The introduction of the -ROAM command line switch solved the problem of keeping up with drive letters. I don't recall if it works with v4.41 though. Check Help > Commandline options and see if it is listed.
From the current help file:
-ROAM This option tells Pegasus Mail that it should ignore the configured drive letter when locating user mailboxes and mail files, and should instead use the drive letter of the drive from which WINPM-32.EXE was run. If Pegasus Mail and your mailbox directories are located on the same physical drive, you should always use this option. -ROAM greatly simplifies running the program on Peer-to-Peer and non-NetWare networks, because it allows the same copy of the program tobe run no matter what drive letter mappings exist on the particular workstation where it runs. This switch also allows you to install a complete, working copy of Pegasus Mail, complete with mailboxes, onto a memory stick, and to use that memory stick in any computer where it is subsequently plugged. You must not use this switch if Pegasus Mail and your mailbox directories cannot be accessed using the same drive letter. This switch is ignored and has no effect in either Novell NetWare operating mode.
As for running pconfig.exe on a 64-bit Win7 machine you need run it in a DOS emulator like DOSBOX.
<p>The introduction of the -ROAM command line switch solved the problem of keeping up with drive letters.&nbsp; I don't recall if it works with v4.41 though.&nbsp; Check Help &gt; Commandline options and see if it is listed.
</p><p>From the current help file:</p><blockquote><p><i>-ROAM&nbsp; This option tells Pegasus Mail that it should ignore the configured drive letter when locating user mailboxes and mail files, and should instead use the drive letter of the drive from which WINPM-32.EXE was run. If Pegasus Mail and your mailbox directories are located on the same physical drive, you should always use this option. -ROAM greatly simplifies running the program on Peer-to-Peer and non-NetWare networks, because it allows the same copy of the program tobe run no matter what drive letter mappings exist on the particular workstation where it runs. This switch also allows you to install a complete, working copy of Pegasus Mail, complete with mailboxes, onto a memory stick, and to use that memory stick in any computer where it is subsequently plugged. You must not use this switch if Pegasus Mail and your mailbox directories cannot be accessed using the same drive letter. This switch is ignored and has no effect in either Novell NetWare operating mode.</i></p></blockquote><p>As for running pconfig.exe on a 64-bit Win7 machine you need run it in a DOS emulator like DOSBOX.
