Mercury crashes way to often...
Thx, I will work through the provided links.
The new TCP/IP module could explain the network problems and therefor the crashes and it fits to my observation that this network issues did not happen before the installing the new beta.
Can you provide the "special version of mercury.exe" so that I can send the logs after the next crash?
Konrad
<p>Thx, I will work through the provided links. </p><p>The new TCP/IP module could explain the network problems and therefor the crashes and it fits to my observation that this network issues did not happen before the installing the new beta.</p><p>Can you provide the "special version of mercury.exe" so that I can send the logs after the next crash?</p><p> </p><p>Konrad </p>
Hi All,
My Mercury installation (v4.8 beta on a Windows XP SP3 VM image - no AV software) is crashing way to often but I cannot find a way to find out what is going on. The only thing I know is that at least some of the crashes are related to sending mails to a Mercury mailing lists (with more than 1000 addresses). I checked every possible log file but there is no indication of any problem. Only the loader log file is showing the crashes. Here is an extraction of my loader log for 2014 (the crashes yesterday and today are related to such mailing list mails):
14-01-02.1741: Restarting Mercury after apparent abnormal termination
14-01-28.1308: Restarting Mercury after apparent abnormal termination
14-01-31.1750: Restarting Mercury after apparent abnormal termination
14-02-12.2242: Restarting Mercury after apparent abnormal termination
14-02-12.2308: Restarting Mercury after apparent abnormal termination
14-03-25.1856: Restarting Mercury after apparent abnormal termination
14-04-08.1756: Restarting Mercury after apparent abnormal termination
14-04-11.2157: Restarting Mercury after apparent abnormal termination
14-04-16.2208: Restarting Mercury after apparent abnormal termination
14-04-30.1036: Restarting Mercury after apparent abnormal termination
14-04-30.1043: Restarting Mercury after apparent abnormal termination
14-05-01.1310: Restarting Mercury after apparent abnormal termination
14-05-01.1317: Restarting Mercury after apparent abnormal termination
14-05-01.1323: Restarting Mercury after apparent abnormal termination
14-05-01.1330: Restarting Mercury after apparent abnormal termination
What would you suggest?
Konrad
<p>Hi All,</p><p>My Mercury installation (v4.8 beta on a Windows XP SP3 VM image - no AV software) is crashing way to often but I cannot find a way to find out what is going on. The only thing I know is that at least some of the crashes are related to sending mails to a Mercury mailing lists (with more than 1000 addresses). I checked every possible log file but there is no indication of any problem. Only the loader log file is showing the crashes. Here is an extraction of my loader log for 2014 (the crashes yesterday and today are related to such mailing list mails):</p><p>... 14-01-02.1741: Restarting Mercury after apparent abnormal termination 14-01-28.1308: Restarting Mercury after apparent abnormal termination 14-01-31.1750: Restarting Mercury after apparent abnormal termination 14-02-12.2242: Restarting Mercury after apparent abnormal termination 14-02-12.2308: Restarting Mercury after apparent abnormal termination 14-03-25.1856: Restarting Mercury after apparent abnormal termination 14-04-08.1756: Restarting Mercury after apparent abnormal termination 14-04-11.2157: Restarting Mercury after apparent abnormal termination 14-04-16.2208: Restarting Mercury after apparent abnormal termination <b>14-04-30.1036: Restarting Mercury after apparent abnormal termination 14-04-30.1043: Restarting Mercury after apparent abnormal termination 14-05-01.1310: Restarting Mercury after apparent abnormal termination 14-05-01.1317: Restarting Mercury after apparent abnormal termination 14-05-01.1323: Restarting Mercury after apparent abnormal termination 14-05-01.1330: Restarting Mercury after apparent abnormal termination  </b> </p><p>What would you suggest? </p><p>Konrad </p>
Mercury crashed another 4 times during the last hour while processing another mailing list mail!
And I can see lots of
Network write failure during data transmission to <IP address>
TCP/IP error during processing.
errors in the Mercuy SMTP client console window. Could that be related?
Konrad
&lt;p&gt;Mercury crashed another 4 times during the last hour while processing another mailing list mail!&lt;/p&gt;&lt;p&gt;And I can see lots of&lt;/p&gt;&lt;p&gt;&lt;i&gt;Network write failure during data transmission to &amp;lt;IP address&amp;gt;&lt;/i&gt;&lt;/p&gt;&lt;p&gt;&lt;i&gt;TCP/IP error during processing.&lt;/i&gt;&lt;/p&gt;&lt;p&gt;errors in the Mercuy SMTP client console window. Could that be related?&lt;/p&gt;&lt;p&gt;Konrad &lt;/p&gt;
As you are running a beta version it could be that we should move this thread to the beta forum, but on the other hand it could be a general problem anyway, so let's keep it here for the time being.
In case it's a beta problem, start by checking the version. If it's not beta 15 (mercury.exe modified March 31, 2014) please contact me.
In case it's a networking issue we would instead look into how the virtual machine handles network connections. It could be that there are some limitations in how the virtual network adapter works, which perhaps could be fixed by changing VM settings, updating the VM software, or testing some other type of VM software. When we know the specific conditions leading to the crashes we could as well see if we can make Mercury more resilient to that type of network failure.
&lt;p&gt;As you are running a beta version it could be that we should move this thread to the beta forum, but on the other hand it could be a general problem anyway, so let&#039;s keep it here for the time being.&lt;/p&gt;&lt;p&gt;In case it&#039;s a beta problem, start by checking the version. If it&#039;s not beta 15&lt;span style=&quot;font-size: 10pt;&quot;&gt;&amp;nbsp;(mercury.exe modified March 31, 2014) please contact me.&lt;/span&gt;&lt;/p&gt;&lt;p&gt;In case it&#039;s a networking issue we would instead look into how the virtual machine handles network connections. It could be that there are some limitations in how the virtual network adapter works, which perhaps could be fixed by changing VM settings, updating the VM software, or testing some other type of VM software. When we know the specific conditions leading to the crashes we could as well see if we can make Mercury more resilient to that type of network failure.&lt;/p&gt;
Hi Rolf,
I'm not really sure what I could check related to my VM settings. I'm using VMware and I'm running this setup for years now. I had crashes from time to time but never so often so I doubt that the VM settings are the cause for my crashes. I have also not changed anything on the server. Updating the software is a license issue and therefor not that easy and testing another type of WM software is also not something I can easily do.
Do you see any way how we could figure out what is going and why Mercury is crashing so often? As said, this is new that I have so many problems with mailing lists (we do use them very often and so far, there was never a problem related to that and I never have seen this network errors before in the SMTP client console).
I know that I have mentioned this before, but it would be very helpful if Mercury could print a stack trace before exiting. Maybe you can talk to David about this?
Thx!
Konrad
&lt;p&gt;Hi Rolf,&lt;/p&gt;&lt;p&gt;I&#039;m not really sure what I could check related to my VM settings. I&#039;m using VMware and I&#039;m running this setup for years now. I had crashes from time to time but never so often so I doubt that the VM settings are the cause for my crashes. I have also not changed anything on the server. Updating the software is a license issue and therefor not that easy and testing another type of WM software is also not something I can easily do.&lt;/p&gt;&lt;p&gt;Do you see any way how we could figure out what is going and why Mercury is crashing so often? As said, this is new that I have so many problems with mailing lists (we do use them very often and so far, there was never a problem related to that and I never have seen this network errors before in the SMTP client console).&lt;/p&gt;&lt;p&gt;I know that I have mentioned this before, but it would be very helpful if Mercury could print a stack trace before exiting. Maybe you can talk to David about this?&lt;/p&gt;&lt;p&gt;Thx! &lt;/p&gt;&lt;p&gt;Konrad &lt;/p&gt;
Just checked my SMTP client log files and I found lots of TCP/IP errors in there (unfortunately, I have not log file before the upgrade to 4.8 beta):
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-17.log"(911,28):E 20140217 110347 53008239 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-22.log"(24,28):E 20140222 063152 5307ce37 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-24.log"(102,28):E 20140224 090057 5307ce71 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-27.log"(451,28):E 20140227 160631 5307cf96 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-06.log"(232,28):E 20140306 131359 5311b2b5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-12.log"(2765,28):E 20140312 152303 531c9f2c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(979,28):E 20140318 200908 531cacc5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(988,28):E 20140318 202244 531cacc6 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(997,28):E 20140318 203915 531cacc7 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1014,28):E 20140318 205251 531cacc9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1023,28):E 20140318 210924 531cacca TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1040,28):E 20140318 212300 531caccc TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1065,28):E 20140318 213932 531caccf TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1074,28):E 20140318 215307 531cacd0 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1091,28):E 20140318 220939 531cacd2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1100,28):E 20140318 222316 531cacd3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1109,28):E 20140318 223953 531cacd4 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1118,28):E 20140318 225325 531cacd5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1127,28):E 20140318 231029 531cacd6 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1153,28):E 20140318 232433 531cacd9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1178,28):E 20140318 234037 531cacdc TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log"(1187,28):E 20140318 235447 531cacdd TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(8,28):E 20140319 001045 531cacde TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(17,28):E 20140319 002453 531cacdf TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(26,28):E 20140319 004053 531cace0 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(35,28):E 20140319 005501 531cace1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(44,28):E 20140319 011101 531cace2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(53,28):E 20140319 012509 531cace3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(62,28):E 20140319 014107 531cace4 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(71,28):E 20140319 015515 531cace5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(80,28):E 20140319 021115 531cace6 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(89,28):E 20140319 022524 531cace7 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(98,28):E 20140319 024124 531cace8 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(107,28):E 20140319 025531 531cace9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(116,28):E 20140319 031131 531cacea TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(133,28):E 20140319 032540 531cacec TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(142,28):E 20140319 034140 531caced TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(151,28):E 20140319 035548 531cacee TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(160,28):E 20140319 041147 531cacef TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log"(177,28):E 20140319 042555 531cacf1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-24.log"(131,28):E 20140324 001706 531cadde TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-24.log"(442,28):E 20140324 001858 531cadde TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(32,28):E 20140326 012825 5331c348 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(41,28):E 20140326 015833 5331c349 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(50,28):E 20140326 022840 5331c34a TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(59,28):E 20140326 025849 5331c34b TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(68,28):E 20140326 032856 5331c34c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(85,28):E 20140326 035906 5331c34e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(94,28):E 20140326 042914 5331c34f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(111,28):E 20140326 045922 5331c351 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(128,28):E 20140326 051400 5331c353 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(137,28):E 20140326 052930 5331c354 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(146,28):E 20140326 054409 5331c355 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(155,28):E 20140326 055940 5331c356 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(164,28):E 20140326 061419 5331c357 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(173,28):E 20140326 062948 5331c358 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(190,28):E 20140326 064427 5331c35a TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(199,28):E 20140326 065954 5331c35b TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(208,28):E 20140326 071434 5331c35c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(217,28):E 20140326 073002 5331c35d TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(226,28):E 20140326 074444 5331c35e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(235,28):E 20140326 080011 5331c35f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(252,28):E 20140326 081450 5331c361 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(269,28):E 20140326 083018 5331c363 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(278,28):E 20140326 084458 5331c364 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(287,28):E 20140326 090027 5331c365 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(312,28):E 20140326 091507 5331c368 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(1173,28):E 20140326 093034 5331c377 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(1906,28):E 20140326 094518 5331c37d TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(1993,28):E 20140326 101522 5331c383 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(2066,28):E 20140326 104538 5331c38c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(2093,28):E 20140326 111540 5331c38f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(2294,28):E 20140326 114547 5331c39c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(2355,28):E 20140326 121555 5331c3a4 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(2376,28):E 20140326 124603 5331c3a7 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log"(2397,28):E 20140326 131612 5331c3aa TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-07.log"(1766,28):E 20140407 084244 5331cc51 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-09.log"(9820,28):E 20140409 131217 53442110 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-09.log"(10505,28):E 20140409 161127 53442176 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-11.log"(168,28):E 20140411 105003 53459e5e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-14.log"(104,28):E 20140414 105002 53484991 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(502,28):E 20140416 004827 53484aaa TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(517,28):E 20140416 004844 53484aac TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(853,28):E 20140416 011836 53484ad1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(862,28):E 20140416 011852 53484ad2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(1482,28):E 20140416 014845 53484b17 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(1497,28):E 20140416 014901 53484b19 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(2042,28):E 20140416 021853 53484b57 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(2064,28):E 20140416 021910 53484b58 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log"(2588,28):E 20140416 024919 53484b92 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-27.log"(9243,28):E 20140427 120521 534eecb5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-27.log"(11210,28):E 20140427 174445 534eee0d TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(259,28):E 20140429 092552 535e50b9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(267,28):E 20140429 092601 535e50c1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(307,28):E 20140429 092647 535e50bc TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(323,28):E 20140429 092704 535e50ba TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(334,28):E 20140429 092730 535e50c2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(340,28):E 20140429 092737 535e50c8 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(348,28):E 20140429 092741 535e50c7 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(361,28):E 20140429 092819 535e50c5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(394,28):E 20140429 092856 535e50cc TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(402,28):E 20140429 092858 535e50c9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(411,28):E 20140429 092921 535e50cd TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(418,28):E 20140429 092924 535e50cf TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(434,28):E 20140429 093011 535e50d2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(443,28):E 20140429 093016 535e50d4 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(459,28):E 20140429 093025 535e50d3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(467,28):E 20140429 093028 535e50d5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(499,28):E 20140429 093128 535e50d9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(507,28):E 20140429 093155 535e50d8 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(515,28):E 20140429 093208 535e50da TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(547,28):E 20140429 093316 535e50e1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(592,28):E 20140429 093412 535e50db TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(604,28):E 20140429 093424 535e50e7 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(612,28):E 20140429 093505 535e50e8 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(627,28):E 20140429 093531 535e50ea TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(642,28):E 20140429 093548 535e50ec TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(650,28):E 20140429 093552 535e50ed TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(678,28):E 20140429 093701 535e50f2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(687,28):E 20140429 093711 535e50ef TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(689,28):E 20140429 093711 535e50f3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(697,28):E 20140429 093817 535e50f1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(992,28):E 20140429 093905 535e5117 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(7549,28):E 20140429 100106 535e544b TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(7551,28):E 20140429 100117 535e544c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(7741,28):E 20140429 101334 535e5457 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log"(7855,28):E 20140429 105350 535e5471 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log"(3322,28):E 20140430 103627 535e565f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log"(3550,28):E 20140430 103733 5360b631 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log"(5219,28):E 20140430 104313 5360b6e5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log"(7632,28):E 20140430 105156 5360b8d1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log"(8517,28):E 20140430 105504 5360b934 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(3329,28):E 20140501 130918 5360bbaa TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(4910,28):E 20140501 131520 53622c01 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(6610,28):E 20140501 132140 53622dbb TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(6699,28):E 20140501 132156 53622dcc TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(8564,28):E 20140501 132849 53622f5b TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(8934,28):E 20140501 133013 53622f6f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(9967,28):E 20140501 140125 536230e5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10015,28):E 20140501 140221 536230eb TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10052,28):E 20140501 140320 536230e2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10056,28):E 20140501 140330 536230f1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10080,28):E 20140501 140358 536230ee TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10127,28):E 20140501 140501 536230f6 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10167,28):E 20140501 140616 536230f3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10168,28):E 20140501 140621 53623100 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10173,28):E 20140501 140625 536230f9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10231,28):E 20140501 140750 536230fd TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10292,28):E 20140501 140936 53623928 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10316,28):E 20140501 141004 53623929 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10332,28):E 20140501 141012 53623927 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10356,28):E 20140501 141100 53623930 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10365,28):E 20140501 141120 53623931 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10428,28):E 20140501 141251 5362392e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10429,28):E 20140501 141254 53623935 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10440,28):E 20140501 141309 53623937 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10458,28):E 20140501 141346 53623934 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10484,28):E 20140501 141406 53623939 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10486,28):E 20140501 141410 5362393e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10592,28):E 20140501 141624 53623ab3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10616,28):E 20140501 141651 53623ab9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10632,28):E 20140501 141704 53623ab1 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10648,28):E 20140501 141728 53623aba TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10656,28):E 20140501 141750 53623ab0 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10663,28):E 20140501 141753 53623abe TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10695,28):E 20140501 141826 53623abd TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10703,28):E 20140501 141829 53623ac9 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10705,28):E 20140501 141829 53623ac5 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10707,28):E 20140501 141829 53623ac6 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10709,28):E 20140501 141829 53623ac0 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10711,28):E 20140501 141829 53623abf TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10713,28):E 20140501 141829 53623ac3 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10715,28):E 20140501 141829 53623ac4 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10717,28):E 20140501 141829 53623ac7 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10728,28):E 20140501 141829 53623ac2 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10730,28):E 20140501 141829 53623ac8 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10835,28):E 20140501 142716 53623cf8 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10912,28):E 20140501 142918 53623d06 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10939,28):E 20140501 142946 53623d04 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10979,28):E 20140501 143101 53623d0e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(10984,28):E 20140501 143102 53623d0c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11011,28):E 20140501 143148 53623d10 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11043,28):E 20140501 143218 53623d14 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11051,28):E 20140501 143222 53623d15 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11083,28):E 20140501 143343 53623d1a TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11112,28):E 20140501 143400 53623d20 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11131,28):E 20140501 143408 53623d1c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11147,28):E 20140501 143511 53623d24 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11155,28):E 20140501 143516 53623d21 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11203,28):E 20140501 143601 53623d27 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11219,28):E 20140501 143641 53623d26 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11227,28):E 20140501 143649 53623d2a TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11243,28):E 20140501 143729 53623d2f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11266,28):E 20140501 143752 53623d30 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11272,28):E 20140501 143754 53623d33 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11283,28):E 20140501 143815 53623d2c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11291,28):E 20140501 143821 53623d35 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11323,28):E 20140501 143913 53623d34 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11331,28):E 20140501 143926 53623d3a TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11347,28):E 20140501 143955 53623d2d TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11361,28):E 20140501 144025 53623d3c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11380,28):E 20140501 144046 53623d3f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11426,28):E 20140501 144205 53623d42 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11470,28):E 20140501 144310 53623d48 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11509,28):E 20140501 144416 53623d52 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11533,28):E 20140501 144426 53623d4f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11547,28):E 20140501 144445 53623d4d TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11555,28):E 20140501 144519 53623d5b TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11558,28):E 20140501 144519 53623d54 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11579,28):E 20140501 144542 53623d5c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11665,28):E 20140501 144734 53624214 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11673,28):E 20140501 144756 53624215 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11729,28):E 20140501 144850 53624213 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11737,28):E 20140501 144905 5362421e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11745,28):E 20140501 144928 5362421c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11769,28):E 20140501 145014 53624224 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11841,28):E 20140501 145153 5362422c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11881,28):E 20140501 145253 53624231 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11913,28):E 20140501 145338 53624233 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11969,28):E 20140501 145506 5362423a TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(11985,28):E 20140501 145534 5362423c TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12004,28):E 20140501 145551 53624242 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12041,28):E 20140501 145618 5362423f TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12049,28):E 20140501 145649 53624243 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12057,28):E 20140501 145700 53624249 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12073,28):E 20140501 145726 53624245 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12105,28):E 20140501 145810 53624247 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12129,28):E 20140501 145910 5362424d TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12142,28):E 20140501 145916 53624250 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12152,28):E 20140501 145919 53624252 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12180,28):E 20140501 150028 53624254 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12209,28):E 20140501 150047 53624259 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12233,28):E 20140501 150110 53624257 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12246,28):E 20140501 150119 53624258 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12269,28):E 20140501 150158 53624260 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12275,28):E 20140501 150159 5362425e TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12286,28):E 20140501 150228 53624263 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12302,28):E 20140501 150248 53624262 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12311,28):E 20140501 150258 53624266 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12334,28):E 20140501 150330 53624268 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12347,28):E 20140501 150340 53624267 TCP/IP error.
"C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log"(12358,28):E 20140501 150359 5362426a TCP/IP error.
242 occurrences have been found in 19 files.
 Konrad
&lt;p&gt;Just checked my SMTP client log files and I found lots of TCP/IP errors in there (unfortunately, I have not log file before the upgrade to 4.8 beta):&lt;/p&gt;&lt;p&gt;&amp;nbsp; &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-17.log&quot;(911,28):E 20140217 110347 53008239 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-22.log&quot;(24,28):E 20140222 063152 5307ce37 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-24.log&quot;(102,28):E 20140224 090057 5307ce71 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-02-27.log&quot;(451,28):E 20140227 160631 5307cf96 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-06.log&quot;(232,28):E 20140306 131359 5311b2b5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-12.log&quot;(2765,28):E 20140312 152303 531c9f2c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(979,28):E 20140318 200908 531cacc5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(988,28):E 20140318 202244 531cacc6 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(997,28):E 20140318 203915 531cacc7 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1014,28):E 20140318 205251 531cacc9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1023,28):E 20140318 210924 531cacca TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1040,28):E 20140318 212300 531caccc TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1065,28):E 20140318 213932 531caccf TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1074,28):E 20140318 215307 531cacd0 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1091,28):E 20140318 220939 531cacd2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1100,28):E 20140318 222316 531cacd3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1109,28):E 20140318 223953 531cacd4 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1118,28):E 20140318 225325 531cacd5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1127,28):E 20140318 231029 531cacd6 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1153,28):E 20140318 232433 531cacd9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1178,28):E 20140318 234037 531cacdc TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-18.log&quot;(1187,28):E 20140318 235447 531cacdd TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(8,28):E 20140319 001045 531cacde TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(17,28):E 20140319 002453 531cacdf TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(26,28):E 20140319 004053 531cace0 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(35,28):E 20140319 005501 531cace1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(44,28):E 20140319 011101 531cace2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(53,28):E 20140319 012509 531cace3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(62,28):E 20140319 014107 531cace4 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(71,28):E 20140319 015515 531cace5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(80,28):E 20140319 021115 531cace6 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(89,28):E 20140319 022524 531cace7 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(98,28):E 20140319 024124 531cace8 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(107,28):E 20140319 025531 531cace9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(116,28):E 20140319 031131 531cacea TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(133,28):E 20140319 032540 531cacec TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(142,28):E 20140319 034140 531caced TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(151,28):E 20140319 035548 531cacee TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(160,28):E 20140319 041147 531cacef TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-19.log&quot;(177,28):E 20140319 042555 531cacf1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-24.log&quot;(131,28):E 20140324 001706 531cadde TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-24.log&quot;(442,28):E 20140324 001858 531cadde TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(32,28):E 20140326 012825 5331c348 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(41,28):E 20140326 015833 5331c349 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(50,28):E 20140326 022840 5331c34a TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(59,28):E 20140326 025849 5331c34b TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(68,28):E 20140326 032856 5331c34c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(85,28):E 20140326 035906 5331c34e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(94,28):E 20140326 042914 5331c34f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(111,28):E 20140326 045922 5331c351 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(128,28):E 20140326 051400 5331c353 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(137,28):E 20140326 052930 5331c354 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(146,28):E 20140326 054409 5331c355 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(155,28):E 20140326 055940 5331c356 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(164,28):E 20140326 061419 5331c357 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(173,28):E 20140326 062948 5331c358 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(190,28):E 20140326 064427 5331c35a TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(199,28):E 20140326 065954 5331c35b TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(208,28):E 20140326 071434 5331c35c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(217,28):E 20140326 073002 5331c35d TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(226,28):E 20140326 074444 5331c35e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(235,28):E 20140326 080011 5331c35f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(252,28):E 20140326 081450 5331c361 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(269,28):E 20140326 083018 5331c363 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(278,28):E 20140326 084458 5331c364 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(287,28):E 20140326 090027 5331c365 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(312,28):E 20140326 091507 5331c368 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(1173,28):E 20140326 093034 5331c377 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(1906,28):E 20140326 094518 5331c37d TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(1993,28):E 20140326 101522 5331c383 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(2066,28):E 20140326 104538 5331c38c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(2093,28):E 20140326 111540 5331c38f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(2294,28):E 20140326 114547 5331c39c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(2355,28):E 20140326 121555 5331c3a4 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(2376,28):E 20140326 124603 5331c3a7 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-03-26.log&quot;(2397,28):E 20140326 131612 5331c3aa TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-07.log&quot;(1766,28):E 20140407 084244 5331cc51 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-09.log&quot;(9820,28):E 20140409 131217 53442110 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-09.log&quot;(10505,28):E 20140409 161127 53442176 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-11.log&quot;(168,28):E 20140411 105003 53459e5e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-14.log&quot;(104,28):E 20140414 105002 53484991 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(502,28):E 20140416 004827 53484aaa TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(517,28):E 20140416 004844 53484aac TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(853,28):E 20140416 011836 53484ad1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(862,28):E 20140416 011852 53484ad2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(1482,28):E 20140416 014845 53484b17 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(1497,28):E 20140416 014901 53484b19 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(2042,28):E 20140416 021853 53484b57 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(2064,28):E 20140416 021910 53484b58 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-16.log&quot;(2588,28):E 20140416 024919 53484b92 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-27.log&quot;(9243,28):E 20140427 120521 534eecb5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-27.log&quot;(11210,28):E 20140427 174445 534eee0d TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(259,28):E 20140429 092552 535e50b9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(267,28):E 20140429 092601 535e50c1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(307,28):E 20140429 092647 535e50bc TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(323,28):E 20140429 092704 535e50ba TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(334,28):E 20140429 092730 535e50c2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(340,28):E 20140429 092737 535e50c8 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(348,28):E 20140429 092741 535e50c7 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(361,28):E 20140429 092819 535e50c5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(394,28):E 20140429 092856 535e50cc TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(402,28):E 20140429 092858 535e50c9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(411,28):E 20140429 092921 535e50cd TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(418,28):E 20140429 092924 535e50cf TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(434,28):E 20140429 093011 535e50d2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(443,28):E 20140429 093016 535e50d4 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(459,28):E 20140429 093025 535e50d3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(467,28):E 20140429 093028 535e50d5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(499,28):E 20140429 093128 535e50d9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(507,28):E 20140429 093155 535e50d8 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(515,28):E 20140429 093208 535e50da TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(547,28):E 20140429 093316 535e50e1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(592,28):E 20140429 093412 535e50db TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(604,28):E 20140429 093424 535e50e7 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(612,28):E 20140429 093505 535e50e8 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(627,28):E 20140429 093531 535e50ea TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(642,28):E 20140429 093548 535e50ec TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(650,28):E 20140429 093552 535e50ed TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(678,28):E 20140429 093701 535e50f2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(687,28):E 20140429 093711 535e50ef TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(689,28):E 20140429 093711 535e50f3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(697,28):E 20140429 093817 535e50f1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(992,28):E 20140429 093905 535e5117 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(7549,28):E 20140429 100106 535e544b TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(7551,28):E 20140429 100117 535e544c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(7741,28):E 20140429 101334 535e5457 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-29.log&quot;(7855,28):E 20140429 105350 535e5471 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log&quot;(3322,28):E 20140430 103627 535e565f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log&quot;(3550,28):E 20140430 103733 5360b631 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log&quot;(5219,28):E 20140430 104313 5360b6e5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log&quot;(7632,28):E 20140430 105156 5360b8d1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-04-30.log&quot;(8517,28):E 20140430 105504 5360b934 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(3329,28):E 20140501 130918 5360bbaa TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(4910,28):E 20140501 131520 53622c01 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(6610,28):E 20140501 132140 53622dbb TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(6699,28):E 20140501 132156 53622dcc TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(8564,28):E 20140501 132849 53622f5b TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(8934,28):E 20140501 133013 53622f6f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(9967,28):E 20140501 140125 536230e5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10015,28):E 20140501 140221 536230eb TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10052,28):E 20140501 140320 536230e2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10056,28):E 20140501 140330 536230f1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10080,28):E 20140501 140358 536230ee TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10127,28):E 20140501 140501 536230f6 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10167,28):E 20140501 140616 536230f3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10168,28):E 20140501 140621 53623100 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10173,28):E 20140501 140625 536230f9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10231,28):E 20140501 140750 536230fd TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10292,28):E 20140501 140936 53623928 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10316,28):E 20140501 141004 53623929 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10332,28):E 20140501 141012 53623927 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10356,28):E 20140501 141100 53623930 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10365,28):E 20140501 141120 53623931 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10428,28):E 20140501 141251 5362392e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10429,28):E 20140501 141254 53623935 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10440,28):E 20140501 141309 53623937 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10458,28):E 20140501 141346 53623934 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10484,28):E 20140501 141406 53623939 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10486,28):E 20140501 141410 5362393e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10592,28):E 20140501 141624 53623ab3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10616,28):E 20140501 141651 53623ab9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10632,28):E 20140501 141704 53623ab1 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10648,28):E 20140501 141728 53623aba TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10656,28):E 20140501 141750 53623ab0 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10663,28):E 20140501 141753 53623abe TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10695,28):E 20140501 141826 53623abd TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10703,28):E 20140501 141829 53623ac9 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10705,28):E 20140501 141829 53623ac5 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10707,28):E 20140501 141829 53623ac6 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10709,28):E 20140501 141829 53623ac0 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10711,28):E 20140501 141829 53623abf TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10713,28):E 20140501 141829 53623ac3 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10715,28):E 20140501 141829 53623ac4 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10717,28):E 20140501 141829 53623ac7 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10728,28):E 20140501 141829 53623ac2 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10730,28):E 20140501 141829 53623ac8 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10835,28):E 20140501 142716 53623cf8 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10912,28):E 20140501 142918 53623d06 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10939,28):E 20140501 142946 53623d04 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10979,28):E 20140501 143101 53623d0e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(10984,28):E 20140501 143102 53623d0c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11011,28):E 20140501 143148 53623d10 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11043,28):E 20140501 143218 53623d14 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11051,28):E 20140501 143222 53623d15 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11083,28):E 20140501 143343 53623d1a TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11112,28):E 20140501 143400 53623d20 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11131,28):E 20140501 143408 53623d1c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11147,28):E 20140501 143511 53623d24 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11155,28):E 20140501 143516 53623d21 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11203,28):E 20140501 143601 53623d27 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11219,28):E 20140501 143641 53623d26 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11227,28):E 20140501 143649 53623d2a TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11243,28):E 20140501 143729 53623d2f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11266,28):E 20140501 143752 53623d30 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11272,28):E 20140501 143754 53623d33 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11283,28):E 20140501 143815 53623d2c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11291,28):E 20140501 143821 53623d35 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11323,28):E 20140501 143913 53623d34 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11331,28):E 20140501 143926 53623d3a TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11347,28):E 20140501 143955 53623d2d TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11361,28):E 20140501 144025 53623d3c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11380,28):E 20140501 144046 53623d3f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11426,28):E 20140501 144205 53623d42 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11470,28):E 20140501 144310 53623d48 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11509,28):E 20140501 144416 53623d52 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11533,28):E 20140501 144426 53623d4f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11547,28):E 20140501 144445 53623d4d TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11555,28):E 20140501 144519 53623d5b TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11558,28):E 20140501 144519 53623d54 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11579,28):E 20140501 144542 53623d5c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11665,28):E 20140501 144734 53624214 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11673,28):E 20140501 144756 53624215 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11729,28):E 20140501 144850 53624213 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11737,28):E 20140501 144905 5362421e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11745,28):E 20140501 144928 5362421c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11769,28):E 20140501 145014 53624224 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11841,28):E 20140501 145153 5362422c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11881,28):E 20140501 145253 53624231 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11913,28):E 20140501 145338 53624233 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11969,28):E 20140501 145506 5362423a TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(11985,28):E 20140501 145534 5362423c TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12004,28):E 20140501 145551 53624242 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12041,28):E 20140501 145618 5362423f TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12049,28):E 20140501 145649 53624243 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12057,28):E 20140501 145700 53624249 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12073,28):E 20140501 145726 53624245 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12105,28):E 20140501 145810 53624247 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12129,28):E 20140501 145910 5362424d TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12142,28):E 20140501 145916 53624250 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12152,28):E 20140501 145919 53624252 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12180,28):E 20140501 150028 53624254 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12209,28):E 20140501 150047 53624259 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12233,28):E 20140501 150110 53624257 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12246,28):E 20140501 150119 53624258 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12269,28):E 20140501 150158 53624260 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12275,28):E 20140501 150159 5362425e TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12286,28):E 20140501 150228 53624263 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12302,28):E 20140501 150248 53624262 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12311,28):E 20140501 150258 53624266 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12334,28):E 20140501 150330 53624268 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12347,28):E 20140501 150340 53624267 TCP/IP error. &quot;C:\Users\konrad\Desktop\SMTPCLIE\SMTPCLIE\14-05-01.log&quot;(12358,28):E 20140501 150359 5362426a TCP/IP error. 242 occurrences have been found in 19 files. &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;Konrad&lt;/p&gt;
I've minimal experience with VMware myself, but there appears to be some different ways to set up and control network traffic:
http://www.virtualizationadmin.com/articles-tutorials/vmware-server-workstation-player-articles/understanding-virtual-networking-vmware-workstation-9.html
http://www.techrepublic.com/blog/data-center/set-bandwidth-limits-with-vmware-traffic-shaping/
There is various information about networking troubleshooting as well, which may or may not be useful in this case:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1007842
As the entire TCP/IP module is updated in v4.80 you should probably first try it with the current beta release though. If problems persist there is a special version of mercury.exe that creates minidump files, that David can use to track a crash in the Visual Studio debugger.
&lt;p&gt;I&#039;ve minimal experience with VMware myself, but there appears to be some different ways to set up and control network traffic:&lt;/p&gt;&lt;p&gt;http://www.virtualizationadmin.com/articles-tutorials/vmware-server-workstation-player-articles/understanding-virtual-networking-vmware-workstation-9.html&lt;/p&gt;&lt;p&gt;http://www.techrepublic.com/blog/data-center/set-bandwidth-limits-with-vmware-traffic-shaping/&lt;/p&gt;&lt;p&gt;There is various information about networking troubleshooting as well, which may or may not be useful in this case:&lt;/p&gt;&lt;p&gt;http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&amp;amp;cmd=displayKC&amp;amp;externalId=1007842&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;As the entire TCP/IP module is updated in v4.80 you should probably first try it with the current beta release though. If problems persist there is a special version of mercury.exe that&amp;nbsp;&lt;span style=&quot;font-size: 10pt;&quot;&gt;creates&amp;nbsp;&lt;/span&gt;&lt;span style=&quot;font-size: 10pt;&quot;&gt;minidump files, that David can use to track a crash in the Visual Studio&amp;nbsp;&lt;/span&gt;&lt;span style=&quot;font-size: 10pt;&quot;&gt;debugger.&lt;/span&gt;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
