MSendTo body
Found.
The problem is when I attach a file either with -FB or -FT. It looks to forget that the body is an HTML.
<P>Found.</P> <P>The problem is when I attach a file either with -FB or -FT. It looks to forget that the body is an HTML.</P>
I am testing the MSendTo command line utility and found that it doesn't detect HTML bodies.
This is the input file I wrote:
-TO admin@myserver.com
-SUBJECT "eFactura 1/12/2013"
-BODY FACTURA.HTM
-FB FACTURA.XML
-FROM admin@myotherserver.org
And the FACTURA.HTM:
<html>
<body>
TEST
</body>
</html>
I am testing the MSendTo command line utility and found that it doesn&#039;t detect HTML bodies. &lt;P&gt;This is the input file I wrote:&lt;/P&gt; &lt;P&gt;-TO &lt;A href=&quot;mailto:admin@myserver.com&quot;&gt;admin@myserver.com&lt;/A&gt; -SUBJECT &quot;eFactura 1/12/2013&quot; -BODY FACTURA.HTM -FB FACTURA.XML -FROM &lt;A href=&quot;mailto:admin@myotherserver.org&quot;&gt;admin@myotherserver.org&lt;/A&gt; &lt;/P&gt; &lt;P&gt;And the FACTURA.HTM:&lt;/P&gt; &lt;P&gt;&amp;lt;html&amp;gt; &amp;lt;body&amp;gt; TEST &amp;lt;/body&amp;gt; &amp;lt;/html&amp;gt;&lt;/P&gt; &lt;P&gt;Thanks,&lt;/P&gt;
