Postition of Spell Check on Screen When Using 2 Monitors???
Try WINSIZE ... but it's not trivial.
Some Contextmenues may display on wrong monitor too.
bye    Olaf
<p>Try WINSIZE ... but it's not trivial.</p><p>Some Contextmenues may display on wrong monitor too.</p><p>bye    Olaf</p><p> </p><p> </p>
Using 4.70.....Not a deal breaker, but I use 2 monitors with my pc and the spell check box always shows up half on the left monitor and half on the right.
I don't think any other program I use that generates a similar pop-up window does that.
Is this a bug and/or can it be adjusted somehow?   thnx
<p>Using 4.70.....Not a deal breaker, but I use 2 monitors with my pc and the spell check box always shows up half on the left monitor and half on the right.</p><p>I don't think any other program I use that generates a similar pop-up window does that.</p><p>Is this a bug and/or can it be adjusted somehow?   thnx </p>
