus config.I think some other setting has been disturbed .&lt;/P&gt; &lt;P&gt;I think there is a program involved called&amp;nbsp; TC/IP but i,m not familiar with its settings.&amp;nbsp;&lt;/P&gt; &lt;P&gt;[/quote]&lt;/P&gt; &lt;P&gt;TCP/IP is just the protocol used to transport the message over the internet.&amp;nbsp; Is all your other outgoing mail working?&lt;/P&gt; &lt;P&gt;What server are you using for your outgoing (SMTP) mail? &lt;/P&gt;
