Thanks for the help.  Below is my Mercury.ini file.  Any advice will be great!
#  Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#  This sample file implements most of the possible switches for each
#  module, but you can edit it to do less if you wish.
#  Anything after a '#' to the end of the line is a comment and
#  is stripped out before parsing. Trailing and leading whitespace
#  is also stripped before parsing. Many sample commands have been
#  left in this file commented out for reference purposes.
#  Note that in general, manual modification of this file is NOT
#  RECOMMENDED - use the Mercury "Configuration" menu to change the
#  program's settings wherever possible.
[General]
myname:          neocap.org    # Canonical name for this server
timezone:        -0500    # Time Zone to add to date fields
file_api:        1    # Use the file api instead of queues
mailqueue:       C:\MERCURY\QUEUE    # Where mail should be put for delivery
smtpqueue:       C:\MERCURY\QUEUE    # Where the SMTP client should look for mail
newmail_path:    C:\PMAIL\MAIL\~N    # Where to find the users' WinPMail mailboxes.
[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
# MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile:      C:\MERCURY\Mercury\FAILURE.MER    # Delivery failure notification template
confirmfile:   C:\MERCURY\Mercury\CONFIRM.MER    # Delivery confirmation template
aliasfile:     C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file
synfile:       C:\MERCURY\Mercury\SYNONYM.MER    # User synonym database
listfile:      C:\MERCURY\Mercury\LISTS.MER    # List of lists
logfile:       C:\MERCURY\Logs\Core\~y-~m-~d.log    # Traffic logging file
logwidth:      30    # Width of address fields in logfile
retpath:       1    # Do/Don't use 'return-path' for errors
maxhops:       30    # Used to detect mailing loops
gullible:      0    # If NZ, don't validate 'From' fields
poll:          10   # Seconds between queue polling cycles
scratch:       C:\MERCURY\Scratch    # Where we can write temp files
returnlines:   15    # How many lines of failed messages to return
postmaster:    rblower    # NetWare UIC of postmaster
broadcast:     1    # Yes, we want broadcast notifications, but
receipts:      0    # ... no broadcasts for receipt confirmations
PM_notify:     1    # Do/Don't send errors to the postmaster
change_owner:  1    # Change message ownership to recipient
auto_tzone:    1    # If NZ, obtain timezone information from OS
LogLevel:      15    # System message reporting level
LogMax:        100    # Maximum number of system messages to store
RetryPeriod:   1    # Period between job retries (minutes)
MaxRetries:    16    # Maximum number of times a job can fail
TwoPasses:     1    # If NZ, process submission queue in 2 passes
Autoaddress:   -121    # If NZ, auto-generate user addresses based on name
Daily_exit:    0    # If NZ, auto-restart each day after maintenance
No_Areply:     0    # If NZ, disable automatic replies system-wide
Alt_Forward:   0    # If NZ, allow alternate forwarding specification
Maint_hour:    2    # Hour for daily maintenance (24-hour clock)
Maint_min:     0    # Minute for daily maintenance
Retry_Mode:    0    # If NZ, use progressive backoff for queue retries
Local_DSNs:    1    # If NZ generate Delivery Status for local users only
DSN_time1:     10800    # Seconds deferred before first DSN is sent
DSN_time2:     86400    # Seconds deferred before second DSN is sent
DSN_time3:     259200    # Seconds deferred before third DSN is sent
Host_in_title: 0    # If NZ, show hostname in system tray and taskbar
Lingering:     0    # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60   # Seconds before a lingering mailbox is shut down
Alert_Host:    notify.pmail.com    # Host to check for licensee advisories
Alert_Interval: 720   # Frequency in minutes (min 240) for checks
Alert_Flags:   7    # Flags controlling advisory checks
Alert_Users:   r.blower@neocap.org    # Local users to receive advisories
[MercuryC]
Host : smtp.centurylink.net
Failfile : C:\MERCURY\Mercury\FAILURE.MER
Poll : 30
Scratch : C:\MERCURY\scratch
ReturnLines : 15
Timeout : 30
ESMTP : 1
SMTP_Username: xxx Removed XXX
SMTP_Password: XXX Removed XXX
POP3_Auth : 0
Logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log
Log_Verbose : 0
Session_logging : C:\MERCURY\Sessions\MercuryC
Session_logmode : 1
[MercuryE]
HELO : mail.neocap.org
Session_logging : C:\MERCURY\Sessions\MercuryE
Session_logmode : 0
Poll : 30
Timeout : 60
Nameservers : 205.244.194.36, 204.117.214.10, 8.8.8.8, 192.168.109.5
Logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log
Log_Verbose : 0
DNS_Timeout : 20
DNS_Retries : 4
Transcripts : 1
MaxThreads : 10
[MercuryD]
Timeout : 30
Poll : 30
Session_logging : C:\MERCURY\Sessions\MercuryD
Session_logmode : 0
[MercuryS]
Debug : 1
Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log
Timeout : 30
Relay : 0
Strict_Relay : 0
Allow_Illegals : 1
SMTP_Authentication : 0
Auth_File : smtpauth
Killfile : KillFile
Session_logging : C:\MERCURY\Sessions\MercuryS
Session_logmode : 0
Compliance_Settings : 488
Maximum_Failed_Rcpts : 6
Max_Relay_Attempts : 3
SSL_Mode : 0
SSL_Certfile : C:\MERCURY\cert.txt
ST_Blacklisting : 288
No_VRFY : 1
SMTP_ConnFlags : 0
Compliance_Exceptions : smtpExcp
[MercuryP]
Logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 0
Session_logging : C:\MERCURY\Sessions\MercuryP
Session_logmode : 1
Timeout : 600
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup            :     TESTGRP
[Domains]
n.neocap.co.trumbull.oh.us: neocap.org
n.neocap.co.trumbull.oh.us: [69.34.18.154]
n: neocap.org
[Maiser]
Helpfile:        C:\MERCURY\Mercury\MAISER.HLP   # Help sent on failed maiser requests
Lookupfile:      C:\MERCURY\Mercury\MAISER.LKP   # Format file for the 'lookup' command
Send_dir:        C:\MERCURY\Mercury\SENDABLE   # Directory for the 'send' command
Logfile:         C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG   # Mail server log file
Notify:          C:\MERCURY\Mercury\TMP   # Dir. for pending 'notify' commands
[MercuryH]
Addressbook : C:\PMAIL\Programs\personal.pmr
Logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log
Administrator : rblower@neocap.org
Timeout : 30
[MercuryI]
Logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log
Timeout : 120
Server_Port : 143
SSL_Port: 993
Charset : ISO-8859-1
Session_logging : C:\MERCURY\Sessions\MercuryI
Session_logmode : 0
Idle_Timeout : 1800
SSL_Mode : 1
Login_Disabled : 0
No_NUL_passwords : 1
[MercuryB]
Logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log
Timeout : 120
Server_Port : 80
Session_logging : C:\MERCURY\Sessions\MercuryB
Session_logmode : 0
Idle_Timeout : 1800
URL_Base : neocap.org
SSL_Mode : 1
Alt_Server_Port : 443
[Groups]
[Rewrite]
[Statistics]
StatFlags:    3  # Statistical reporting settings
StatFiles:    C:\MAILSTATS  # Directory to write stat log files
StatMail:     t.williams@neocap.org  # Address to send stat log files
STF_Hours:    24  # How often to write stat log files
STM_Hours:    24  # How often to e-mail stat log files
        <p>Thanks for the help.&nbsp; Below is my Mercury.ini file.&nbsp; Any advice will be great!</p><p>#&nbsp; MERCURY.INI generated by Mercury Setup
#&nbsp; Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#&nbsp; This sample file implements most of the possible switches for each
#&nbsp; module, but you can edit it to do less if you wish.
#&nbsp; Anything after a '#' to the end of the line is a comment and
#&nbsp; is stripped out before parsing. Trailing and leading whitespace
#&nbsp; is also stripped before parsing. Many sample commands have been
#&nbsp; left in this file commented out for reference purposes.
#&nbsp; Note that in general, manual modification of this file is NOT
#&nbsp; RECOMMENDED - use the Mercury "Configuration" menu to change the
#&nbsp; program's settings wherever possible.
[General]
myname:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; neocap.org&nbsp;&nbsp;&nbsp; # Canonical name for this server
timezone:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; -0500&nbsp;&nbsp;&nbsp; # Time Zone to add to date fields
file_api:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Use the file api instead of queues
mailqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\QUEUE&nbsp;&nbsp;&nbsp; # Where mail should be put for delivery
smtpqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\QUEUE&nbsp;&nbsp;&nbsp; # Where the SMTP client should look for mail
newmail_path:&nbsp;&nbsp;&nbsp; C:\PMAIL\MAIL\~N&nbsp;&nbsp;&nbsp; # Where to find the users' WinPMail mailboxes.
[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
# MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\FAILURE.MER&nbsp;&nbsp;&nbsp; # Delivery failure notification template
confirmfile:&nbsp;&nbsp; C:\MERCURY\Mercury\CONFIRM.MER&nbsp;&nbsp;&nbsp; # Delivery confirmation template
aliasfile:&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\ALIAS.MER&nbsp;&nbsp;&nbsp; # System-wide alias file
synfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\SYNONYM.MER&nbsp;&nbsp;&nbsp; # User synonym database
listfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\LISTS.MER&nbsp;&nbsp;&nbsp; # List of lists
logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Logs\Core\~y-~m-~d.log&nbsp;&nbsp;&nbsp; # Traffic logging file
logwidth:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Width of address fields in logfile
retpath:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't use 'return-path' for errors
maxhops:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Used to detect mailing loops
gullible:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, don't validate 'From' fields
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10&nbsp;&nbsp; # Seconds between queue polling cycles
scratch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Scratch&nbsp;&nbsp;&nbsp; # Where we can write temp files
returnlines:&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
postmaster:&nbsp;&nbsp;&nbsp; rblower&nbsp;&nbsp;&nbsp; # NetWare UIC of postmaster
broadcast:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Yes, we want broadcast notifications, but
receipts:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # ... no broadcasts for receipt confirmations
PM_notify:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't send errors to the postmaster
change_owner:&nbsp; 1&nbsp;&nbsp;&nbsp; # Change message ownership to recipient
auto_tzone:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, obtain timezone information from OS
LogLevel:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # System message reporting level
LogMax:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 100&nbsp;&nbsp;&nbsp; # Maximum number of system messages to store
RetryPeriod:&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Period between job retries (minutes)
MaxRetries:&nbsp;&nbsp;&nbsp; 16&nbsp;&nbsp;&nbsp; # Maximum number of times a job can fail
TwoPasses:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, process submission queue in 2 passes
Autoaddress:&nbsp;&nbsp; -121&nbsp;&nbsp;&nbsp; # If NZ, auto-generate user addresses based on name
Daily_exit:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, auto-restart each day after maintenance
No_Areply:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, disable automatic replies system-wide
Alt_Forward:&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, allow alternate forwarding specification
Maint_hour:&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp; # Hour for daily maintenance (24-hour clock)
Maint_min:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Minute for daily maintenance
Retry_Mode:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, use progressive backoff for queue retries
Local_DSNs:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ generate Delivery Status for local users only
DSN_time1:&nbsp;&nbsp;&nbsp;&nbsp; 10800&nbsp;&nbsp;&nbsp; # Seconds deferred before first DSN is sent
DSN_time2:&nbsp;&nbsp;&nbsp;&nbsp; 86400&nbsp;&nbsp;&nbsp; # Seconds deferred before second DSN is sent
DSN_time3:&nbsp;&nbsp;&nbsp;&nbsp; 259200&nbsp;&nbsp;&nbsp; # Seconds deferred before third DSN is sent
Host_in_title: 0&nbsp;&nbsp;&nbsp; # If NZ, show hostname in system tray and taskbar
Lingering:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60&nbsp;&nbsp; # Seconds before a lingering mailbox is shut down
Alert_Host:&nbsp;&nbsp;&nbsp; notify.pmail.com&nbsp;&nbsp;&nbsp; # Host to check for licensee advisories
Alert_Interval: 720&nbsp;&nbsp; # Frequency in minutes (min 240) for checks
Alert_Flags:&nbsp;&nbsp; 7&nbsp;&nbsp;&nbsp; # Flags controlling advisory checks
Alert_Users:&nbsp;&nbsp; r.blower@neocap.org&nbsp;&nbsp;&nbsp; # Local users to receive advisories
[MercuryC]
Poll : 30
ReturnLines : 15
Timeout : 30
ESMTP : 1
POP3_Auth : 0
Log_Verbose : 0
Session_logmode : 1
[MercuryE]
Session_logmode : 0
Poll : 30
Timeout : 60
Log_Verbose : 0
DNS_Timeout : 20
DNS_Retries : 4
Transcripts : 1
MaxThreads : 10
[MercuryD]
Timeout : 30
Poll : 30
Session_logmode : 0
[MercuryS]
Debug : 1
Timeout : 30
Relay : 0
Strict_Relay : 0
Allow_Illegals : 1
Killfile : KillFile
Session_logmode : 0
SSL_Mode : 0
No_VRFY : 1
SMTP_ConnFlags : 0
[MercuryP]
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 1
Session_logmode : 1
Timeout : 600
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; TESTGRP
[Domains]
n: neocap.org
[Maiser]
Maiser:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Maiser&nbsp;&nbsp; # 'Username' of mail server account
Helpfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\MAISER.HLP&nbsp;&nbsp; # Help sent on failed maiser requests
Lookupfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\MAISER.LKP&nbsp;&nbsp; # Format file for the 'lookup' command
Send_dir:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\SENDABLE&nbsp;&nbsp; # Directory for the 'send' command
Logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG&nbsp;&nbsp; # Mail server log file
Notify:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\TMP&nbsp;&nbsp; # Dir. for pending 'notify' commands
NoList:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; N&nbsp;&nbsp; # If 'Y', disable the 'list' command
Local_only:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Y&nbsp;&nbsp; # If 'Y', local 'notify' commands only
[MercuryH]
Timeout : 30
[MercuryI]
Timeout : 120
Server_Port : 143
SSL_Port: 993
Session_logmode : 0
Idle_Timeout : 1800
SSL_Mode : 1
Login_Disabled : 0
[MercuryB]
Timeout : 120
Server_Port : 80
Session_logmode : 0
Idle_Timeout : 1800
SSL_Mode : 1
[Groups]
[Rewrite]
[Statistics]
StatFlags:&nbsp;&nbsp;&nbsp; 3&nbsp; # Statistical reporting settings
StatFiles:&nbsp;&nbsp;&nbsp; C:\MAILSTATS&nbsp; # Directory to write stat log files
StatMail:&nbsp;&nbsp;&nbsp;&nbsp; t.williams@neocap.org&nbsp; # Address to send stat log files
STF_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to write stat log files
STM_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to e-mail stat log files
&nbsp;</p>
